IPhone 11 Temperature Sign
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello, Namaste.
    We have an iphone 11 for which we had changed the NAND IC and upgraded from 64gb to 128gb.
    After upgrading the iPhone shows a Temperature Sign but there is no heating in the board. We did a lot of trial and error and found that whenever the Charging Flex and Power Flex are connected together the sign shows. If either one is removed there is no such sign.
    We replaced the lower board just to check if there was a problem with the connection pads maybe but the issue persists.
    I think we have messed up while replacing the NAND. Any help from anyone will be highly appreciated. Thanks in Advance
  • mon2
    • 14634
    Re: IPhone 11 Temperature Sign
    Double check your pads. Watch this video on iphone 12 with the same fault.
    https://youtu.be/IH-uKWq3MEY
    • Instafixx
      • Jul 2022
      • 374
      • India
      Hello Mon2, the pads seem to fine. For double assurance we even swapped the lower board. The problem still persisted.
      • tojaert
        • Sep 2022
        • poland
        hello,
        an answer you are looking for should find out here: https://youtu.be/9E3Dwi4lHXo
        • tranquility
          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
          by tranquility
          i want to repair an Onkyo TX-NR809 receiver.
          symptoms:
          on power on, display appears and i hear one click. enue functions is given.
          - no hdmi output
          - audio output not tested, but i think it is not there
          - usb sticks are not recognized
          if i read out the chips with display+standby button + tone+
          both dts show only ????
          chip is D830K013BZKB4
          things i have done:
          - reflow of the dts chip without taking off and reballing
          - changed the aluminium caps without the big one with 25v because i dont...
          08-25-2025, 01:04 AM
        • bogosort
          iPhone 13 mini not booting, shorted test pads
          by bogosort
          I am trying to diagnose an iPhone 13 Mini that does not boot. (Amp meter shows a couple milli amps then goes to zero, looping).
          Here are some measurements I took :
          Is it worth trying to repair this?
          Thank you...
          09-22-2024, 11:11 AM
        • Spider1211
          iPhone XS Data recovery from NAND flash
          by Spider1211
          Hey guys, I have an iPhone XS which came in as dead. The phone was not worked on before (I was the first to open it). After diagnosis (Splitting board, etc) it's confirmed to have a shorted PP2v63_NAND line.
          Removed the NAND flash and short is gone on the board. Measuring directly on the NAND, there is about 2 to 15ohm to ground.
          Is there anyway of backing up data externally in such cases (Client has some very important files and no back ups)?
          08-22-2022, 09:22 AM
        • mattpd
          PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
          by mattpd
          PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
          No LM damage. UART gives a generic "APU not responding" error.
          Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
          I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
          So to those with experience, would you expect at least a little heat from the NAND during...
          09-02-2025, 09:42 AM
        • CapLeaker
          AcuRite 5 in 1 temperature sensor replacement repair
          by CapLeaker
          Got a new victim:
          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
          B: stuck at some temperature and maybe updating once in 12 hrs or so.
          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
          04-15-2025, 01:32 PM
