why my trusty DPD5005 is not recognized by MANY laptops as charger?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Today another laptop not detected my DPS5005 as a charger and wont charge or start. Anybody have a clue why or what types of PSU is better with laptops?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: why my trusty DPD5005 is not recognized by MANY laptops as charger?
    What brand ? Dell and HP use the centre pin to identify the rating of the dc adapter.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      mostly acer and asus. hp and lenovo no problem. dell have chip inside charger so on dell i use only original charger
      • julianmustofa
        Lenovo G485 LA-8681p Laptop recognized charger only when OFF position
        by julianmustofa
        Hi i've been troubleshooting laptop that only charge/recognized dc in when it in OFF position.
        When i plugged in charger in ON position it won't recognized/charging at all
        So when i need to charge the laptop i need to turn it off>plugged charger>and turn it on again. That way the laptop is charging/detect dc in
        I have an schematic of the board. But i'am not expert at diagnosing board level like this
        So what i need to check in this kind of problem? Is it resistors? Or mosfet charging?
        I provide the schematic link thanks
        Schematics: https:...
        04-18-2023, 04:17 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • Johndill
        Dell Inspiron 7567 LA-D993P odd charger issue
        by Johndill
        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
        Here are the tested scenarios:
        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
        2. With the laptop off, plug in charger (LED says on) & the front charging...
        11-16-2022, 10:55 PM
