MacBook Pro 16" 820-01700 help troubleshoot :(
  • esko1
    • Nov 2015
    • 5
    • Slovenia
    Hi. I have weird problem with macbook pro 16 820-01700. This is the second macbook with the same problem in two mounts. So after powering on macbook it works for few minutes than black screen, fan full speed for 1 second and than restart to apple logo and than again problem repeats. I have already rebelled gpu and reflowed mux chip but that haven't solved problem. No liquid spill, logicboard looks visually intact. Any suggestions? Thank you in advance.
  • mon2
    • Dec 2019
    • 14028
    Re: MacBook Pro 16" 820-01700 help troubleshoot
    Try to boot with a SMC bypass.
    • ugamazing
      • Jun 2013
      • 165
      • usa
      You re-balled the GPU, but only reflowed the MUX? What made you suspect the GPU? Are you sure you re-balled the GPU properly/sufficiently? What made you suspect GPU over CPU? Lot of info needed for this since you've done so much work on the board already.
      • esko1
        • Nov 2015
        • 5
        • Slovenia
        Thank you for reply. In safe mode macbook is working stable, no restart. So I suspect that something has to be wrong with gpu. It can be that GPU IC is defective and need to be replaced, but the symptoms are the same after reballing. I don't know.
        • envym
          MacBook Pro 2018 with Activation Lock
          by envym
          Hi everyone!
          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
          06-27-2025, 08:54 AM
        • tobeend
          Bypass mdm macbook m2 ventura
          by tobeend
          1. RESET MACOS WITH IPSW
          a. Power off MacBook, press and hold the power button to enter Recovery
          b. Open Disk Utility, remove Macintosh HD
          c. Reboot, connect to the network to Activate Mac.
          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
          e. Release the other keys, but keep holding the Power key for another 10 seconds
          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
          05-26-2023, 07:18 AM
        • SarcasticOP
          General question about MacBook power rails for repair.
          by SarcasticOP
          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
          • PPBUS_G3H (12.6V-12.8V)
            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
          • PP3V42_G3H (3.42V)
            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
          • PPVRTC_G3H (3.3V)
            • This
          12-12-2024, 05:50 PM
        • obelix24
          A2941 Macbook air 15” - 5V 0a
          by obelix24
          I’m working on one macbook air 15” m2 that was water damaged.
          keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
          i’ve put macbook in shelf and order new screen so i can fully repair it.
          Now i got the screen and macbook stays at 5v 0a.
          i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
          i don’t have schematics so i don’t know where to start can someone help me?...
          03-27-2025, 01:19 PM
        • Kush679
          MacBook Pro M1 Activate Mac
          by Kush679
          Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
          Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
          06-20-2025, 09:43 AM
