Problem Macbook 2019 16” A2141 no power
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Re: Problem Macbook 2019 16” A2141 no power
    Damaged nands, almost 100% guaranteed. Swap full set from like-board, keep track of which nand goes where. They must be swapped as a set, and must be replaced in exact same spots.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      Originally posted by zpi
      Thats to low, if you have thermal camera. Yo can inject 1-2volts to see bad nand.
      Hi guys you were right, I found 1 of the 4 nand shorted and I removed it, now I no longer have 6 Ohm but with the nand removed it doesn't start anyway and I have the loop, is it necessary to solder it? I also noticed that the PP3v3_S5 is not generated anyway, is everything normal? Should I just change the broken nand or all of them?
      • dclass-pro
        • Dec 2022
        • 157
        • Italy
        unfortunately I don't have a similar card, I have to change them all, but can you advise me where to buy them from? the code is TSB4227
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          Its not so simple, you will also have to rewrite T2 firmware, also nand chips has to be from same part number donor board.
          • dclass-pro
            • Dec 2022
            • 157
            • Italy
            ok that's fine then I will provide the customer with an estimate for everything or for a new logic board. Thanks so much guys !!!!
            • reformatt
              • Feb 2020
              • 1451
              Basically Apple put a ticking time bomb into each 16" MAC. This is a completely shit design and Apple should take the heat for it. This fault is so common that most will be written off due to the expense and complexity of a repair, or replacement of the board. I don't believe the investment is a good one.
              This area is right on top of the air intake so it always subjected to the elements. They put underfill on everything else, but no protective coating on this area. That is despite this being a known issue for some years. They truly are taking the p__s.
              • tech_guru
                Macbook Pro 2019 A2141 NAND Shorted
                by tech_guru
                Hello. If you could please help me understand what I am doing wrong...
                This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
                I also replaced the tps power ic for the ssd.
                Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
                08-28-2025, 08:04 AM
              • cheebster
                MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
                by cheebster
                Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
                Nand voltages are missing.
                I've found no shorts at all so far, no signs of heat via thermal camera either.
                PPBUS_G3H 12.31
                PP3V3_G3H_RTC 3.387v
                PP3V3_G3H 12.31v
                PP2v5_NAND_SSD0 0v 58 ohms
                PP2v5_NAND_SSD1 0v 57.8 ohms
                PP1v8_SLPS2R 1.8v
                PP1v1_SLPS2R 1.1v
                P3V3_G3H_SOCPMU 3.37v
                PP0V9_SLPDDR 0.9v...
                10-11-2023, 11:31 AM
              • tomtom67
                MacBook Pro 16" (2019) A2141: power consumption? Dead GPU? MacOS not installing
                by tomtom67
                A friend brought his fresh-from-ebay macbook pro A2141 after he failed replacement keyboard plugging.
                I fixed all the little problems he introduced.
                I am unable to install macOS to this device. Both Sequoia and Catalina (from Internet Recovery) start to install, but after ~2-5 minutes into the installation the macbook does a hard restart (max fan spin for a split second, then reboot without chime).
                I noticed what I think is a very high power consumption, like 20V/1.7A when activating WiFi for internet recovery, and more like 20V/3.7-4.1A while downloading the recovery...
                10-08-2024, 08:59 AM
              • martyjelen
                Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
                by martyjelen
                Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                PP3v3_G3H_RTC_X is present - 3,3V
                PP3v3_G3H_SOCPMU is present - 3,3V
                ​What else should I check?
                Thank you for your help.
                05-05-2025, 01:34 AM
              • ApplePie14
                MacBook Pro 2019 16inch A2141 no power
                by ApplePie14
                My Macbook, which had been working fine until two weeks ago, now has unstable power and won't turn on.
                When I took it apart, I found a lot of dust, so I think that might be what caused the damage.
                I checked with a USB meter and found that the voltage is 20V, and the current consumes a maximum of about 150mA, then fluctuates between 4 and 70mA.
                The same thing happens when the battery is removed.
                There were no short circuits in the PPBUS_G3H or NAND.
                08-25-2025, 12:17 AM
