Troubles with HP pro x2 612 g2
  • johnjohnjohnjohn
    • Sep 2019
    • 120
    • france
    #181
    Re: Troubles with HP pro x2 612 g2
    could BQ24780S be damaged ?
    • mon2
      • Dec 2019
      • 14792
      Yes, it could be. They are very common parts.
      https://www.aliexpress.com/item/3279...d=YBLXWO1IGF0t
      https://www.aliexpress.com/item/3286...d=DNtp2BSGYHK4
      • johnjohnjohnjohn
        • Sep 2019
        • 120
        • france
        #183
        so, i swapped it with two others I had on donor boards. Now 12V is allowed through the tpca8120 mosfets
        Nothing more, though, still no power.
        Just to check, I powered the board on battery with screen plugged in (tricky setup...) The board works like this, but when the battery will be empty, no way to charge it
        • mon2
          • Dec 2019
          • 14792
          Good to hear. Party @Piernov's will have to wait. I think the other mosfets linked to the 24780S will need a review when you are well rested. Good job on this fix to get here.
          Need to check again,
          ACDET
          REGN
          HIGH SIDE / LOW SIDE mosfets - are they shorted or not ? Their gate voltage ?
          The current sense feedback from the coil that is charging the battery.
          Battery mosfet as well.
          Update:
          Now use this state of the unit to download and reflash to the latest and greatest BIOS update. This procedure will also update the CYPD4125 firmware to be current. Curious to know if your charging of the battery state improves after this update.
          Also - the thread linked earlier notes that similar faults were from the battery itself - what @Piernov has mentioned many times in his blogs. 99% of the time, the battery is at fault. Do you have access to this battery from Amazon ? Just for testing to rule it out before we dig deeper. With Amazon, you can always return the battery.
          • johnjohnjohnjohn
            • Sep 2019
            • 120
            • france
            #185
            0.22V at battery mosfet source, 0.25V at battery mosfet gate
            0.22V at ACDET and REGN
            11.8 0.14A on my power supply. the board blinks white orange a few times when I put on my power supply. It means it reacts which is good I guess.
            While I was finishing this measure, suddenly the voltage dropped. Now, from the tpca 8120 drain pad where I soldered the wire to inject power, to the DC in mosfet drain : the resistance which was before 0, climb seemingly to the infinite.
            Power supply showed me only 0.02 A so I cut it, that s how I saw the resistance building up
            • johnjohnjohnjohn
              • Sep 2019
              • 120
              • france
              #186
              in fact, the resistance between dc usb c drain pad and the dc in mosfet now reaches 450 KOhms. I think the board gave up before I did. I believe resistance increasing suddenly between two pad means inside layer trace going bad
              • mon2
                • Dec 2019
                • 14792
                Earlier, you had success in powering up this board - was that with your power supply @ 12v ?
                Now the logic board no longer powers up ?
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #188
                  nope ! even on battery. . .
                  Maybe it was too big of step to try such a tricky fix so early ?
                  • mon2
                    • Dec 2019
                    • 14792
                    Is your battery charged at this time ?
                    If it is, when you attach it to the logic board, do you see any voltage AFTER the 2 x DCin charger mosfets ? This is the common shared point where the Type C voltage enters the charger circuit to power the board OR the battery mosfet is enabled by the 24780S to use the battery to power the board.
                    • johnjohnjohnjohn
                      • Sep 2019
                      • 120
                      • france
                      #190
                      I see voltage until lowdrv drain.
                      And now It starts again, on battery. Unfortunately, now that there is huge resistance between tpca 8120 mosfet pad and E6 GUD...
                      • mon2
                        • Dec 2019
                        • 14792
                        Does this mean the unit is able to power up to install a new bios ?
                        • johnjohnjohnjohn
                          • Sep 2019
                          • 120
                          • france
                          #192
                          In fact, I updated the BIOS first before even opening it up. It means the BIOS is the latest HP published for it
                          • johnjohnjohnjohn
                            • Sep 2019
                            • 120
                            • france
                            #193
                            I think I could try ordering the IC and mosfets on AliExpress. If it doesn't work, it will still be spare parts for another job, maybe.
                            The board forcing the manually chosen delivery contract, is it a way to bypass the cypress usb c controller when suspecting IC to adapter issues ? It might be useful, at least one day or another. What is it called ? I will order one.
                            I try to find a USB C port too.
                            If you think of anything that might be useful, please tell me, It will take at least two to three weeks until delivery, but I can't really blame the chinese, It's once in France that customs and postal service drag for at least a week.
                            • mon2
                              • Dec 2019
                              • 14792
                              Hi. Something like this:
                              US $0.72 33%OFF | PD/QC/AFC TYPE-C Fast Charge Trigger Polling Detector Notebook Power Supply Change Module Charger Board Tools 9/12/15/20V
                              https://a.aliexpress.com/_mqA21Kc
                              They are calling these 'decoy usb boards'.
                              Will post more suggestions tomorrow.
                              • rubaobh
                                • Aug 2025
                                • 3
                                • Brasil
                                #195
                                Hi, can anyone tell me what these three components marked in the photo are? I accidentally ripped them off!
Name:	Novo(a) Imagem de bitmap.png
                                • VHS
                                  • Oct 2020
                                  • 15
                                  Not sure if this will help anyone in the future.
                                  I just went through this with that same notebook, which was given to me for free, and I was told it was dead.
                                  It appears to want a genuine HP-branded adapter. I tried various USB-C notebook adapters, including Lenovo, ASUS, Dell, generic, Anker, and a Dell Wd19 dock, paired with a Dell 130W adapter.
                                  Nothing got more than a few blinks from the charging light, and most not even that.
                                  It wasn't until I took a genuine HP USB-C dock (g2) with a real HP adapter that it came to life.
                                  After much trial and error, I found one more off-brand USB-C adapter that worked, but suffice to say, I wouldn't rip into one of these before I tried a 'real' HP adapter or dock to charge it.
                                  The first thing I did after seeing that it wouldn't boot with my bench USB-C adapter was replace the battery with a new, partially charged one, and that's when I started chasing the no-charge issue and ended up here.
                                  HTH
                                  • VHS
                                    • Oct 2020
                                    • 15
                                    Just found this:
                                    https://www.chekyang.com/musings/201...pro-x2-612-g2/
                                    The HP Pro x2 comes with either a 45W or 65W charger – mine has the latter. However, the BIOS seems pretty fussy with the kind of adapter that will let it charge the laptop while in use. The Anker 5 Port 60W charger which can supply up to 30W via USB-C would not work – it would for the HP Elite x2 – but surprisingly, even the 65W charger that came with my X1 Carbon wouldn’t work either. On the other hand, the new Xiaomi Mi Power Bank Gen 3 USB-C powerbank which throws out 45W can charge the Pro x2, though it’ll gobble up the charge contained in its 20,000mAh capacity real quick. In any case, I picked up a Energea PowerHub 4PD+ 75W that puts out 60W through USB-C PD – and it works like a charm with the Pro x2.
                                    ________
                                      NVDC charger configuration...
                                      11-05-2024, 03:28 PM
                                      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                      Narrow VDC applications where the system power source is
                                      either the battery pack or the regulated output of the charger.
                                      This makes the max voltage to the system equal to the max
                                      battery voltage instead of the max adapter voltage. Operating
                                      at lower system voltage can improve...
                                      11-05-2024, 04:43 PM
                                    • flat-earther
                                      how to prevent a connected charger from draining battery when not charging?
                                      by flat-earther
                                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                      So the battery is backfeeding the charger and being drained.
                                      How can I prevent...
                                      08-07-2025, 01:04 PM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                      Bauer tool battery pack charging with a HERCULES charger modification
                                      by sam_sam_sam
                                      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                      05-06-2023, 12:17 PM
