When I connect to my DC supply with 19.5v I see Unusual readings there like below.
Voltage: 19.5v which is OK.
Current: This one keep changing on every second. most of the time it is 0. (it take 0.00A,0.05A, 0.02A. Its rotating)
When I test Power section I noticed that the first mosfet take 19v but it doesn't out any. Reason is the gate voltage is equal to 0v.
I followed the sections and I noticed that something strange in Charging IC. Here are the values I noticed In my Charging IC.
Model: BQ24725A
According to datasheet of this controller, above voltages are okay to out AC_OK and AC_Drive Signals. But It doesn't out them.
So I guess this IC needs to replace. But I would like to know your thoughts before I touch this IC.
Special: I noticed an Inductor which has low resistance which is 0.4ohms. I don't know what rail it is. But I will try to find out. I marked it on the image.
Model: BQ24725A
Pin 20 (VCC) ----> 19v Seems OK
Pin 6 (AC_Detect) ---->2.59v Seems OK
Pin 12 (SRN) ------> 0.4v Seems OK
 HP - LA-D704P Rev 1.0 No Power Motherboard HELP
