Very strange SPI issue with 820-01521 Board
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Working on an 820-01521 board that we replaced a dead CD3215 on, pretty standard. No issues were found after repairs. We stocked the board and recently pulled it to send to a customer, and noticed a very quirky issue that we've never seen before.
    The only symptom is: When attempting to connect to WiFi pre-boot (i.e. to run AHT or to load Internet Recovery), after selecting the network and when entering the password, the board acts as if the keyboard is inputting characters--i.e. phantom registering--but it's not. The issue ONLY occurs at this time (SPI input presumably, before keyboard switches to a USB device). Once OS is loaded, there are absolutely no issues with keyboard/trackpad or WiFi.
    Things we've already tried:
    1. Have tried 3 different trackpad/cables and 3 known-good keyboards.
    2. Have tried restoring T2 multiple times.
    3. Have tried reinstalling MacOS multiple times.
    4. Have tried 3 entirely-different test assemblies--different LCDs, batteries, audio/IO boards, TouchIDs, USB-C ports, etc--all different and all known-good.
    5. Replaced keyboard/trackpad connector on board, as well as all related SPI controller circuitry for kbd/tpad (U6860/6865).
    At this point, I'm suspecting a possible T2 issue. Before we worried about that, I wanted to see if anyone had any other ideas. This one has been so odd and I'm out of ideas of what else to try. I'm wondering if MAYBE U3000/low-volt USB circuitry could be related, maybe?? But I'd expect issues/symptoms beyond the one we're seeing. Very odd.
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Re: Very strange SPI issue with 820-01521 Board
    To add to the strangeness: The issue persists with keyboard/trackpad totally disconnected from the board. So something very funky going on.
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • Stephen
      A2991 Logic Board issue, 20volts 0 amps help!
      by Stephen
      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
      09-10-2025, 03:16 PM
    • Stephen
      A2991 logic board issue, 20volts 0 amps help!
      by Stephen
      09-10-2025, 03:15 PM
    • notallbad
      TCL 55RP620K power board issue
      by notallbad
      Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
      0% p_dim at 1.65v and a_dim at 1v
      50% p_dim at 3.3v and a_dim at 1.65v
      100% p_dim at 3.3v and a_dim at 2.88v
      Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
      Leds are 2 rows of 15 6v leds.
      On inspection of the power board found diode MBR3200 shorted so replaced with...
      07-12-2025, 05:45 AM
