Lenovo Ideapad 320-15IKA NM-B452 not charging battery
  • jared101
    • Mar 2019
    • 10
    • US`
    NM-B452
    Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
    On the BQ24780SRUYR charging ic
    VCC 20V
    SMBUS lines
    SDA 3.3V
    SCL 3.3V
    Current Sensing lines
    ACP/ACN 2.3 ohms
    SRP/SRN 21.2 ohms
    REGEN line 6V
    PHASE .84V with no battery installed(this may be normal)
    PHASE xxV with battery installed voltage is slightly higher than battery voltage.
    Originally the battery was completely drained so I charged it with my DCPS. The machine will work on battery power. When the ac adapter is first plugged in the battery icon in the lower right shows that it is charging and it shows the battery filling up over and over for about 10-20 seconds. Then it stops but still shows that the battery plugged up. I do not get a message saying not charging. Feel free to let me know what I haven't checked. I have not tried a new battery yet because this battery seems okay.
  • tomodachi
    • Apr 2012
    • 603
    • Turkey
    Re: Lenovo Ideapad 320-15IKA NM-B452 not charging battery
    Check to see if DCIN mosfets PQ311 and PQ312 is short or not
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      ACDRV,ACOK,ACDET Voltage??
      • jared101
        • Mar 2019
        • 10
        • US`
        No shorts on DCIN fets
        ACDRV 20.3V. BATDRV Same as battery V
        ACOK 3.27v BATSRC Same as battery V
        ACDET 2.9v TB_STAT .785v
        HIDRV Same as battery V BATPRES .298v
        LODRV 0v PROCHOT .3mV
        BTST 6.85v PMON 10mV
        ILIM .79V IDCHG .398v
        CMPIN .276v IADP 26V
        CMPOUT .520v CMSRC 20V
        • piernov
          • Jan 2016
          • 4437
          • France
          ACDRV 20.3V.
          • jared101
            • Mar 2019
            • 10
            • US`
            Hi piernov. I just reread through your sticky on charging circuits. When i think short I think short to ground. Sorry for the noob mistake. PQ311 is definitely bad
            PQ311
            0 ohm between Drain and source
            170 ohm between Drain and gate
            170 ohm between gate and source
            PQ312
            9Mohm between drain and source
            OL between drain and gate
            OL between source and gate.
            I’m not sure if PQ312 is okay or not. After I have replaced PQ311 what V should I see on ACDRV
            • mon2
              • Dec 2019
              • 14307
              As per the TI datasheet, the gate voltage (ACDRV) should be ~6 volts higher than the source voltage.
              So you should see ~25 volts.
              • jared101
                • Mar 2019
                • 10
                • US`
                I did read that but I just wanted to ask. I’m still new to some of this. Now to locate a replacement that won’t take a month to get here.
                • mon2
                  • Dec 2019
                  • 14307
                  Now to locate a replacement that won't take a month to get here.
                  Aliexpress is not too bad but yes it *may* take longer than sourcing locally.
                  See attached. TI has stock of the part at this time of writing. While you are at it, consider to buy drop in replacement mosfets for the same repair. If TI has them in stock, the part will be great as spares for your parts drawer.
                  I think some datasheets, including this one, are written in a format that only twins can understand. Chargers are a hot (no pun, ok a small pun) topic here.
                  See my post and the excellent reply from the TI engineer here ( a must read ):
                  https://e2e.ti.com/support/power-man...114776#4114776
                  • jared101
                    • Mar 2019
                    • 10
                    • US`
                    Definitely over my head. I think that reply he gave came from the data sheet too. I tried locating that part at www.ti.com but did not see it the first time. I’ll check again later
                    • tomodachi
                      • Apr 2012
                      • 603
                      • Turkey
                      Glad you found the problem.
                      • jared101
                        • Mar 2019
                        • 10
                        • US`
                        Thanks for helping. You were spot on.
                        • jared101
                          • Mar 2019
                          • 10
                          • US`
                          Digikey for the win.
                          • rookieme
                            • Oct 2014
                            • 397
                            • Greece
                            Hello team, I am having same charge battery issues with the same model.
                            The SRN_R line was blown internally at the pcb and the pcb was lifted a bit at that spot.
                            So far I have cut both lines SRN_R & SRP_R just to be sure and connected them by cable to PR317, replaced PR338, PR328 & PU301, checked PQ311 & PQ312.
                            ACDET 2,66V
                            ACOK 3,32V
                            ACDRV 24,11V
                            ILIM 0,84V
                            SDA & SCL 3,33V and connection to kbc & battery
                            HIDRV 7,44V with battery voltage 5,85V or 7,80V with 6,15V [second battery]
                            I have orange flashing led 3 times for as long I have a battery connected.
                            I can find nothing wrong with it, any help will be appreciated.
                            • mon2
                              • Dec 2019
                              • 14307
                              Remove all power and measure the resistance of the current loop but directly at the ic pins for SRN & SRP.
                              • rookieme
                                • Oct 2014
                                • 397
                                • Greece
                                It is 20,16 Ohm
                                • mon2
                                  • Dec 2019
                                  • 14307
                                  Ok resistance.
                                  What is the voltage to ground of BATT_TEMP = pin # 15 (BATPRES#) on the charger IC?
                                  • rookieme
                                    • Oct 2014
                                    • 397
                                    • Greece
                                    It is 3,33V without battery and 0,30V with the battery connected.
                                    • mon2
                                      • Dec 2019
                                      • 14307
                                      What is the voltage to ground of REGN (pin #24 = BQ24780_VDD) ? This should be ~6 volts.
                                      Test with a known good battery. The conditions look ok to charge the battery.
                                      Perhaps the battery is locked.
                                      • rookieme
                                        • Oct 2014
                                        • 397
                                        • Greece
                                        REGN is 6,02V
                                        The fact is that I have a similar model that has same charger [24780s] and can take either 2 cell or 3 cell batteries [currently has 3 cells] so I tried these 2 cell batteries there and they charge [stable orange led].
                                        After I took the working 3 cell battery and tried at the faulty motherboard one just to confirm that it cannot charge it but it does powers on with it.
                                        I'm wondering if bios could cause such issue.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Julian Bailey
                                          HP ProBook 445 G8 Battery not charging
                                          by Julian Bailey
                                          Hi all
                                          We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                          The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                          I have gone around the board with a MM and cant find anything
                                          Windows shows the battery fine,...
                                          10-11-2024, 10:34 AM
                                        • mferna14
                                          Lenovo Carbon X1 Battery not charging
                                          by mferna14
                                          Hi, Working on a Lenovo X1 Carbon 1st Gen (Type 3444) Laptop. Came in for battery problems. Upon testing the battery, I noticed that one of the cells is bursted & has to be replaced. Ordered a Brand New battery. Now it works on battery but does not charge at all. I see in Windows 10 it shows the charging sign & AC power connected but stuck on 79%. I did a press-in switch reset at the botton of the laptop, but did not help. Checked the Voltage on the chip BQ24760RSBR, all seem to be fine. Battery voltages are ok 14.4v but on the battery coil L24, when AC is plugged in I only get 1.8V. Then...
                                          02-24-2023, 05:25 PM
                                        • piernov
                                          Laptop battery charging circuit
                                          by piernov
                                          1. Some theory
                                          1.1. Introduction
                                          Almost every laptop has a charging circuit of some sort, that does a few things:
                                          • Manages switching between AC adapter and battery power
                                          • Manages battery charging and generates power rail to charge battery
                                          There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                          • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                          • Narrow VDC (NVDC)
                                          Texas instrument has a nice overview of these technologies with some more details at https:...
                                          11-15-2020, 01:31 PM
                                        • code share
                                          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                          by code share
                                          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                          Here's what I've tried so far:
                                          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                          • Booted successfully on AC power only with the battery disconnected
                                          • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                          • Battery
                                          04-21-2025, 12:50 PM
