Ideapd 5 15ITL05 wont charge battery
  • alfredosn
    • Jun 2016
    • 19
    • México
    Hello friens , i have a Lenovo Ideapd 5 15ITL05 wont charge battery, so i have these escenarys
    laptop with battery and charger plugged.... laptop power on but wont charge battery and no detect the ac adapter
    laptop only with ac adapter plugged .... laptop power on but wont charge battery and obvuisly no detect the battery
    laptop only with the battery plugged .... laptop power on but wont charge battery and obvuisly no detect the ac adapter
    does somebody has a working bios dump for this laptop, the MB is NM-D211 Rev 1.0
  • Sephir0th
    • Oct 2020
    • 1262
    Re: Ideapd 5 15ITL05 wont charge battery
    Start with checking the DCIN mosfets for being internal shorted.
    BIOS request goes into another category here iirc
    FairRepair on YouTube
    • alfredosn
      • Jun 2016
      • 19
      • México
      The laptop and motherboard power on with the adapter, so i dont think this problem is related to DCIN mosfet, you rigth, bios request is in another category
      • Sephir0th
        • Oct 2020
        • 1262
        That's a interesting attitude. Good luck by solving your fault.
        • Stevedb
          Stevedb
          • Feb 2018
          • 623
          • Belgium
          Hi like Sepiroth said check the dcin mosfets if the second mosfet is shorted between drain and source then will pass the 19v and the laptop will work on the adapter bit will not work on battery and will not charge the battery. See the beginner guide from Piernov.
          Regards
          • jared101
            • Mar 2019
            • 10
            • US`
            I just fixed a Lenovo with the same symptoms as yours. It was a bad DCIN mosfet causing the issue
            • techfreak9356
              Vostro 3400 (LA-K033P) won't charge battery, everything else ok
              by techfreak9356
              09-14-2023, 11:10 PM
            • razenxd
              How can I charge that battery pack?
              by razenxd
              it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
              At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
              Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
              Now, I have noticed a few things.
              The "dead" battery, while connected to charger and NOT Charging will...
              12-05-2024, 06:11 AM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
            • Klevjetack
              Charge a L19D3PDA battery externally from the laptop
              by Klevjetack
              Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
              03-05-2024, 07:26 AM
            • dclass-pro
              Latitude 3301 not charge battery
              by dclass-pro
              Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
              I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
              I noticed 2 things:
              1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
              2) if I try to turn it on without the battery...
              05-06-2025, 06:19 AM
