HP - LA-D704P Rev 1.0 No Power Motherboard HELP
  • Sephir0th
    • Oct 2020
    • 1289
    Re: HP - LA-D704P Rev 1.0 No Power Motherboard HELP
    Are you injecting while the heatsink is mounted? The shorted coil is on the side of the substrate where the PCH, so it's pretty clear what is going on.
    FairRepair on YouTube
    • harshana
      • Aug 2022
      • 216
      • Sri Lanka
      #62
      I removed the heatsink as well
      • Sephir0th
        • Oct 2020
        • 1289
        Well, powering the board with missing components (after DC-IN circuit) wasn't a good idea. I'm to lazy to look into the schematics but to me sounds like a completely shorted PCH not only through the 3.3V but also through the 1.05V rail. If it wasn't so from the beginning, it went while troubleshooting.
        The PCH die which shares the substrate with the CPU die should heat up when injecting 1V 3A in the 1.05V or 3.3V rail.
        Sorry to say that, but the board is gone.
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          #64
          When i inject voltage no one were heated up. Thats the surprising part.
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
