Macbook Pro 15" 2019 (A1990, 820-01814) CD3215 shenanigans
  • JoeDeeS
    • Dec 2021
    • 3
    • Netherlands
    Hi! Thanks in advance for taking your time reading this / helping me out .
    I have this MB Pro which had a defective CD3215C00Z. After replacing that one, I figured out that I needed to replace the other one as well since I only had CD3215C00 chips (without the Z at the end).
    Now the funny thing is where I replaced both the CD3215 chips, it takes 5V ~.32A and the other side that I didn't touch now takes 20V ~.45A (then drops down to .03A).
    Do I need to replace the 2 CD3215 chips that I didn't touch as well? Feels so counterintuitive so I'm having serious doubts...
    Any tips or advice is very much appreciated! <3
  • mon2
    • Dec 2019
    • 14213
    Re: Macbook Pro 15" 2019 (A1990, 820-01814) CD3215 shenanigans
    https://boards.rossmanngroup.com/thr...battery.59438/
    • JoeDeeS
      • Dec 2021
      • 3
      • Netherlands
      So the 2 CD3215's that I placed could both be just bad? That would be hilarious...
      It takes 5v on one side and 20v on the other side with or without battery connected, should've mentioned that.
      • Cemal Odabasioglu
        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
        by Cemal Odabasioglu
        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
        Observations...
        01-14-2025, 03:54 PM
      • alfredodinolfo
        MacBook Pro 2019 (A1990)
        by alfredodinolfo
        mb code:820-01827-A;
        sn:C02Z349ALVDR;
        i9 32GB Ram 1TB
        Hi, I found short on one of 6 black nand (total 1TB).
        i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
        I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
        macbook with A2141 configuration run on recovery but don't complete it.​
        anyone can help me?
        05-26-2025, 09:27 AM
      • robka
        MacBook Pro 2018 - A1990 Dead - not charging - only 5V
        by robka
        my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
        I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
        The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
        After that the Macbook was dead. It isn't charging anymore.
        The USB-C Port where the charger was plugged is burned. Also The Cable and the...
        03-02-2024, 02:58 PM
      • DATATECH85
        Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
        by DATATECH85
        I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
        The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
        I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
        However, I can't work out exactly why I don't have the PPBUS_G3H rail.
        Here are the values...
        07-24-2024, 06:34 AM
      • Cameron Kajohn
        A1990 MacBook no power help
        by Cameron Kajohn
        I have a a1990 2018 15 inch MacBook Pro that will not power on.
        I have replaced the pch bga chip because it was heating up under my thermal camera.
        I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
        the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
        I have also noticed L7030 gets extremely hot yet...
        01-24-2024, 12:00 AM
