Razer Blade RZ09-01953 Switches off under Nvidia GPU load
  • ZixuTech
    • Oct 2017
    • 90
    Working on this Razor Blade RZ09-01953, which seems to work fine on light tasks or when the GPU stress test is running under Intel, but the minute it runs under Nvidia, it cuts power.
    Could it be GPU failure? I ran some GUI memtests and came up fine. MATS GPU RAM test doesn't seem to boot
    Anybody experienced it or have advice on where to look to? No liquid damage signs/
  • ZixuTech
    • Oct 2017
    • 90
    Re: Razer Blade RZ09-01953 Switches off under Nvidia GPU load
    I have spotted slight corrosion signs around the KBD controller; cleaned but doesn't look serious. Still same.
    • Sephir0th
      • Oct 2020
      • 1289
      There is a small chance but there is one. First make sure the GPU is recognized and running with latest drivers. If everything is good and issue still persists take a look at the Phases for creating GPU-Core. Sometimes there is at one Phase the Gate shorted with Drain (for example). I'd exclude that before saying dead GPU.
      FairRepair on YouTube
      • ZixuTech
        • Oct 2017
        • 90
        Thanks for your reply. No short on the GPU core MOSFETs. Reflowed them just in case.
        The previous repair shops drowned Memory and MOSFET pads with thermal paste. Ultrasonic Cleaned the board just in case to prevent any short between Mosfet legs, not sure how elctro-conductive that thermal paste is.
        Still the same cut-off when under GPU load. I also noticed that it sometimes cuts off when even loading windows, after that heat treatment.
        Could it be a cold joint on the memory chips, which gapped up after the reheat? There is nothing much in that area.
        https://www.badcaps.net/forum/attach...1&d=1667702573
        • rediii
          h???, spurrrn
          • Mar 2018
          • 499
          • somewhere in europe
          the thermal paste looks like there was a bad hotspot on the gpu... or was it renewed? the thermal paste on the pads don't make sense though
          • Sephir0th
            • Oct 2020
            • 1289
            When I look at the GPU die I'd the heatsink doesn't make proper contact. Could be part of the issue.
            Also I'd even rule out the charger in case of it fails under load.
            • ZixuTech
              • Oct 2017
              • 90
              Yeah thought the same, hence went and UCd the whole board to make sure nothing conductive is left.
              @Sephir0th, I feed it with 15A Bench PSU pulls 4A at max.Temps are in the 60*s range. When I fire up Heaven its stable on the loading part, but cuts off the minute game starts.
              I went and reflowed the GPU, to eliminate cold joint. But still same. Maybe RAM chips next - seems to be common thing with Desktop GPUs. But cant run MATS to confirm.
              • theplop
                Razer blade 2022, 14" PI480 wont boot to OS, freezes
                by theplop
                Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
                I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
                I've run memtest quite a few times, and more often then not...
                03-20-2025, 06:42 PM
              • 0xx
                2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                by 0xx
                Hi folks,
                My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                I assumed that Windows Update was interrupted due to closing...
                09-14-2025, 03:46 PM
              • shellybelly
                Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                by shellybelly
                Back Story
                I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                08-27-2023, 10:40 PM
              • Awdev
                Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
                by Awdev
                S/N is BY2011A72401766
                Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
                MB Model is: DA530-MB
                Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
                10-18-2025, 02:13 AM
              • Trodrigue
                razer blade stealth 13 2019
                by Trodrigue
                Hi everyone, I'm posting this message for help. I was given a Razer Blade motherboard because many people around me know that I like to tinker or make things with computer salvage.
                The problem with this board is that the person ripped out the keyboard port from the board.
                But in short, it's not a problem in itself because I'm planning to build a console with this motherboard.
                The problem is turning on the card without the keyboard.
                So I'm looking for another way to turn it on, either by
                using the pins or by using the ITE chip ref: IT8320VG-256 1920-DX0 EA07ZB....
                10-02-2025, 10:17 AM
