LA-C501P No ACDRV??
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: LA-C501P No ACDRV??
    Originally posted by mon2
    From the voltage on pin # 20 (VCC), the charger IC @ PUB01 is not being powered.
    See attached.
    Review the parts that have been highlighted.
    The dual diode and series resistor must be present and working to allow for the raw ~19v to reach this charger IC to power up this logic board.
    On a normal logic board, pin #20 should be ~19 volts. Confirm it and update this thread.
    Start with the voltage check on each pin of PDB1 (dual diode). Pin #1 should be about the same as the adapter voltage.
    My bad, I attached wrong schematic. Board in NM-B731. I couldn't find schematic but boardview attached.
    • mon2
      • Dec 2019
      • 14198
      See attached. It is the same flow. Check the voltages at each of the arrow points.
      • dspok
        • Jan 2014
        • 553
        • Nepal
        Pin28 has 19v. PD302 and PR314 is too.
        • 3mar
          • May 2021
          • 3
          • jordan
          i've fixed the same problem by replacing those component , the small capacitor was shorted and the small mosfet risistance was almost zero
          • reefcool
            • Jan 2014
            • indonesia
            i've fixed same problem by change source PR311 from N1 to VIN
            • mon2
              • Dec 2019
              • 14198
              Interesting that this worked and thanks for sharing but the bypass should not be necessary if the mated parts are working properly. That is, the original board should function with the original wiring diagram.
              • fredyjbi
                • Feb 2021
                • 144
                • malaysia
                #27
                do you have a 19v csmrc on pin 3?
                Measure all voltages on the charging IC
                - cmsr 19v
                - vin 19v
                - acdet 2.6v
                - regn 6v
                • zaurus81
                  Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
                  by zaurus81
                  Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
                  When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
                  11-21-2024, 05:04 AM
                • BlackScreen_22
                  Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                  by BlackScreen_22
                  Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                  Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                  I had no problems connecting mosfets and capacitors,...
                  08-27-2024, 12:46 PM
                • kotel studios
                  Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                  by kotel studios
                  Finally got time to fix this board up.
                  At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                  Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                  04-22-2025, 05:08 AM
                • zaurus81
                  HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                  by zaurus81
                  Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                  WITHOUT BATTERY WITH BATTERY
                  PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                  05-06-2025, 09:48 AM
                • flerre
                  Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                  by flerre
                  Hi!
                  Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                  No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                  So, could I safely assume all of these 3 mosfets are...
                  03-13-2022, 12:14 PM
