MBA A1932 820-01521-A no Post after few seconds it restarts
  • PACh
    • Feb 2022
    • 24
    • Austria
    Re: MBA A1932 820-01521-A no Post after few seconds it restarts
    Originally posted by mon2
    On the A1932, post the voltage readings of:
    SMBUS_3V3_BATT_SCL
    SMBUS_3V3_BATT_SDA
    I will do the measurements tomorrow and get back to you.
    Thank you
    • PACh
      • Feb 2022
      • 24
      • Austria
      SMBUS_3V3_BATT_SCL
      SMBUS_3V3_BATT_SDA
      SMBUS_3V3_BATT_SCL: 3.297V
      SMBUS_3V3_BATT_SDA: 3.297V
      *there small fast fluctuations between 3.297V and 3.289V
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        ALL_SYSPWRGD: 1.8V it should be higher volt.
        • PACh
          • Feb 2022
          • 24
          • Austria
          how many volts should it be?
          • mon2
            • Dec 2019
            • 14660
            Confirm with the schematics but believe that the pull-up resistor is to 1v8 so ALL_SYSPWRGD is ok at 1v8.
            What is the exact voltage at PPBUS_G3H ?
            • PACh
              • Feb 2022
              • 24
              • Austria
              #26
              what is the exact voltage at ppbus_g3h ?
              ppbus_g3h: 12.63v
              • mon2
                • Dec 2019
                • 14660
                Check each of the following rails:
                PP1v8_S3: Normal voltage is ~1.8v. Produced from U7800. (Powers system RAM.)
                PP1v2_S3: Normal voltage is ~1.2v. Produced from U8100/Q8100. (Powers system RAM.)
                PP1v_S3: Normal voltage is ~1.0v. Produced from U7800. (Powers some CPU functions.)
                • PACh
                  • Feb 2022
                  • 24
                  • Austria
                  #28
                  PP1v8_S3: 1.799V
                  PP1v2_S3: 1.199V
                  PP1v_S3: 1.004V
                  • mon2
                    • Dec 2019
                    • 14660
                    The PCH will then de-assert (pull low) PM_SLP_S3_L and PM_SLP_S0_L momentarily to enable the final stage in the power up sequence.
                    Confirm the following voltages:
                    PP1v2_S0SW: Normal voltage is ~1.2v. Produced from U8240.
                    PP1v_S0SW: Normal voltage is ~1.0v. Produced from U7800.
                    PPVCCIO_S0_CPU: Normal voltage is ~0.95v. Produced from U8110/Q8102.
                    PPVCCSA_S0_CPU: Normal voltage is ~1.5v. Produced from U7100/U7290/Q7291.
                    PPVCORE_S0_CPU: Normal voltage is ~ 0.75v. Produced from U7100/U7210/U7230.
                    PPVCCGT_S0_CPU: Normal voltage is ~ 0.75v. Produced from U7100/U7410/U7430.
                    • PACh
                      • Feb 2022
                      • 24
                      • Austria
                      #30
                      PP1v2_S0SW: 1.198V
                      PP1v_S0SW: 1.007V
                      PPVCCIO_S0_CPU: 0.957V at R8102, there is no PPVCCIO_S0_CPU at U8110/Q8102
                      PPVCCSA_S0_CPU: 1.109V from R7290, 1.144V from Q7291 CPUSA_SW_LL
                      PPVCORE_S0_CPU: 0.839V from R7230, R7210
                      PPVCCGT_S0_CPU: 0V from R7410, R7430 actually L7410, L7430 have 0V as well
                      • mon2
                        • Dec 2019
                        • 14660
                        Is your trackpad / keyboard connected during these tests ?
                        Remove them if they are and test again.
                        You can use the ON/OFF button in the bottom right of the PCB to turn the logic board on/off (SWE010; PMU_ONOFF_L)
                        • PACh
                          • Feb 2022
                          • 24
                          • Austria
                          #32
                          all my tests are with the board out, that part of my board looks different..
                          • PACh
                            • Feb 2022
                            • 24
                            • Austria
                            #33
                            I want to take the time a THANK YOU for the effort and time your are spending helping me,
                            I really appreciate it!
                            • PACh
                              • Feb 2022
                              • 24
                              • Austria
                              #34
                              did the tests again and the same results
                              • mon2
                                • Dec 2019
                                • 14660
                                Reflash the T2 Rom (U2890; 3v3 device) using the dump from here:
                                https://www.badcaps.net/forum/showth...ight=rom+dumps
                                * backup your original flash before erasing the device
                                • piernov
                                  • Jan 2016
                                  • 4439
                                  • France
                                  #36
                                  U2890 is USB-C controller ROM, not T2.
                                  • PACh
                                    • Feb 2022
                                    • 24
                                    • Austria
                                    #37
                                    reflashed (was fun removing that cover...) same voltages
                                      • 21853
                                      Did you see post #36
                                      • mon2
                                        • Dec 2019
                                        • 14660
                                        My bad - all in the basket of Tx propreitary crapware. The TBT rom was only to confirm the image is stable to maintain the 20V power delivery contracts.
                                        Is the display attached ? Can you test without the display to see if the results are different ?
                                        Can you confirm the voltages for the SOC ROM ?
                                        Check the Vcc; MISO; MOSI pins. Suspecting some I2C / SMBUS / SPI widget is timing out and the boot process restarts / loops.
                                        • PACh
                                          • Feb 2022
                                          • 24
                                          • Austria
                                          #40
                                          Wait so I should have reflashed the T2 Rom chip not the U2890? I reflashed the U2890 NOT the T2 rom U4770
                                          • lawrenceptrini
                                            Lenovo Ideapad 100-15ibd restarts every few seconds continuously.
                                            by lawrenceptrini
                                            Laptop turns on and restarts every 7 seconds or so.
                                            Power led and Webcam led turn on and goes off repeatedly.
                                            Pressing the power button does absolutely nothing.
                                            Same thing happens whether the bios battery is connected or not.
                                            I tried resetting the bios, press power button to drain power etc.,
                                            but no change same thing. I tried numerous ram modules but same result.
                                            Using a desktop power supply I can see the amps going to zero and rebuilding,
                                            same thing with multimeter. Doesn't matter if I plug in adapter or main battery,...
                                            12-27-2024, 10:20 PM
                                          • zklgfs
                                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                            by zklgfs
                                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                            08-11-2025, 02:14 PM
                                          • twonk9098
                                            Lenovo Legion 5 high fan spin turns off after 34 seconds
                                            by twonk9098
                                            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                            I have tried a few new bios but exactly...
                                            07-14-2024, 11:19 AM
                                          • Sephir0th
                                            DELL XPS 15 9560 - No VCore, Power Off after few seconds
                                            by Sephir0th
                                            Hello Community,
                                            i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
                                            It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
                                            Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
                                            I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
                                            05-09-2021, 11:22 AM
                                          • narf
                                            Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                            by narf
                                            hi all,
                                            first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                            i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                            what i've found so far:
                                            - the PSU does its job and supplies 12V to the mainboard via the connector.
                                            - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                            - not far away, there's the first cap with a resistance of 0.7 ohms....
                                            07-02-2024, 03:53 PM
