MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
  • gjlpereira
    • Sep 2018
    • 13
    • Portugal
    Hi forum.
    I'm working on a macbook pro, model a1708, that is running extremely slow.
    Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
    One other symptom of the problem with the machine is that the fan is always running at full speed.
    This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like I said before, the system is, for the most part, fully working.
    The previous person that worked on the machine just told me that he suspected that it was a problem with some sensor, but couldn't figure out more. Once I was told that the computer ran extremely slow with fan at full speed, that was also my initial guess; that it would be some issue with some sensor.
    So, to start with it, I did a full visual inspection of the motherboard under the microscope, to look for any liquid damage, corrosion, burned/damaged components or any other fiscal damage; it all looked good expected for a broken off capacitor that had been ripped of the motherboard; I knew that it wouldn't be the cause of the issue, but I replaced it and fixed the cap anyways.
    Next; and because I had an identical machine laying around, and to rule out any issue with trackpad, flex cabels, battery, display, etc, I swapped motherboards with a know good working machine; the anomalies persist. So, not the display, not the trackpad, etc etc.
    Next, since I had an equal fully working motherboard, with the motherboards side by side, I started measuring and comparing voltages, 20v ok, etc etc etc. Couldn't for the life of me find anything off on the motherboard.
    I have spend hours measuring and comparing the boards, with no luck. I then booted linux and took a reading of the sensors, in hope you guys could point me in the right direction on this one; because i'm at a lost on this one.
    Most of the sensors with odd readings I either can't identify them on the schematic/boardview, or they are not even on the motherboard.
    Would really appreciate some help/guidance on this one guys.
    Thank you very much,
    Dia
  • mon2
    • Dec 2019
    • 14662
    Re: MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
    1) it is very late for you ?
    2) what is the 820-xxxx of your logic board?
    3) Review this video from Louis and post your updates:
    https://www.youtube.com/watch?v=yuunAVCAd0g
    • gjlpereira
      • Sep 2018
      • 13
      • Portugal
      Its 03:12 right now; so yeah, a bit late. But I prefer it; I tend to work the "graveyard shift".
      Sorry for not posting that info in the first place, silly me. Motherboard is a 820-00840-A.
      I had already previously reviewed that (and many other) video(s) from Louis; that's why I swapped motherboards just to rule out any issue with the display; I even followed that specific video troubleshooting steps, with no luck.
      • mon2
        • Dec 2019
        • 14662
        1) Is a suitable USB Type C power adapter being used to power this unit? Suggest any 90-100W power adapter with power delivery support. We used the LVSUN for a while till someone stiffed us on Ebay and their theft of logic board parts (BGA with solder shorts and all) burnt out this nice adapter. Ebay refunded all in full and allowed us to keep the macbook.
        CUI is a good unit for us as well.
        Can the same power adapter power your known good unit at full / proper speed ?
        2) Sensors often are applied with the I2C (SMBUS) interface.
        Review the voltage of:
        SMBUS_SMC_1_S0_SCL
        SMBUS_SMC_1_S0_SDA
        SMBUS_SMC_5_G3H_SCL
        SMBUS_SMC_5_G3H_SDA
        We are hunting for stuck I2C logic levels which may indicate a fault that will halt proper communication and temp feedback to the bus master. I2C is an open-drain specification which should default to the pull-up voltage for each leg of these runs.
        • piernov
          • Jan 2016
          • 4439
          • France
          Ts0P
          • gjlpereira
            • Sep 2018
            • 13
            • Portugal
            SMBUS_SMC_1_S0_SCL
            SMBUS_SMC_1_S0_SDA
            SMBUS_SMC_5_G3H_SCL
            SMBUS_SMC_5_G3H_SDA
            Yes, a suitable USB type C power adapter is being used; I have tried three genuine apple power adapters and a couple of 3rd party ones, 90w+, and they all do the same anomaly. They will all negotiate to 20v. Also, they all work fine on the other known good working mackbook; the machine works fine at full speed with all of them.
            As for the voltage readings you asked:
            SMBUS_SMC_1_S0_SCL - 3.3v
            SMBUS_SMC_1_S0_SDA - 3.3v
            SMBUS_SMC_5_G3H_SCL - 3.4v
            SMBUS_SMC_5_G3H_SDA - 3.4v
            • gjlpereira
              • Sep 2018
              • 13
              • Portugal
              Originally posted by piernov
              Ts0P
              Isn't that related to palm rest/trackpad?
              I already tried another palm rest/trackpad, and same anomaly happens. I also tried this one on another board and it works fine.
              Maybe Ts0P on this motherboard relates to something different. Can you give me a little more please?
              • mon2
                • Dec 2019
                • 14662
                Be sure to test with known good interface cables for the keyboard / trackpad.
                • gjlpereira
                  • Sep 2018
                  • 13
                  • Portugal
                  I did; I don't think its the trackpad or cable; I swapped motherboards with another macbook and the anomaly remained; different chassis, different cables, different keyboard, trackpad, etc; and same anomaly; also, the known good motherboard works fine on this system; so I don't think it's an issue with trackpad.
                  • gjlpereira
                    • Sep 2018
                    • 13
                    • Portugal
                    Also, on this motherboard schematic I can't find any reference to Ts0P; is it called something else? Where would I go to follow its circuit and troubleshoot it?
                    • mon2
                      • Dec 2019
                      • 14662
                      Try a SMC bypass. Does this allow for a faster logic board?
                      • gjlpereira
                        • Sep 2018
                        • 13
                        • Portugal
                        I tried it, no change.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          • reformatt
                            • Feb 2020
                            • 1497
                            Boot MAC into Diagnostics mode (D on bootup) and see if there is an error. Any missing sensor data and the firmware will force the processor to throttle. I have seen a defective SSD itself on a Macbook Air throttle the system, so also swap it to rule it out.
                            If you ruled out external things, then check around thermal sensor IC's U5800/U5810/U5870 for corrosion etc under the BGA, especially the Vdd pad (pin 8 or 16). Highest current pad usually corrodes the quickest. You can lift these off to check.
                            • Francisco.s
                              Macbook air with 820-3437-B extremely slow
                              by Francisco.s
                              Hi, have a Macbook air with 820-3437-B with a weird problem.
                              It starts and seems to stop at the very beginning of POST, there is no chime and no access to usb boot pen-drive.
                              Current consumption is near 500 mili amps and seems not to do anything/
                              The weird issue is that if left it in this state "booting", the chime sounds about 4 minutes from start, and 2 minutes later I can see the pendrive led blinking and back-light is on. About 2 minutes more the progress bar starts, but in very slow motion.
                              It takes more than 30 minutes to show...
                              04-05-2023, 03:28 PM
                            • alexity
                              MacBook Pro A1708 VERY slow
                              by alexity
                              Hello
                              I'm 40, french IT guy, my wife have a MacBook Pro F-keys i5 13-inch Mid-2017 wich is VERY slow, fan don't turn at full speed, airport and motherboard sensors indicate 128 degrees
                              I tried to unplug the screen, the webcam, reset SMC... without effect
                              I've watch many videos about sensors issues, but all of the videos talk about fan turning at full speed which is not my case
                              do you have any idea ? what is wrong?
                              Motherboard number: 820-00840
                              regards
                              Alex​
                              02-29-2024, 06:49 AM
                            • EpicFix
                              MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                              by EpicFix
                              Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                              04-08-2025, 09:55 AM
                            • 24gsm
                              MacBook Pro A1708 install macos fail
                              by 24gsm
                              hi to all
                              i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                              after enter to recovery and format hdd 1to .
                              after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                              can help please
                              Serial Number: FVFXP0U0HV2J
                              Config Code: HV2J
                              Find My Mac: OFF
                              04-16-2025, 03:57 AM
                            • envym
                              MacBook Pro 2018 with Activation Lock
                              by envym
                              Hi everyone!
                              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                              06-27-2025, 08:54 AM
