HP 15-r239nl LA-B972P bios request
  • resistor83
    • Oct 2018
    • 127
    • Italy
    hi everyone, i need this bios
    thank you
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: HP 15-r239nl LA-B972P bios request
    thank you
    File has Extracted from HP latest version, try it and let me know.
    all donations are welcome,
    • resistor83
      • Oct 2018
      • 127
      • Italy
      not work, caps lock blinking continuously
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Older version without DMI. if it didn't work, you must have hardware issue.
        BTW what's your original bios symptoms
        • resistor83
          • Oct 2018
          • 127
          • Italy
          it would seem a 1 slow caps lock blink
          cpu??
          https://streamable.com/8qx8aw
          • hardware1
            • Sep 2021
            • 2948
            • N/A
            cpu??
            According to HP blinking table, 1 blink means CPU failure. but you said it's continuous blinking.
            • resistor83
              • Oct 2018
              • 127
              • Italy
              yes, look my video: https://streamable.com/8qx8aw
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                yeah, it's 1 blink. create a new thread there, maybe someone can help you.
                https://www.badcaps.net/forum/forumdisplay.php?f=23
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • hotcrossedbuns999
                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                  by hotcrossedbuns999
                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                  3. I could only locate two chips that look like bios chips. Could someone verify this
                  01-03-2025, 12:32 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
