Lenovo Carbon X1 Battery not charging
  • mferna14
    • Jun 2018
    • 1038
    Hi, Working on a Lenovo X1 Carbon 1st Gen (Type 3444) Laptop. Came in for battery problems. Upon testing the battery, I noticed that one of the cells is bursted & has to be replaced. Ordered a Brand New battery. Now it works on battery but does not charge at all. I see in Windows 10 it shows the charging sign & AC power connected but stuck on 79%. I did a press-in switch reset at the botton of the laptop, but did not help. Checked the Voltage on the chip BQ24760RSBR, all seem to be fine. Battery voltages are ok 14.4v but on the battery coil L24, when AC is plugged in I only get 1.8V. Then I checked abnormal behavior on the battery connector. Data/clock both 3.3v. But on the M_TEMP pin (pin 6) there is 2.1v, where as this should be LOW (ZERO) when the battery & AC Power is connected. When I remove the battery terminal, Pin 6 is back to 3.3v. I check all the resistences, all are fine. This signal comes directly from I/O Chip U36. Is there a way I can disable this & battery temp rail to start battery charging again. I have uploaded the Schematic for review. Any tips/help will be greatly appreciated. Thanks in advance.
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Lenovo Carbon X1 Battery not charging
    Did you check the second mosfet it is not shorted do you ad det?
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • jared101
      Lenovo Ideapad 320-15IKA NM-B452 not charging battery
      by jared101
      NM-B452
      Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
      On the BQ24780SRUYR charging ic
      VCC 20V
      SMBUS lines
      SDA 3.3V
      SCL 3.3V
      Current Sensing lines
      ACP/ACN 2.3 ohms
      SRP/SRN 21.2 ohms
      REGEN line 6V
      PHASE .84V with no battery installed(this may be normal)
      08-03-2022, 09:19 PM
    • Julian Bailey
      HP ProBook 445 G8 Battery not charging
      by Julian Bailey
      Hi all
      We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
      The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
      I have gone around the board with a MM and cant find anything
      Windows shows the battery fine,...
      10-11-2024, 10:34 AM
    • piernov
      Laptop battery charging circuit
      by piernov
      1. Some theory
      1.1. Introduction
      Almost every laptop has a charging circuit of some sort, that does a few things:
      • Manages switching between AC adapter and battery power
      • Manages battery charging and generates power rail to charge battery
      There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
      • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
      • Narrow VDC (NVDC)
      Texas instrument has a nice overview of these technologies with some more details at https:...
      11-15-2020, 01:31 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
