Problem Macbook 2019 16” A2141 no power
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    I have a strange problem with a MacBook Pro 2019 16” A2141 that won't boot, initially it was shorted The U9080 chip that generates the PP2V5_NAND_SSD1, replaced and now I have the 2.5v together with all voltages 3V 1.8v 0.9v when I plug in the power supply and it passes quietly from 5 to 20v and it starts charging but after a few seconds the absorption goes to 0 and it tries again but nothing happens it doesn't start and the fans don't turn… the battery starts charging but then since it goes to 0 it doesn't load it anymore and so in an infinite loop 😩 I noticed that I don't have the PP3V3_S5 voltage, I didn't understand who generates it but I thought the problem was the PMU, which I changed but the exact same defect.. not nothing has changed.
    If I put the MAC in dfu mode, the other macbook sees it and from Apple Configurator if I click on the Restore button, the restore starts and at point 4 out of 4 it crashes and an error comes out.
    What can I check? I've been going crazy for days and I can't find the solution.
    Thank you all!
  • mon2
    • 14244
    Re: Problem Macbook 2019 16” A2141 no power
    Is the power adapter the original or at least rated to support this macbook?
    Suggest 100W Type C and see if the fault remains.
    Do you have a thermal camera? Some component may be heating up and causing this loop.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      I'm doing the test with the bench power supply and the BY-3200 adapter, but it doesn't absorb even 1A so it shouldn't be a power problem... I have the thermal imager but it doesn't heat anything.
      If I turn on the motherboard without the battery I have an absorption of 100mA/110mA, is this normal?
      • mon2
        • 14244
        I know that some macbook models do require a battery to boot. Not sure of the exact models but Tim @ TCRS (youtube) specifically mentions this key detail.
        May be worthwhile to locate his video that mentions the same - believe it is in the early part of the video.
        • Aliseo
          • Dec 2022
          • 12
          • Italy
          Hello dear, you have a problem with the PMIC, replace it and check.
          I had the same problem on an a2179, an air and I fixed it
          • dclass-pro
            • Dec 2022
            • 157
            • Italy
            ok i will try to check from the video, thanks for the advice, anyway even if i connect the battery i dont have the pp3v3_s5... i tried through dfu mode but this is the error i get "Error AMRestoreErrorDomain 6 - Faliedto handle message type StatusMsg), I don't want there to be some problem with the NAND... but I can't figure out who generates the PP3v3_S5 and when it should be generated..
            • dclass-pro
              • Dec 2022
              • 157
              • Italy
              Originally posted by Aliseo
              Ciao caro, hai un problema con il PMIC, sostituiscilo e fai delle verifiche.
              Ho Aavuto lo stesso problema su un a2179, un air e ho risolto
              hi which one do you mean exactly by PMIC ? I changed the PMU and nothing changed
                • 20977
                english please https://translate.google.it/ In inglese per favore
                • dclass-pro
                  • Dec 2022
                  • 157
                  • Italy
                  "Originally Posted by Aliseo View Post
                  I had the same problem on an a2179, an air and I fixed it"
                  • anhbanxoi
                    • Sep 2021
                    • 173
                    • VN
                    Check the resistant between PPBUS and PP2V5_NAND_SSD1. I think the ssd is gone.
                    • dclass-pro
                      • Dec 2022
                      • 157
                      • Italy
                      Hi, the resistance between PP2V5_NAND_SSD0 and ground is 6 ohm, but when I power the card the 2.5v is fine and doesn't become 0 it remains very stable. the resistance between PPBUS_G3H and PP2V5_NAND_SSD0 is 2 Mohm
                      • reformatt
                        • Feb 2020
                        • 1414
                        If you had a short on PPBUS_G3H due to U9080, then the usual failure pattern is application of 12V onto a 2.5V rail. Damage to the NAND's is highly likely in that event. 6 ohms sounds pretty low to me.
                        • dclass-pro
                          • Dec 2022
                          • 157
                          • Italy
                          Do you advise me to unsolder the nands and see if the machine turns on?
                          • zpi
                            • Feb 2018
                            • 132
                            • Lithuania
                            Machine will be in power on loop without nands same as you have now, your boards behavior is same as bad nands, just had same case, but one of two nand power rails was shorted by nand. Check both coils near u9080
                            • dclass-pro
                              • Dec 2022
                              • 157
                              • Italy
                              all coils both near U9080 and near U9580 are good
                              • zpi
                                • Feb 2018
                                • 132
                                • Lithuania
                                I mean check resistance to ground on these coils.
                                • dclass-pro
                                  • Dec 2022
                                  • 157
                                  • Italy
                                  it is about 2k between coils near U9080 and ground (but nands are not mounted and 6ohm between coils near U9580 and ground nand soldered)
                                  • zpi
                                    • Feb 2018
                                    • 132
                                    • Lithuania
                                    Lift one side of L9580 and L9581, and check if 6ohm is on pin 1 side or pin 2 side (nand side or controller side)
                                    • dclass-pro
                                      • Dec 2022
                                      • 157
                                      • Italy
                                      I confirm the 6ohm are nand side
                                      • zpi
                                        • Feb 2018
                                        • 132
                                        • Lithuania
                                        Thats to low, if you have thermal camera. Yo can inject 1-2volts to see bad nand.
                                        • cheebster
                                          MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
                                          by cheebster
                                          Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
                                          Nand voltages are missing.
                                          I've found no shorts at all so far, no signs of heat via thermal camera either.
                                          PPBUS_G3H 12.31
                                          PP3V3_G3H_RTC 3.387v
                                          PP3V3_G3H 12.31v
                                          PP2v5_NAND_SSD0 0v 58 ohms
                                          PP2v5_NAND_SSD1 0v 57.8 ohms
                                          PP1v8_SLPS2R 1.8v
                                          PP1v1_SLPS2R 1.1v
                                          P3V3_G3H_SOCPMU 3.37v
                                          PP0V9_SLPDDR 0.9v...
                                          10-11-2023, 11:31 AM
                                        • geolangston
                                          2019 macbook a2141 backlight troubleshooting
                                          by geolangston
                                          Hello, I have a 2019 macbook a2141 with no backlight. video image is visible with flashlight but no backlight. All the associated circuitry is located on the back side of the logic board. I've removed the logic board and display and have them connected together on the bench so I can probe the back side of the board. I'm applying power through a usb-c port attached to the logic board but I'm not sure how to actually boot the logic board. I tried attaching the power button and that didn't work. I also have the fans attached and they are not spinning. If anyone can help me with this setup I would...
                                          05-21-2023, 04:18 PM
                                        • Dani1406
                                          MacBook Pro A2141 2019 16'' - 820-02037-06 - schematic & boardview
                                          by Dani1406
                                          Hey guys.
                                          I received a MacBook A2141 with a board-number, that hasn't even been mentioned in this forum: 820-02037-06. Does anybody have a schematic and a boardview for this model?
                                          The device is crashing when idle or performing low-power tasks like browsing etc., so I'd like to check whether a cpu-mosfet swap would help, but I do not know the exact type of mosfet used.
                                          Thanks in advance!
                                          07-03-2023, 12:20 PM
                                        • Karmet
                                          MacBook Pro 16" 2019 NAND Swap
                                          by Karmet
                                          I couldn't find a post related to this, so if it exists please point me in that direction.
                                          I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
                                          I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
                                          07-24-2023, 10:48 AM
                                        • sdogs
                                          Macbook Pro 16 A2141 stuck in network boot
                                          by sdogs
                                          Good evening guys ;-) In a moment of lucid madness I bought a macbook pro 16 A2141 on which they sat on it. Aside from the banana shape and obviously gone screen, the macbook turns on, sounds the initial gong.
                                          I disassembled the screen and connected it to an external display, using a usb-c adapter, but I can't reinstall the os.
                                          I tried SMC and PRAM reset but the result doesn't change, the recovery starts only from the network, I tried different USB pendrives with different operating systems but nothing, it sees the boot device for an instant and immediately goes looking for the network....
                                          02-25-2023, 11:27 AM
