Troubles with HP pro x2 612 g2
  • johnjohnjohnjohn
    • Sep 2019
    • 120
    • france
    #81
    Re: Troubles with HP pro x2 612 g2
    ok, it might be the interesting part.
    plugging order :
    DC first then Batt : tpc 8120 reading : D 11.9V S 11.9V G 0.23V
    Batt first then DC : tpc8120 readings are not the same for the two ICs.
    The left one on the photo reads D 4.96V S 4.63V G 4.43V
    The right one reads : D 0V S 4.63V G 4.43V
    • mon2
      • 14634
      On p-channel mosfets, the gate has to be lower than the voltage on the source / drain pins.
      If the gate is @ ~5v, the p-channel mosfet is being requested to remain OFF.
      When you have the battery first and then attach the dc adapter -> what are the voltages on the charger IC mosfets ?
      Your last post has drain @ 0v, is that the same voltage you see on the first of the DCin mosfets ?
      • johnjohnjohnjohn
        • Sep 2019
        • 120
        • france
        #83
        So, back to the BQ2480S area, in the scenario you asked, batt then dc
        the two DC mosfets are at D 8.23 for the "left" one, 0V everywhere else on them (Gates, other D, Sources)
        The batt mosfet is G 14V D 8.23 S 8.23
        • johnjohnjohnjohn
          • Sep 2019
          • 120
          • france
          #84
          I did the battery connector measurements too :
          if Batt first then DC : the 3 black wires 0V White and blue 3.33V Yellow 3.08V and the 3 red 8.23V
          if DC first then Batt : the 3 black wires 0V white and blue 3.33V yellow 3.1V and the 3 red 8.7V
          I guess that Batt first then DC is supposedly the correct sequence, as the batt is not supposed to be remove nor disconnected, it even powers the real time clock...
          • mon2
            • 14634
            Can you post a pic of your battery connector ? Do you not have the usual connector which will also have 2 pins for the SCL & SDA communication lines ?
            • mon2
              • 14634
              So with battery first, power adapter next, the charger IC is NOT receiving the power from the external power adapter.
              This is because the USB Type C controller logic is disabling the power adapter from powering the logic board.
              That is, the TPC8120 mosfets are at 0v and this is what you are receiving at the charger IC mosfets.
              Respectively, the ACDET pin on the charger IC will remain at 0v since no voltage is present at these DCin mosfets as input.
              Then the charger IC remains to enable the battery mosfet only to operate the logic board.
              Remove all power -> meter in resistance mode.
              Check the resistance from the drain of the the 2nd TPC8120 and to the first pin of the first DCin mosfet at the charger.
              We are wanting to know that there are no other components between the USB Type C mosfets and the DCin mosfets. You should read ~0 ohms if measured properly.
              • johnjohnjohnjohn
                • Sep 2019
                • 120
                • france
                #87
                • johnjohnjohnjohn
                  • Sep 2019
                  • 120
                  • france
                  #88
                  from the drain of tpca8120 left one on the pic to the drain of E6 GUD closest to the charger IC : 0Hms
                  • mon2
                    • 14634
                    So we have a fairly accurate idea of this design.
                    The TPC8120 x 2 are the USB Type C mosfets (aka solid state switches) that allow for the external power adapter to enter the logic board.
                    Then the 2 x DCin mosfets at the charger IC accepts this voltage to power the logic board & charge the battery.
                    Should have asked earlier but what is the history of this board ?
                    Any liquid damage ? Just stopped working properly one day ?
                    Have you tested with another battery ?
                    Suspecting that the CYPD4125 controller is sensing if the battery is present or not (in addition to the charger IC which also does the same).
                    If the battery is not detected, the power delivery enables ok. Charger IC receives the voltage @ ACDET and DCin mosfets -> powers the board ok.
                    If the battery IS detected, the power delivery disables the adapter mosfets. Charger IC does not receive the voltage @ ACDET and DCin mosfets remain OFF -> the battery is forced to power the board.
                    On the battery connector picture, there are other wires with different colors. Proceed to measure their voltage to ground as well.
                    Post all readings.
                    • johnjohnjohnjohn
                      • Sep 2019
                      • 120
                      • france
                      #90
                      reading on the battery itself when unplugged black 0V White and blue 0V yellow 3.1V and red 7.96V
                      • johnjohnjohnjohn
                        • Sep 2019
                        • 120
                        • france
                        #91
                        I bought the pc second hand, from an office employee that got it from work. It was already in this state. The board bears no trace of previous work, no flux or liquid damage.
                        • mon2
                          • 14634
                          Remove all power. Meter in resistance mode.
                          Measure the resistance to ground of the white and blue wires.
                          Also measure the resistance to ground of the yellow wire.
                          • johnjohnjohnjohn
                            • Sep 2019
                            • 120
                            • france
                            #93
                            ok, so you mean on battery itself, plugged to nothing ?
                            • mon2
                              • 14634
                              Sorry, remove the battery and no power adapter - more concerned about the resistance to ground of the actual logic board signals.
                              You will measure on the logic board connector where the battery docks.
                              • johnjohnjohnjohn
                                • Sep 2019
                                • 120
                                • france
                                #95
                                ok, so i mesure the resistance to ground of each pins of the logic board battery connector ?
                                • mon2
                                  • 14634
                                  yes.
                                  • johnjohnjohnjohn
                                    • Sep 2019
                                    • 120
                                    • france
                                    #97
                                    black 1 2 3 : 0 Ohms
                                    White 4 and Blue 5 : 56KOhms
                                    Yellow 6 : Infinite
                                    Red 7 8 9 : Infinite
                                    • mon2
                                      • 14634
                                      When the battery is glitched into charging, does the battery charge to the full potential ?
                                      How long does a full charge of the battery last on this unit ?
                                      • johnjohnjohnjohn
                                        • Sep 2019
                                        • 120
                                        • france
                                        #99
                                        yes, it reaches its 100%
                                        According to HWMInfo, it is at 90% health
                                        It lasts I'd say 3 hours, maybe 4. At the time it was review by tech websites, its weak autonomy was pointed out.
                                        The battery is the first thing I checked, it is not buldged at all, and the health status seems legit
                                        • mon2
                                          • 14634
                                          Can you confirm the details of your power adapter ?
                                          Post pics. Concerned if this adapter is suitable to power the logic board and charge the battery.
                                          See here (random search):
                                          https://www.staples.com/hp-45w-usb-c...duct_IM18V8746
                                          This adapter features the use of 20V, yet the voltage is 12v. This may be limited by the firmware inside the CYPD4125 or could be a fault of the adapter.
                                          I think it is worth testing with your Nintendo adapter - if the adapter is not suitable, the power delivery contract will not be negotiated.
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Bauer tool battery pack charging with a HERCULES charger modification
                                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                            05-06-2023, 12:17 PM
