iPhone XS not charging
  • daro19862
    • Jul 2013
    • 20
    • Poland
    The cables and lighting port chargers did not help.
    Current consumption from the charger is 0,00A
    PC not reconize Iphone
    Iphone work if have battery is charged.
    I found short circuit on the lighting flex socket of the motherboard on pin 14 (PMU_TO_PHALANX2) and pin 17 (PMU_TO_PHALANX1).
    And pin 20 (MIKEYBUS_REFERENCE) 100 Ω.
    pin 24 (90_HYDRA_DP2_CONN_P ) pin 26 (90_HYDRA_DP2_CONN_N) pin 28 (90_HYDRA_DP1_CONN_P) and 30 (90_HYDRA_DP1_CONN_N) its OK
    Need replace U2700 ?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: iPhone XS not charging
    You need to change the chargings coils.
    Good luck
    • daro19862
      • Jul 2013
      • 20
      • Poland
      Which coils?
      FL6411 and FL6413?
      • elecsoluces
        • May 2020
        • 66
        • France
        Pin 14 and 17 on J6400 are ground pin it's not a short.
        Connect a charger and check PP_VBUS1_E75 (TP0773) you should have 5V.
        If it's ok you have to separate the motherboard and check value in diode mode around U3300.
        • daro19862
          • Jul 2013
          • 20
          • Poland
          Where found TP0773? with part pcp?
          I dont have soft only pdf
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            You can use phoneboard for boardview is free programma. Sorry i was mistake the chargingcoils is for iphone x probably hydra ic need to be replaced i think.
            https://phoneboard.co/
            • daro19862
              • Jul 2013
              • 20
              • Poland
              I have 5V on B242.
              Need 100% separate to continue ? or maybe U6300 (hydra) change?
              • tojaert
                • Sep 2022
                • poland
                no, this is a blind way.
                Desolder a sandwich and check again everything from PP_BAT way to VDD_Main. You have to have a some schematic diagram, boardview should be enough.
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
                • Thomasraud
                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                  by Thomasraud
                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                  QUOTED
                  -It works on charger (without battery connected-only charger)
                  -It works on battery (without charger connected-only battery)
                  -& it also works when plugged in battery & charger, but it's not charging the battery
                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                  and..
                  QUOTE
                  The IC cannot maintain the input current level
                  06-28-2022, 06:47 PM
                • Scoff
                  HP Probook 470 G4 - Power and Charging Problem
                  by Scoff
                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                  07-03-2023, 09:28 AM
                • SluggerB
                  Help with trying to fix phone that is not charging (Pics inside)
                  by SluggerB
                  I have two TCL A30 phones.
                  Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                  New Phone: Works fine, bought as a donor board to try and repair Old Phone
                  My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                  08-12-2024, 08:11 AM
                • Nash99
                  iPhone X not charging
                  by Nash99
                  Hi everyone
                  I replaced a battery fpc connector on an iPhone X. The process went well and the connector is connected securely. However, the iPhone is not charging. It powers on, however it does not show the lightning bolt when plugged in and the battery percentage is at a constant 0%. It was charging fine before the replacement. It still, however, makes the charging sound when it is plugged in and connects to a computer fine. What should I do? What can be causing this?
                  Also, I have attached a picture, please can some help identity what these two components are and what...
                  09-13-2021, 03:10 PM
