Alienware 15 R3 Motherboard Issues Help Plz!
  • z32KRAzY
    Eager to learn!
    • Aug 2022
    • 37
    Re: Alienware 15 R3 Motherboard Issues Help Plz!
    This is what both the bottom ones are, maybe I'm not finding the right datasheet or something.. That's pq701 and pq708.
    And yeah I see the tiny dimple now that marks pin 1.. That's annoying lol, I was looking for anything else like that I guess I just missed it. My eyes certainly aren't what they used to be.
    • mon2
      • Dec 2019
      • 13936
      See attached.
      The datasheet for these mosfets has been posted in the earlier post.
      • z32KRAzY
        Eager to learn!
        • Aug 2022
        • 37
        Originally posted by mon2
        See attached.
        Okay lol that helps.. I was searching for 4803 mosfet.. Sorry I'm still learning obviously..
        • z32KRAzY
          Eager to learn!
          • Aug 2022
          • 37
          Just to make sure I'm understanding, once I get the bad mosfet out the remaining ones will test high Ohms S-G in circuit? Thanks again! Sorry for all the questions, I just want to understand what I'm doing as much as possible..
          And I took your advice and drew a simple diagram of the area and the pin 1 location. Lesson learned.
          • mon2
            • Dec 2019
            • 13936
            Correct. For your logic board, there are 2 x mosfets that are working together and then follow another 2 x mosfets before the power rail is fed to the logic board.
            As per @Piernov's articles, typically there are only 2 x mosfets (total) but the better designs, like yours, now feature 4 of them.
            However, we believe that at least one of these 4 is defective.
            More so, one the 2 mosfet boards, it is the 2nd mosfet (so it is not the one that is mated directly to the AC adapter) that goes bad. So for this reason, I suggested for you to remove this mosfet. You still have another mosfet on this same leg but @Piernov is suggesting your problem probably is in the first 2 x mosfets.
            We are only trying to nail this down with the least amount of soldering but proceed as you wish.
            Do not place back any of the mosfets till we determine which one is the bad boy.
            After you no longer have the 0 ohm short condition, the last removed mosfet is the mosfet that is the suspect. Confirm it by checking the resistance of the removed mosfet while it is out of the circuit.
            Check again, the resistance between source & drain pins, etc. while the mosfet is on your table. If the resistance is low, it is defective.
            Once you can confirm it, you will need a replacement. We can work on that next. The mosfets are not difficult to source but we often use stores like Digikey. Mouser is another option but shipping to Canada is $20 from them.
            DK will sell to anyone with overnight service @ $8 (shipping) + parts you wish to purchase. Best option. We can guide you once we can 100% confirm the mosfet is defective. Otherwise, you can order from Aliexpress which will be cheaper but the parts will not arrive for another 3-5 weeks.
            • z32KRAzY
              Eager to learn!
              • Aug 2022
              • 37
              Okay thanks for that, it helps to know I'm following.. As luck has it, I have my original (same) motherboard still, I was thinking I would just borrow one from that board if there's no reason I shouldn't? I'm just getting everything prepped again to pull another. Will post when I get a bad one off.
              • z32KRAzY
                Eager to learn!
                • Aug 2022
                • 37
                Alright I pulled pq707, it tested good, so I pulled pq701 next and it tests 3-60 Ohms between source and gate.. And the remaining mosfet (pq708) tests 255K Ohms source to gate. So how difficult are these going to be to solder back if I don't have any paste solder?
                • z32KRAzY
                  Eager to learn!
                  • Aug 2022
                  • 37
                  I pulled one from the donor board from location pq707.. It tests 14M Ohms S - G..
                  • mon2
                    • Dec 2019
                    • 13936
                    Good. You do not need solder paste as there is enough solder remaining on the pads from where these parts were pulled.
                    However, you should have solder flux. You may be ok to proceed without it but flux just makes it easier to solder.
                    Keep the air pressure relatively low so that other nearby parts do not end up in the next province. Enough heat to have liquid solder. Go around in circles from the top side and the part should just sink back onto the pads like before.
                    As you solder each back, wait till the part is cool. Then check the resistance again on the logic board before moving to solder back the next mosfet.
                    • z32KRAzY
                      Eager to learn!
                      • Aug 2022
                      • 37
                      Okay great, yeah I do have flux. And the desoldering braid I have seems to be beyond its best before date also, it doesnt want to suck up solder worth a damn... I'll try just reusing the old solder then. Thanks again!
                      • z32KRAzY
                        Eager to learn!
                        • Aug 2022
                        • 37
                        I got the first one replaced, but it doesn't look like it's lined up as perfectly as it was, should I worry about it it just move on? The S-G is still not shorted and the D-GND isn't shorted, I assume that would mean it's okay? Thx!
                        • z32KRAzY
                          Eager to learn!
                          • Aug 2022
                          • 37
                          Okay last 2 are done also, is there anything else I should check before reassembling to test?
                          • z32KRAzY
                            Eager to learn!
                            • Aug 2022
                            • 37
                            Removed all the kapton and cleaned the board.. Should I just reassemble and cross my fingers at this point? =)
                            • mon2
                              • Dec 2019
                              • 13936
                              The soldering looks fine for these mosfets.
                              The pin pitch is not as delicate as smaller devices so there is some flexibility to solder these down.
                              Before powering up, check the resistance again like before to confirm there is no short.
                              Then power up and check.
                              • z32KRAzY
                                Eager to learn!
                                • Aug 2022
                                • 37
                                Okay yes I already did check and lowest resistance is 255K Ohms source to gate.. I'll cross my fingers and reassemble in that case.. =))
                                • piernov
                                  • Jan 2016
                                  • 4435
                                  • France
                                  #56
                                  Looks like solder did no take properly on the pins. Remove MOSFET, put some fresh leaded solder on the pad, add flux and solder it back with hot air. To make the solder joints look even better, add flux again and go around the pins with a soldering iron.
                                  When the MOSFET is not soldered properly, resistance will be higher and it'll warm up, and if the thermal pad is not soldered properly either the MOSFET will not be able to dissipate the heat to the power plane.
                                  • z32KRAzY
                                    Eager to learn!
                                    • Aug 2022
                                    • 37
                                    I was thinking that could be an issue, I ordered some fresh braid/wick when it comes I'll fix it. In the meantime I'm so happy to report that the battery is charging and the computer seems to be 100% again! =D So I can't tell you all how much I appreciate your guidance, your all just so freakin awesome!! Thank you!!
                                    • z32KRAzY
                                      Eager to learn!
                                      • Aug 2022
                                      • 37
                                      Could one of you guys possibly recommend a part from mouser or digikey that I could order to replace the one I took from my old board? It was labelled B04 N03.. I'll attach a picture of the chip for reference..
                                      • mon2
                                        • Dec 2019
                                        • 13936
                                        https://www.digikey.ca/en/products/d...TR2PBF/2639558
                                        https://www.digikey.ca/en/products/d...4TRPBF/2639551
                                        https://www.digikey.ca/en/products/d...5TRPBF/2639552
                                        • evoman2
                                          Hp z420 motherboard (?) issues
                                          by evoman2
                                          Hello everyone! I have an old hp workstation z420. Xeon E5 1620 v2, 8gb ecc ddr3
                                          Basically, when I plug in the power cable to the power supply, it turns on and off while clicking every time it power cycles. Once I remove the power cable from the supply, it flashes a red light 4 times while beeping for about 10 seconds. I have purchased a new CPU and power supply already, but that hasnt fixed it so I'm convinced it's a motherboard level fault. If anyone has any ideas on what the fault could be, and/or how to diagnose it, that would be highly appreciated. Thanks!
                                          05-09-2025, 07:31 PM
                                        • eduardo11791
                                          ASUS STRIX GL703GE Motherboard Issues
                                          by eduardo11791
                                          Hi, pretty much new here, glad I can be part of this community. I'm new to repairing laptops motherboards (Only previous experience was repairing a Z690I STRIX with a broken trace on the memory slot, and it was a sloppy job but worked)
                                          Bit of background: I'm not new replacing Laptop parts and doing general testing. Bought multiple laptops of the same model since it's easier to repair and got some that I can either switch parts and test.
                                          ASUS STRIX GL703GE-IS74
                                          Motherboard Model: DABKNBMB8D0 Rev D All of them
                                          Issues (Each one on a separate board)...
                                          12-06-2022, 11:41 AM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • paparazzo79
                                          Alienware 17 R3 freezing in games
                                          by paparazzo79
                                          Hi guys.
                                          I own Alienware 17 r3 6820HK GTX 980M.
                                          I purchased it recently tried some gaming (Rise of the Tomb Raider, Serious Sam) and after 10-15.min games freeze, but I could hear audio from game.
                                          Now I am not yet at home, but when it happens I do get separate window error message and will post it later.
                                          Then again there are moments when I could play for like an hour and no errors.
                                          From my experience reading about this issue, this means my GPU is dying, correct?
                                          I installed most recent nVidia drivers.
                                          Temp of GPU while gaming is max 76 C, but usually around...
                                          04-19-2024, 12:07 PM
                                        • amigo744
                                          PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
                                          by amigo744
                                          Hello there,
                                          ps5 cfi-1016a disk console
                                          Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
                                          After the shut down the console boots up normal and then the ps4 game functions without a problem.
                                          ps5 games run allways without any problems after cold boot.
                                          Thats absolutely curious....
                                          I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
                                          That doesen´t help
                                          Furthermore i have opened console and renew liquid metal on gpu.
                                          This all doesn´t...
                                          06-19-2023, 05:02 AM
