820-00165 Sensor Issue
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste,
    I have a Macbook 820-00165 that came in for repair with a few components missing. We replaced those from a donor board and the laptop is now booting.
    But there are2 major problems, the fan seems to be spinning constantly and the laptop wont go to sleep mode when turn the flap down. It remains on.
    What can be the issue?
  • reformatt
    • Feb 2020
    • 1410
    Re: 820-00165 Sensor Issue
    Trackpad cable or trackpad itself. Fan will run flat out without trackpad, and SMC_LID goes through that cable as well.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Originally posted by reformatt
      trackpad cable or trackpad itself. Fan will run flat out without trackpad, and smc_lid goes through that cable as well.
      replaced both the cable and the trackpad, still the same.
      Resistance at smc_lid of j4800 is also normal.
      • reformatt
        • Feb 2020
        • 1410
        Lid sensor is in the DC IN board, with the magnet in the lid. You can manually check it by using a magnet over the DC IN board to trigger it. If not working, you can try another DC IN board, LIO cable and inspect J9500. SMC_LID should toggle when the magnet is used.
        As far as fan running fast goes, run diagnostics from boot (hold D) and report any errors. I have seen a bad SSD cause this so try another by substitution.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Problem was with the small LIO Board.Issue Resolved. Thanks for the help guys.
          • Stephen
            A2141 MacBook Pro 16" lid sensor issue.
            by Stephen
            Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
            11-01-2024, 03:45 PM
          • drake441335
            OLED65G6P-U.BUSWLJR Temperature sensor issue
            by drake441335
            I am a very beginner at tv repairs. I am trying to fix my tv before I end up buying a new one. I do not know names of boards, but I will do my best to explain what I have done so far.
            Tv is an LG OLED65G6P manufactured in april 2016. I had a warranty on it till September of 2021. Warranty is done. The problem I am having is when I turn the tv on after about two or so minutes a popup comes up and says the temperature sensor issue, and then it powers itself off. The tv works as designed, picture, sound, wifi, settings and everything, before it just powers itself down.
            So i did what any...
            02-13-2022, 03:34 PM
          • spidertnt
            820-02443 14" M1 angle sensor / keyboard / trackpad not working
            by spidertnt
            FYI.
            I just had a 14" M1 MacBook Pro with liquid damage very small pretty much only angle sensor sustained any corrosion or damage.
            But both keyboard and trackpad will not work at all ! Screen would flicker on and off all the time.
            I ended up re-building the traces on the angle sensor cable using very small copper wire... this fixed both the flickering and the keyboard / trackpad.
            I'm like WTF does the angle sensor have to do with keyboard / trackpad ?
            04-29-2023, 11:03 AM
          • CapLeaker
            AcuRite 5 in 1 temperature sensor replacement repair
            by CapLeaker
            Got a new victim:
            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
            B: stuck at some temperature and maybe updating once in 12 hrs or so.
            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
            04-15-2025, 01:32 PM
          • kjchatman
            lenovo yoga 7 14itl5 keyboard and trackpad issue
            by kjchatman
            i've done several clean installations of windows 10 and 11 to try to resolve why the keyboard and trackpad only works in the bios setup. there are no errors in the device manager. since they work in the bios setup then can i assume that this is a software issue?
            05-22-2025, 08:44 PM
