820-00850 question about CD3215
  • Francisco.s
    • 686
    • Spain
    Hi, have a 820-00850 board that someone remove one of the four CD3215.
    It is stuck at 5v 0.24A in ports that are "working".
    I am confusing with CD3215.
    I dont know if this board needs all CD3215 soldered or it should work with only 3 of them.
    Thanks in advance,
  • mon2
    • 14012
    Re: 820-00850 question about CD3215
    All CD3215 need to be present and working.
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    • Francisco.s
      • 686
      • Spain
      Hi moon2, I've ordered a new one.
      I hope there are no more hidden problems in this board, but nobody removes this kind of chips for fun.
      Thanks for your help, I will update soon.
      • DanielDacko
        • Mar 2015
        • 325
        • Macedonia
        It would be wise to check for shorts on the board where CD3215 is removed, I know it's PITA, but better to check than do additional troubleshooting and face possible problems after soldering that chip. And make sure that you are ordering same chip as the other three on the board, like revision etc.
        I don't provide help for people using CH341A and a clip.
        • Francisco.s
          • 686
          • Spain
          Hi DanielDacko, I have read an take good notes and advises from logi.wiki:
          https://logi.wiki/index.php/USB-C_Pinout
          I really appreciate all your help.
          Thanks.
          • Francisco.s
            • 686
            • Spain
            Hi, a new CD3215 is soldered and remains stuck at 5v 0.24A, as before.
            All voltages for T2 chip are present.
            It seems to me that data on U4770 is corrupted, so I have programmed new data into U4770 and now it is stuck at 5v but only 0.1 amp.
            I don't know if new data is 100% compatible. (if I put old data into flash chip it returns to 5v 0.24A)
            I would like to test a fully functional dump, but don't know if this board can work with dump from a different board.
            Any advice?
            • mon2
              • 14012
              What are the markings of the original CD3215 that was onboard ?
              What are the markings of the replacement CD3215 ?
              Check the LDO voltages of each of the CD3215 devices on your logic board. If even a single CD3215 is not working, the 20V will not be negotiated.
              • Francisco.s
                • 686
                • Spain
                Hi moon2, the CD3215 is a CD3215C00 and has been replaced for a new one with same type.
                I will check the LDO voltages of each of the CD3215 and post the readings.
                • mon2
                  • 14012
                  Hoping that you have sourced from a reliable vendor or better yet, taken from a donor board and reballed ?
                  As many have posted here and other boards, these controllers are rare and difficult to source a valid component.
                  • Francisco.s
                    • 686
                    • Spain
                    Hi, some more news.
                    All voltages in all CD3215 are correct, except PP1V1_UPC_TB_LDO_BMC in UB400.
                    There are 3.3 volts instead of 1,1. (but there is no short with any 3.3 volts source)
                    Seems that have to replace another chip, at least one more.
                    Thanks for your advice.
                    • Cemal Odabasioglu
                      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                      by Cemal Odabasioglu
                      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                      Observations...
                      01-14-2025, 03:54 PM
                    • Stephen
                      A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
                      by Stephen
                      As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
                      5.16V .47amp
                      5.16V .47amp
                      5.16V .47amp
                      5.16V .04amp (this guy is the issue) (U3200)
                      So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
                      11-27-2023, 03:57 PM
                    • JoeDeeS
                      Macbook Pro 15" 2019 (A1990, 820-01814) CD3215 shenanigans
                      by JoeDeeS
                      Hi! Thanks in advance for taking your time reading this / helping me out .
                      I have this MB Pro which had a defective CD3215C00Z. After replacing that one, I figured out that I needed to replace the other one as well since I only had CD3215C00 chips (without the Z at the end).
                      Now the funny thing is where I replaced both the CD3215 chips, it takes 5V ~.32A and the other side that I didn't touch now takes 20V ~.45A (then drops down to .03A).
                      Do I need to replace the 2 CD3215 chips that I didn't touch as well? Feels so counterintuitive so I'm having...
                      01-20-2023, 06:14 AM
                    • powerblackout
                      820-00840-A CD3215 short
                      by powerblackout
                      Is the CD3215 chip bad if it has pp3v3_upc_xb_ldo at 2.6v and 5.5ohm resistance? I removed C3208 and the ROM chip and the short did not go away. Just checking before I remove the CD3215.
                      Meter shows board is pulling 5V 330mA
                      01-19-2022, 03:30 PM
                    • ahoonid
                      A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
                      by ahoonid
                      Hi everyone.
                      I have MacBook Pro A1708 with a confusing issue.
                      The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
                      Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
                      I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
                      The initial issue however remains.
                      No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad...
                      05-10-2025, 04:19 PM
