HP - LA-D704P Rev 1.0 No Power Motherboard HELP
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    When I connect to my DC supply with 19.5v I see Unusual readings there like below.
    Voltage: 19.5v which is OK.
    Current: This one keep changing on every second. most of the time it is 0. (it take 0.00A,0.05A, 0.02A. Its rotating)
    When I test Power section I noticed that the first mosfet take 19v but it doesn't out any. Reason is the gate voltage is equal to 0v.
    I followed the sections and I noticed that something strange in Charging IC. Here are the values I noticed In my Charging IC.
    Model: BQ24725A
    Pin 20 (VCC) ----> 19v Seems OK
    Pin 6 (AC_Detect) ---->2.59v Seems OK
    Pin 12 (SRN) ------> 0.4v Seems OK
    According to datasheet of this controller, above voltages are okay to out AC_OK and AC_Drive Signals. But It doesn't out them.
    So I guess this IC needs to replace. But I would like to know your thoughts before I touch this IC.
    Special: I noticed an Inductor which has low resistance which is 0.4ohms. I don't know what rail it is. But I will try to find out. I marked it on the image.
  • mon2
    • Dec 2019
    • 14667
    Re: HP - LA-D704P Rev 1.0 No Power Motherboard HELP
    What is the voltage of charger pin # 4 (ACDRV) ?
    • harshana
      • Aug 2022
      • 216
      • Sri Lanka
      Both ACOK and ACDRV equal to 0v
      • mon2
        • Dec 2019
        • 14667
        Are you measuring these directly at the IC ?
        What is the voltage of the REGN pin #16?
        It will be a good idea to check the voltage on each pin on the charger IC so we can review against the datasheet.
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          Pin 16 also were 0v.
          Im facing a power cut now. will send you the actual readings of other pins as well. I checked all the pins when I dig in to this. as I remember all the pins were 0v except the pins I mentioned above
          • mon2
            • Dec 2019
            • 14667
            confirm the Vcc pin of this charger IC - it must be powered for the REGN to function. The REGN must function to create the boosted GATE voltage required to enable the N-channel mosfets.
            If the VCC pin is ok and receiving the power from the power adapter -> then remove all power. Meter in resistance mode -> check the resistance to ground of the REGN pin.
            Is the REGN pin being loaded down ?
            Also good to check the resistance of the DCIN mosfets to see if they are shorted or not.
            Hints are towards this charger IC being defective since the REGN pin is not showing the ~6 volts.
            • harshana
              • Aug 2022
              • 216
              • Sri Lanka
              pin 16 ———-> 96.3kohms
              My fault. I just checked voltage in pin 16 and I see 6.14v there.
              DCIN mosfets are not shorted
              yes I test directly from the IC pins.
              • harshana
                • Aug 2022
                • 216
                • Sri Lanka
                Here are the actual Voltages of the Controller.
                Pin 1,2,3,5,7,8,9,10,14,15 ------> 0v
                Pin 4 -------> change between 0v and 0.2v (I see its trying to get a value. but not stable.)
                Pin 6 -------> 2.59v
                Pin 11 ------> 0.27v
                Pin 12,13,18 ------> 0.42v
                Pin 16 ------>6.14v
                Pin 17 -----> 5.91v
                Pin 19 ------> 0.17v
                Pin 20 ------> 18.90v
                • mon2
                  • Dec 2019
                  • 14667
                  Remove the series resistor that is between ACDRV (Pin #4) and the target mosfets.
                  Then check the voltage on ACDRV (Pin # 4) again.
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    Now its value is 0.07v
                    • mon2
                      • Dec 2019
                      • 14667
                      Post the voltages on the DCIN mosfets.
                      Remove all power -> post the resistance values of the mosfets as well.
                      • harshana
                        • Aug 2022
                        • 216
                        • Sri Lanka
                        1st Mosfet
                        Pin 1,2,3,4 ------> 0v
                        Pin 5,6,7,8 -------------> 19.26v
                        Drain to Source ----> 9.02kohms
                        Drain to Gate -----> No value
                        Drain to Ground ------> 0.48Mega ohms
                        Source to Gate ----> No value
                        Source to Ground -----> 0.54Mega ohms
                        Gate to Ground ----> No value even in 20M range
                        2nd Mosfet
                        all pins have 0v
                        Drain to Source ----> 73.1kohms
                        Drain to Ground ------> 1ohm
                        Source to Ground -----> 4.14kohms
                        • mon2
                          • Dec 2019
                          • 14667
                          Remove the 2nd mosfet and check if ACDRV returns to an expected value.
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            Now It returns 1v
                            • harshana
                              • Aug 2022
                              • 216
                              • Sri Lanka
                              Also I soldered the resistor back and now I see the 1st mosfet is okay. he pass 19v
                              • mon2
                                • Dec 2019
                                • 14667
                                ok. Concern is with the 2nd mosfet and also why the main rail is showing 1 ohm to ground.
                                That is not good news and may again be a CPU fault.
                                Without the 2nd mosfet (which is now likely to be defective and must be replaced) -> what is the resistance to ground of the main power rail (drain of the 2nd mosfet) ?
                                Maybe, perhaps maybe, you have a bad cap on this line but again could be a bad CPU.
                                Confirm pins 5-6-7-8 of PQB2 resistance to ground.
                                (while I fix my clothes dryer from h*ll - the 3600W heater element fell out of its notches and was heating up the back wall of the dryer - almost burnt my hands - now we know why it took ~4 hours to dry the clothes. The fixture was supposed to heat up the dryer cabin - not the back wall nor burn my hands)
                                • harshana
                                  • Aug 2022
                                  • 216
                                  • Sri Lanka
                                  Still 1ohms.
                                  • mon2
                                    • Dec 2019
                                    • 14667
                                    With a power supply -> dial up 1 volt (or even 0v8) @ 3A or whatever you can.
                                    Inject this voltage onto the drain pins of the removed mosfet so that you can feed onto the main power rail.
                                    Who is heating up? Similar to your last case. With some luck, some capacitor will do the heating which means the capacitor is defective / shorted.
                                    Otherwise, if the CPU, then the CPU is defective.
                                    On this laptop, is the CPU removable? Guessing not and is soldered.
                                    • harshana
                                      • Aug 2022
                                      • 216
                                      • Sri Lanka
                                      CPU isn’t removable. anyway will this cause to damage cpu if cpu rail defective?
                                      • mon2
                                        • Dec 2019
                                        • 14667
                                        Yes if the voltage is too high. This is the reason to keep the voltage down to the minimum so that if there is a leak to the CPU rail, you are only at the safe boundaries of the CPU.
                                        The CPU voltage is often 1v05 or lower but 1v05 is ok.
                                        Personally, use 0v8 but have a 10-20A voltage injector from Sunshine or some brand like that. If you want, can share the full details tomorrow when at the office.
                                        It works well to locate shorted caps. For CPU, often you need to remove the heatsink so you can feel if the CPU is the shorted component.
                                        So what 'may' have happened is that some buck regulator (takes in the high voltage like 19vdc) and supplies a low voltage (like perhaps the Vcore rail @ 1v05) will have external mosfets. External mosfets are used to dissipate heavy currents like the Intel / AMD CPUs which are pigs on current. They can consume hefty current in normal operation.
                                        If the high side mosfet leaks, then the high voltage leaks through to the CPU and kills it.
                                        For such a case, it is too late to repair this unit unless you have a BGA rework station and time. Good BGA stations are very $$. We have a very high end one and it is more expensive than my car. Works very well to remove and replace parts, even larger BGA devices or down to 0.5*0.5mm components. Fully automatic.
                                        Respectively, it is not possible to remove and replace with a standard hot air gun due to the size of the CPU / PCH in a single package. At the very least, underside heating table is required (which is integral to our BGA station).
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
