Hp 15-cs2023ca USB 2.0 not working
  • mferna14
    • Jun 2018
    • 1046
    Hi, I am working on a Hp 15-cs2023ca Laptop, Logic Board # DAG7BMB58C0 REV: C. The motherboard works fine but the USB 2.0 does not work at all & gives Error "unknown usb device (device descriptor request failed)" in Windows 10. I checked the 5v & GND, both fine. Checked the coil of TX & RX, resistence between both the point is around 400Khms & no shorts at all. Does this signal come directly from the SOC??? If someone can put in their expertises on this issue, I would appreciate. Thanks in advance.
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    Re: Hp 15-cs2023ca USB 2.0 not working
    do you mean USB3 ports? according to the spec, this unit has 1 USBC and 2 USBA ports. Is absolutely any of these working fine?
    • mferna14
      • Jun 2018
      • 1046
      Thanks for the reply. This has Only 2 USB ports & built-in USB 3.0 in it. I am only concerned about the Generic USB 2.0 which should work & now not working for some reason. More info pls. ask me. Thanks
      • reformatt
        • Feb 2020
        • 1526
        Do you have a Chipmunk USB tester? If not, get one. Can save you buckets of time with USB port issues.
        • mon2
          • Dec 2019
          • 14685
          Remove all power. Meter in diode mode.
          Red meter probe to ground.
          Black meter probe to the D+ on the usb connector. What is the measurement?
          Repeat with D- on the usb connector (black lead on meter). What is the measurement?
          You may have local esd diodes that are damaged. Other faults may be an onboard usb hub controller that links to these ports. Check for the IC nearby.
          Check the diode values against a known good USB port on any laptop.
          • cruiser_
            • Nov 2019
            • 124
            • Ireland
            I'm going by this (external ports).
            According to available G7BD schematics (not sure how close it resembles DAG7BMB58C0) the only elements between the ports and the PCH would be the ESDs or USB multiplexer. If you say your USB3 works fine then the multiplexer is out of the way iMHO.
            See if USB power stays at steady 5V when you plug devices in.
            Go for data lines with oscilloscope and see if they are sound/stable.
            • diamon
              • 107
              • Netherlands
              I have seen these errors also on Dell laptops, after a reinstall of Windows 10, they didn't come back
              • mferna14
                • Jun 2018
                • 1046
                I mentioned the meter reading for the Data lines, both are almost 400Khms, & the 5v is always present, the voltage is not fluctuating at all, stable as ever. I checked, but there does not seem to be any protection diode. After the coil, the circuit is directly going to the SOC, I am assuming this as I do not have the schematics for this model. I have a used another SSD with fresh Windows 10 on it & still gives "unknown usb device (device descriptor request failed)"
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  On newer mb's, there is no esd diode/controller . All bypassed by manufacturer to cut costs and hence any surge/malfunction in usb port directly affets the PCH part of SOC. Sad but true.
                  • cruiser_
                    • Nov 2019
                    • 124
                    • Ireland
                    Actually that is a good thought to follow.
                    To rule out software issue try booting off a Linux usb and see if they work there.
                    I've seen win boxes having usb description read issue while trying to read usb2 devices in usb3 port.
                    • mon2
                      • Dec 2019
                      • 14685
                      Also confirm the integrity of the 24mhz crystal onboard. This clock is linked to the usb controller engine.
                        • 22001
                        Is the card reader working. Post a picture of the USB board both sides
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          As well as webcam working or not??
                          • mferna14
                            • Jun 2018
                            • 1046
                            Thanks, I will check both & report later..
                            • mferna14
                              • Jun 2018
                              • 1046
                              You guys are so right "SMDFlea" & "mcplslg123", USBs, Webcam & SD Card reader solt even is not working. I have attached the photos of tHe USB board, kindly look into it. Hopefully we can resolve this problem. Thanks
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                USB+Webcam+Card Reader-not working is a sure indication of shorted SOC(USB part of PCH). So only SOC replacement will solve it. Else , dont waste your time.
                                • mferna14
                                  • Jun 2018
                                  • 1046
                                  Thanks mcplslg123 for the answer, I will do one last deep testing & then will order new motherboard.
                                  • mon2
                                    • Dec 2019
                                    • 14685
                                    3rd time...crystal ok ?
                                    • mferna14
                                      • Jun 2018
                                      • 1046
                                      Hey "mon2" read it now., I was so involved with the others.. Mon2 where is this crystal???/ Do you have a location for it? & how will I be able to test crystal??? Kindly inform me please. Thanks
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Crystal can be tested with DSO. Should be located near to SOC.
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • kamiewtype
                                          MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                                          by kamiewtype
                                          I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                                          The specs are:
                                          MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                                          Intel core i9-10900kf
                                          2x16gb Corsair Vengeance kit
                                          BIOS ver is E7D06IMS.1B0, from 6/12/2023
                                          The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                                          I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                                          11-01-2024, 10:52 AM
                                        • Björn Brunkau
                                          Palit 980ti no FBVDDQ, no NVVDD, all other voltages working fine
                                          by Björn Brunkau
                                          Hi there,
                                          I am looking for help with my broken 980ti. Had a bad DrMos (the bottom one) and replaced it, card worked for a short moment, but I got another shortes DrMos (second one) and replaced that one aswell.
                                          Now I don't measure any shorts, I have 12v, PEX, 5v, 3.3v all working fine (probing points on card), but I can't get any voltage at FBVDDQ or NVVDD probing points.
                                          Where could I check to find the fault?
                                          You think my first DrMos could be bad, because I read that the first one will activate core?
                                          Don't want to replace that one when I can just test other...
                                          05-11-2024, 10:41 AM
                                        • waterchill
                                          Apple iPad Pro 12,9" 4Gen no charging, but working fine
                                          by waterchill
                                          Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
                                          So I started to replace this parts:
                                          - replaced usb-c port -> no result
                                          - replaced battery -> no result
                                          - replaced usb-c chip CD3217B12A -> no result
                                          - replaced 343S00326 -> no result
                                          - replaced 343S00327 -> no result
                                          - replaced 343S00328 -> no result
                                          I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
                                          04-30-2024, 05:37 AM
                                        • wshadow
                                          HP Mini 800 G5 - Transfer identity & WinLic between two mainboards
                                          by wshadow
                                          I got two HP Mini 800 G5 machines, both 65W mainboards (have all 12 FETs populated on the CPU power rail).
                                          One board is always throwing errors in MemTest86, no matter which known good CPU/RAM combo installed. Board is fried. Period. Will be scrapped.
                                          The defective board contains a Win10Pro license in BIOS.
                                          The other board is working perfectly fine, but only includes a FreeDOS "license".
                                          I want to transfer the Win10Pro license from the fried board to the working one. If that includes transferring S/N etc, I'm fine with that, will...
                                          09-15-2025, 09:04 AM
