A2159 no power test (no charger)
  • marce002
    • May 2018
    • 316
    • Argentine
    Re: A2159 no power test (no charger)
    Yes mon , 12,26V if fuse is removed , with just 5v from my usb cable standard, although 12,26 seems to be a little low right? seems to be 0,007A draw
    Marcelo J
    • marce002
      • May 2018
      • 316
      • Argentine
      yes I confirm, with just 5v usb standard cable, it is 12,26V at fuse (removed) , and just 0,007A draw
      Marcelo J
      • marce002
        • May 2018
        • 316
        • Argentine
        with fuse soldered back, 0,3v at fuse, and just 0,012A draw
        Marcelo J
        • marce002
          • May 2018
          • 316
          • Argentine
          U4910 is the one that gets hot when 5v is injected at F7000 with fuse ..and 300mah draw.. u4910 seems to be 3.0V MESA.. i have removed it and now seems to be no more short ...of course it does not mean it is the culprit but just to let you know where we are. thnks
          Marcelo J
          • mon2
            • Dec 2019
            • 14086
            After removing the parts that are heating up...what us the new resistance to ground with F7000 removed?
            Since you do see ~12v before the fuse, this confirms that the isl9240 is working as a boost regulator.
            However, the load is too much on this line so the voltage drops. Leave the fuse off for now...do not bypass or bridge it. We need to find the part causing this low resistance. Those parts may need to be replaced. AliExpress is the usual go-to place.
            • marce002
              • May 2018
              • 316
              • Argentine
              #26
              no something got wrong now RES is 11ohm to gnd from removed load part.... put back the IC u4910 and it is also 11ohm... so i should have not energized the board without that u4910 removed maybe.... it still has 12,26v in the other side of fuse... so sad
              Marcelo J
              • piernov
                • Jan 2016
                • 4435
                • France
                #27
                If injecting voltage on a power rail causes a part not connected to it to heat up it should give a clue as to what to look for… and definitely confirm that continuing to inject voltage is a bad idea.
                Also never a good to work on a board worth a few hundred bucks and potentially holding data without even having the correct power supply for it and basic tools.
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  #28
                  yes yes absolutely, i will put this on pause until i have the proper tools... will keep this updated. thanks to all.
                  Marcelo J
                  • Mita99
                    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                    by Mita99
                    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                    04-27-2025, 07:20 PM
                  • khelane
                    test active pfc power with lamp test
                    by khelane
                    Hello
                    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                    Is there a way...
                    06-03-2025, 01:00 AM
                  • DenK
                    Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                    by DenK
                    Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                    1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                    12-06-2024, 01:29 AM
                  • kjchatman
                    HP DA0G3HMB8D0 DOESN'T POWER UP WHILE THE CHARGER IS PLUGGED IN
                    by kjchatman
                    the laptop uses a 200w charger. i can trick the battery to charge by repeatedly unplugging and plugging in the charger until the voltage on the battery terminal goes high enough. The laptop will not power on while the charger is plugged in.. The only thing i see that is strange is the gate on the charging mosfets is 24 volts even though the charger is only 20 volts
                    05-11-2025, 11:40 PM
