bios repair FL490/FL590 NM-B931
  • azemar
    • Nov 2022
    • 46
    • France
    Re: bios repair FL490/FL590 NM-B931
    Originally posted by Elvirus
    Azemar did you connect your laptop to an external monitor if the capslock is on i think its actually booting but noo screen
    i think hoaca388 is right
    Yes non Signal ,caps lock is on but no reaction numpad off and no reaction either just the cpu which heats up with 0.8v and 1.1v in voltage
    • hoaca388
      Badcaps
      • Jan 2022
      • 12237
      Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
      • azemar
        • Nov 2022
        • 46
        • France
        Originally posted by hoaca388
        Ok thanks you
        • jhay06
          • Jan 2023
          • 12
          • Philippines
          Sorry if this like a thread hijack , please allow me to ask if the shared files on this thread is can be use on Thinkpad L490 ?
          sorry again . thanks
          • hoaca388
            Badcaps
            • Jan 2022
            • 12237
            There are 2 models 20Q5 and 20Q6, you have to post the corrupted original bios file and serial number.
            • jhay06
              • Jan 2023
              • 12
              • Philippines
              #26
              It's 20Q6 model
              Serial number: PF2827G8
              can you teach me how to extract bios using esp2019 ? or ch341 ? thanks
                • 21586
                It's 20Q6 model
                1. How to dump and flash
                https://www.badcaps.net/forum/showpo...40&postcount=2
                • Zibbo
                  • Mar 2017
                  • 203
                  • Zimbabwe
                  #28
                  ThinkPad L590 - Type 20Q7
                  Works perfectly. Thank you
                  • bmb2015
                    • Jul 2023
                    • 10
                    Hi Everyone. I have a Thinkpad L590 with a Winbond 25Q256JVEQ bios chip. The serial is PF-1YGGLK. Machine: 20Q700ALUK. Bios installed prior to issues was ROZET53W (1.31). The issues started happening when I was trying to make it into hackintosh and one of the steps required reset of nvram. After that it was blank. I was able to get the chip off motherboard and save the attached corrupt bios.
                    Hope this info helps.
                    • volinakis
                      • Jan 2021
                      • 2871
                      • N/A
                      #30
                      try
                      • bmb2015
                        • Jul 2023
                        • 10
                        Originally posted by volinakis
                        try
                        Thank you so much again. This fixed my other laptop as well. It was a challenge to put the bios chip back on the board but it seems to have done the trick. Your help is very much appreciated volinakis.
                        • judamex
                          Active Member
                          • Jan 2021
                          • 185
                          • Mexico
                          #32
                          Hello everyone, could someone help me to clean these files from password?
                        • judamex
                          Active Member
                          • Jan 2021
                          • 185
                          • Mexico
                          #33
                          The model of the machine is L490 type 20Q6 the serials were erased by a scratch
                          These files are my backup
                          i found serial Number PF29G0QG
                          • Mcnick 3
                            • Mar 2024
                            • 7
                            • Poland
                            #34
                            try
                            Hello, i had the same issue, tried making a hackintosh, resetted the nvram and the screen went blank, i've flashed this bios, the laptop started working but it is booting very slow and audio doesn't work (in windows, Intel smart sound OED, code 10 FW did not sent FW Ready notification).
                            Lenovo ThinkPad L590 with i5-8365u vPro
                            Serial number: PF1W2L93
                            Machine number: 20Q8-S20E00
                            Bios version before issues: R0ZET57W 1.35
                            Bios chip: Macronix MX25L25673G
                            Here's my original bios after resetting nvram
                            • volinakis
                              • Jan 2021
                              • 2871
                              • N/A
                              #35
                              read again bios chipset, it can't be that corrupt after resetting nvram.
                              • Mcnick 3
                                • Mar 2024
                                • 7
                                • Poland
                                #36
                                i've read it 2 times and i got the same readings, right now i flashed the bios "L590_NVRAM" and it turns on but is booting very slowly and the sound doesn't work like i described in my last message.
                                • volinakis
                                  • Jan 2021
                                  • 2871
                                  • N/A
                                  #37
                                  yep, that's because ME. i'll try rebuild and clean ME for your bios but you have to use LMU to write back DMI
                                  • volinakis
                                    • Jan 2021
                                    • 2871
                                    • N/A
                                    #38
                                    try
                                    • Mcnick 3
                                      • Mar 2024
                                      • 7
                                      • Poland
                                      #39
                                      What is LMU and DMI? i'm new to this and i have a CH341A programmer.
                                        SMDFlea commented
                                        Editing a comment
                                        Lenovo Maintenance Utility to write the DMI (serial number,UUID etc)
                                    • Mcnick 3
                                      • Mar 2024
                                      • 7
                                      • Poland
                                      #40
                                      try
                                      Thank you very much it worked! I didn't have to use LMU it had already correct DMI.
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • zlr8r
                                        looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                        by zlr8r
                                        looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                        cheers
                                        Dell Inspiron 17 (7786) Laptop
                                        Service Tag: 5J0NHT2
                                        Bios: 1.9.0
                                        MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                        Attached;
                                        1. My saved bios using a programmer
                                        2. Dells Bios updater .exe (v1.16)
                                        3. Dells Bios recovery file
                                        4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                        5. Image of ME...
                                        12-18-2023, 03:08 PM
                                      • bschwand
                                        ASUS N550JK laptop reboots after 30 minute, BIOS extracted invalid...
                                        by bschwand
                                        as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
                                        I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
                                        Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...
                                        05-22-2024, 02:48 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
