HP 15-r239nl LA-B972P 1 blink caps lock
  • resistor83
    • Oct 2018
    • 127
    • Italy
    hello everyone, I have this laptop that flashes continuously when switched on, it would seem a cpu problem because a 1 slow flashing is seen on the capslock key
    Is there a chance that you can do something with this type of error?
    here video: https://streamable.com/8qx8aw
    thank you
  • Jenova56
    • Feb 2020
    • 12
    • FR
    Re: HP 15-r239nl LA-B972P 1 blink caps lock
    Hi
    Saw your video, according to hp , it mean
    Processor not executing code.
    Do you have its original bios dump ?
    Already tried rebuild and clear me?
    • resistor83
      • Oct 2018
      • 127
      • Italy
      yes I have my bios original dump and I have already tried to flash my bios with another one but it always does the same
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You have not provided any measurements. So its impossible to suggest anything based on symptoms only.What rails are coming up after turning on and what's missing-thats important to understand.
        • resistor83
          • Oct 2018
          • 127
          • Italy
          sorry but these days I had the flu.
          However, I am not very experienced at reading wiring diagrams so I need to know what measurements I should take.
          Meanwhile, I analyzed the motherboard with a thermal imaging camera and noticed a temperature spike here when I turn on the PC
          • rediii
            h???, spurrrn
            • Mar 2018
            • 489
            • somewhere in europe
            give us readings of all coils in ohms mode. they are marked as PLxxx
            • resistor83
              • Oct 2018
              • 127
              • Italy
              PL302 11ohm
              PL303 250ohm
              PL102 nothing
              PLW2 nothing
              PLM2 362ohm
              PLZ2 42ohm
              PLV2 43ohm
              PQV3 43ohm
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Voltage on these same coils please.
                • resistor83
                  • Oct 2018
                  • 127
                  • Italy
                  only PL102 3,20v
                  other coils 0v
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I'm wondering how caps lock is blinking. It seems your mb is even not turning on. Lets start with basic measurements.
                    01.PU101 pin1/4/5/6/20 voltage.
                    02.Pu301, pin14/15 voltage.
                    • resistor83
                      • Oct 2018
                      • 127
                      • Italy
                      PU101:
                      Pin 1 19,84 v
                      Pin 4 25,8 v
                      Pin 5 3,29 v
                      Pin 6 2,70 v
                      Pin 20 19,54 v
                      PU301:
                      Pin 14 5,01 v
                      Pin 15 3,29 v
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        All these measurements are perfectly correct. So it must be charging battery.Right?? IS it turning on when power switch is pressed??
                        Consumption on dc supply in 01.When off02.When turned on??
                        Have you tried flashing BIos??
                        PCH_RSMRST#/LID SW#/EC_RST# present on SIO??
                        • resistor83
                          • Oct 2018
                          • 127
                          • Italy
                          yes, if I connect the battery it recharges with the orange LED
                          i tried to flash the bios already and i have a clean bios in this thread (https://www.badcaps.net/forum/showth...59#post1175959) but it always blinking 1 caplocks
                          PCH_RSMRST# 0v
                          LID SW# 3,28v
                          EC_RST# 3,19v
                          sorry I did not understand the question, what measurements should I do with the tester?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            You are powering the mb with adapter or Dc supply?? If later, Your dc supply will give a value of current consumption like 0.009 which means 9mA current. Interested in this reading.
                            So mb is not turning on??You have not clarified on this?? Since RSMRST# is 0 and this remains 0 in off condition on many mb and gets to 3.3V only after turning on. So wantsed to be sure if RSMRST# at 0 is ok or not on this platform in off condition.
                            • resistor83
                              • Oct 2018
                              • 127
                              • Italy
                              until now I used the original HP power supply and the laptop turned on even if it got very hot as I showed the photos with the thermal imager in the previous posts
                              I measured RSMRST # when I turned on the pc and I see 3.23v
                              but now I'm worried: I tried to power the laptop with my stabilized power supply, when I connected the connector there were 0.00A of absorption, I still tried to turn it on and the fan was spinning and warming up the motherboard just like before with the HP power supply. Then I turned off the power supply and from that moment every time I try to turn on the notebook, the power led lights up, the fan stops spinning and after a few seconds the notebook turns off
                              maybe the high temperatures on some components have given way?
                              I don't seem to have done anything strange
                              however all the measurements I made before are the same even now (PU101, PU301, LID SW#, EC_RST# and PCH_RSMRST#)
                              RSMRST # when I turn on, the pc always gives 3.23v but now after a few seconds it turns off
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                What is the status of PCHPWR_EN/SYSON/SUSP# for the brief seconds when it turns on. You have to find out the point where to measure,keep the dmm probe on that point and then turn on to measure as it turns off for few seconds only.
                                To me it seems SUSP# will be the issue here. Lets find out.
                                • resistor83
                                  • Oct 2018
                                  • 127
                                  • Italy
                                  all 3 give 0v, both when turned off and on
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Ok thats bad news but measure the voltage(while turned on) on SIO for the following pins:
                                    9/37/67/75/112
                                    • resistor83
                                      • Oct 2018
                                      • 127
                                      • Italy
                                      PC OFF
                                      pin 9 3,29v
                                      pin 37 3,18v
                                      pin 67 3,29v
                                      pin 75 0,49v
                                      pin 112 0v
                                      PC ON
                                      pin 9 3,29v
                                      pin 37 3,18v
                                      pin 67 3,29v
                                      pin 75 0,49v
                                      pin 112 3,29v
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        PCH_DPWROK status when powered on?? Check DC3/DC4.The reading on Post#19 are all ok. I dont have any further ideas and too me it seems like Dry PCH. If you have the necessary tools and expertise, reballing the SOC is worth trying. Do you have a bga rework station?? If yes, then warm the SOC on bga machine upto 225 degree with lot of flux. Dont use a hot air gun to warm up the SOC-it may be killed.
