Macbook Pro 2020 Touch Bar A2289 Ambient sensor and camera not working
  • kuba2102
    • Jan 2020
    • 41
    • Scotland
    Hi everyone. I have this laptop after water damage. The main board wasn't really affected apart from a slight residue but components seem unharmed, but trackpad was very corroded and had to replace a few components. The problem is that the ALS ambient light sensor isn't working as well as camera. Sometimes even my screen image goes blank with backlight on and I have to close the lid and reopen it. I believe there is some issue with communication as
    MIPI_FTCAM_DATA_P,
    MIPI_FTCAM_DATA_N,
    MIPI_FTCAM_CLK_P,
    MIPI_FTCAM_CLK_N,
    They show 0V all the time. The I2C_FTCAM_SDA_R and I2C_FTCAM_SCL_R have 1.8V Also when I go to System information the APPLE T2 BUS doesn't have any serial numbers apart from Apple Internal Keyboard / Trackpad, rest are all zeros not sure if that's was supposed to be or not.
    I also had to reflow the LCD board as the screen wouldn't turn on at all and I noticed when I heat it up slightly it starts to work. Where or what should I be looking at?
  • mon2
    • Dec 2019
    • 14182
    Re: Macbook Pro 2020 Touch Bar A2289 Ambient sensor and camera not working
    See attached.
    There is a security MUX IC @ U8502.
    Confirm the voltage and the ENABLE pin # 11 voltages.
    Consider to flux and reflow this IC if you suspect liquid hit this area.
    • kuba2102
      • Jan 2020
      • 41
      • Scotland
      That's the IC I mentioned. Pin #11 goes straight to U6650 so no way of measuring it unless I take the IC OFF. The I2C_FTCAM_DSBL_SDA #13 and I2C_FTCAM_DSBL_SCL #12 both have 1.8V. I did reflow this IC but probably gonna try removing it completely.
      • mon2
        • Dec 2019
        • 14182
        The Silego part is a DFN package and pin 12 is a corner pin.
        Sometimes, you can see a bit of solder from the SMD pad - can you meter probe pin #12 ?
        Do you have voltages on the MIPI pins on the other side of the MUX ?
        The MIPI pins will only be active after the MIPI CSI camera is enabled. The CSI interface will require the presence of the data & clock lines in addition to the usual power & ground rails.
        Confirm that the inductor / EMI filters @ L8502 & L8503 are in tact.
        What is the voltage of PP5V_G3S_ALSCAM (pin # 46 of J8500) ?
        Do you see a voltage on the I2C_FTCAM_ISOL_SCL / SDA pins ?
        The actual MUX may need to be replaced.
        • kuba2102
          • Jan 2020
          • 41
          • Scotland
          Originally posted by kuba2102
          MIPI_FTCAM_DATA_P,
          MIPI_FTCAM_DATA_N,
          MIPI_FTCAM_CLK_P,
          MIPI_FTCAM_CLK_N,
          If that's the MIPI you are asking for then no they all show 0V,
          I2C_FTCAM_SDA_R 1.8V
          I2C_FTCAM_SCL_R 1.8V
          PP5V_G3S_ALSCAM has 3.3V
          U6650 pin 12 has 1.8V
          • mon2
            • Dec 2019
            • 14182
            Sorry - should have been more clear.
            Can you measure to see if there are any voltages between the MUX & the J8500 connector pins for the MIPI CSI camera ?
            Specifically, these are the following:
            MIPI_FTCAM_DATA_ISOL_N and also check MIPI_FTCAM_DATA_ISOL_FILT_CONN_N
            and the rest of the MIPI lines in the same way.
            If even a single MIPI line is damaged, the camera will not work.
            The voltage of the 'S' pin #11 on the mux is required to understand in which side the mux is steering the logic. Perhaps you can see the trace under the black solder mask that can be very very gently scraped to allow for a probe check ?
            • kuba2102
              • Jan 2020
              • 41
              • Scotland
              MIPI_FTCAM_DATA_ISOL_N. 0V
              MIPI_FTCAM_DATA_ISOL_FILT_CONN_N 0V
              MIPI_FTCAM_DATA_ISOL_P 0V
              MIPI_FTCAM_DATA_ISOL_FILT_CONN_P 0V
              U6650 pin 12 to pin 11 U8502 has 1.8V
              I have solid connection from MIPI filters to the ribbon connecting the LCD. Perhaps The LCD board part could be damaged?
              • kuba2102
                • Jan 2020
                • 41
                • Scotland
                SOLVED: Macbook Pro 2020 Touch Bar A2289 Ambient sensor and camera not working
                Okay after double checking the LCD flex it turned out that PP5V_G3S_ALSCAM line was missing (burned out) i run a short lead for test and the camera and light sensor started working for few minutes but now the line seems to be shorted..
                • mon2
                  • Dec 2019
                  • 14182
                  Review the inductor that is on the same line in series of the PP5V_G3S_ALSCAM and the connector.
                  Is it still in tact or did it get damaged? The part can only support so much current.
                  • kuba2102
                    • Jan 2020
                    • 41
                    • Scotland
                    Okay I managed it finally. It was my mistake with the short. Anyway thanks a lot for bunch of help from you it definitely helped me moving on. All the best
                    • VRauza
                      • Apr 2015
                      • 9
                      • Latvija
                      I have similar problem, but in my case the connector on display board has corroded and broken pins. Can anyone suggest the type / name of the connector or where to buy it? It looks the same as on A1708 / A1706 display except that on those this type connector is on the cable side not on the display board.
                      • mon2
                        • Dec 2019
                        • 14182
                        Yes, working on a MIPI DSI design and took a while but found the proper names.
                        These are called mezzanine connectors and they do vary in their pin-to-pin pitch. Some are 0.35mm while common are 0.40mm.
                        The height appears to be common. Molex is one vendor but there are tons in Asia since they are making their phone for brand X, Y and Z.
                        How soon do you require the part ? The schematic should reference likely the MOLEX version.
                        What is the connector reference for this component ?
                        See here for starters - again, need to know the pin-pitch; then review if you require the MALE or FEMALE version of this connector.
                        https://www.mouser.ca/ProductDetail/...hoC6ucQAvD_BwE
                        I believe that you require a 20 pin connector where 18 are for signal + 2 for the outside ground tabs but let us confirm this with the schematics.
                        • VRauza
                          • Apr 2015
                          • 9
                          • Latvija
                          It looks slightly different from the one in your link. Size of it is approximately 5.1x2x0.7mm, pin spacing is 0.35mm. It is a 20pin connector where 16pin are for signal and one in each corner is ground. I believe it is female connector (Receptacle). I am not sure there is a schematic for it as the part is on the display T-Con board.
                          • mon2
                            • Dec 2019
                            • 14182
                            I believe this is your part...
                            0.35mm pitch, 16 contacts (8 per side), receptacle
                            Hirose is one vendor of these
                            Select the 16 pin version of the receptacle and compare the dimensions. Mouser or Digikey should have these.
                            https://www.mouser.com/ProductDetail...88j4CKVQ%3D%3D
                            * Link to the 16 pin version
                            Mouser has these in stock if in a rush.
                            If not in a rush, you can buy them at a lower cost in Asia but will take a few weeks for delivery.
                            See attached for the datasheet.
                            • VRauza
                              • Apr 2015
                              • 9
                              • Latvija
                              None of those look close to what I need, I have searched the mouser page with no luck. All look similar but not the same. Here is picture of replacement cables for repairing A1706 displays which suffer the flexgate / stagelight issue. The one on the right looks exactly the same as on A2289 screen board and the one on the left look like counterpart on the camera / sensor cable. Could buy these and transfer but that would be a pain to remove it from cable without damaging.
                              • mon2
                                • Dec 2019
                                • 14182
                                You will not be able to salvage the connector from a donor flex cable without deforming the plastic like a chucky-doll.
                                See attached.
                                What part does not match ? Source a few of both the male & female connectors and test their fit to move on.
                                • VRauza
                                  • Apr 2015
                                  • 9
                                  • Latvija
                                  Ordered the connector but it did not fit as I already thought - could not connect it with the cable, it seem to have slightly thicker center plastic and wouldn't fit on. So still looking to find the right connector.
                                  • mon2
                                    • Dec 2019
                                    • 14182
                                    That really sucks...Dyson style.
                                    Go with your original plan to buy the extension cable that may be a good fit and use the following tool to safely remove the connectors. Do not use hot air. Lots of flux and patience.
                                    US $1.49 50%OFF | Mini Ironing Heating Table Soldering Iron Tip For JBC 210 UD-1200 Sugon T26 Soldering Station IC Reballing Flex Cable Repair
                                    https://a.aliexpress.com/_mMdZcJq
                                    Update this thread with your progress.
                                    • mon2
                                      • Dec 2019
                                      • 14182
                                      https://www.aliexpress.com/wholesale...psort=1&page=1
                                      • nelusab
                                        • Aug 2022
                                        • 27
                                        • România
                                        Hi, would you be so kind and share with us how you solved the problem?
                                        I have the same issue with an A2289, facetime camera, ALS sensor and keyboard backlight doesn't work
                                        Thanks!
                                        • Gcnewbie
                                          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                          by Gcnewbie
                                          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                          I opened the...
                                          03-29-2024, 06:55 AM
                                        • baglaivlad
                                          MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                                          by baglaivlad
                                          Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                                          Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                                          01-09-2024, 09:55 PM
                                        • hummel
                                          Dell Liatitude E7440 - ambient thermal sensor
                                          by hummel
                                          I need help finding the thermistor/sensor responsible for ambient temp. detection in E7440. The laptop randomly powers off with thermal event "ambient thermal sensor -148*C". I have schematics and board view but unable to determine which component is responsible for sensing the ambient temp. I simlpy don't understand how it work from the schematic below:
                                          Could somebody more experienced help?
                                          Schematics and board view attached.
                                          https://www.badcaps.net/forum/troubl...heory/troubles...
                                          11-23-2023, 12:14 PM
                                        • veedo
                                          Apple Macbook Pro A2338 EMC8162 lid sensor doesn't work
                                          by veedo
                                          I have an Macbook Pro A2338 after small liquid damage, all working fine but keyboard was sticky so I have replaced palmrest for genuine second hand and now lid sensor doesn't recognize when I'm closing the lid. Display is always on, can't find sensor for that model, can someone explain my how does it work, where that flex is if there is any.
                                          Maybe that the motherboard issue, not sure where to start.
                                          Thank You
                                          03-03-2025, 02:34 PM
                                        • obelix24
                                          Macbook Air 2020 (a2179) - touch id not working
                                          by obelix24
                                          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                          02-09-2025, 12:57 PM
