MacBook Pro 15" A1707, 2016 - No Display and Touch Bar
  • Hauke
    • Jan 2017
    • 78
    Hi, I am asking for a little troubleshooting advice.
    The laptop seems to boot up fine. Caps lock is working, the touch pad has haptic feedback, and even the "charger plugged"-sound is present.
    Power consumption is about 15-30W at boot and idles at about 20W.
    Unfortunately, the display and the touch bar are completely black (No signal and no backlight).
    I don't get a signal on an external USB-C display either. Also not in safe mode.
    I noticed that only the left fan (from the bottom side, hinge on top) seems to spin up. I think this might be the CPU fan.
    I have not worked on the motherboard so far.
    Is the touch bar linked to the GPU?
    Has anyone experienced this issue so far and has some advice?
    Thank you very much!
    Hauke
  • reformatt
    • Feb 2020
    • 1556
    Touchbar will only work once it's booted into MAC OS. I wouldn't bother with that till you establish why the display isn't working. It should work on USB-C with the lid shut in clamshell mode at least.
    Display could be dead, or liquid damage in the connector from motherboard to the display (very common issue). That usually destroys the display MUX IC, but unlike the 13" models, this protects the CPU display data lines from being damaged.
    • MacbobH
      MacBook Pro 2016 non Touch Bar 820-00239-09 schematics and board views
      by MacbobH
      Has anyone have schematics and board views for Apple Logic board # 820-00239-09? Thanks!
      09-18-2025, 01:13 PM
    • CG_Dionysos
      MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
      by CG_Dionysos
      I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
      • Model: A1707
      • 15-inch, Mid 2017
      • 3.1 GHz Core i7
      • 16 GB RAM
      • Radeon Pro 560
      • 1 TB SSD
      • Board number: 820-00928-A
      I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
      Thanks in advance!
      Greetings from Germany...
      09-16-2025, 06:43 AM
    • leonemax81
      Macbook a1707 820-00281 Battery no Power
      by leonemax81
      Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
      08-23-2024, 09:24 AM
    • PACh
      Macbook Pro 2016 A1707 820-00281-A not booting
      by PACh
      Hi, I got the macbook pro 2016 820-00281-A that doesnt boot, I checked almost all rails and they are present, didnt find any short and the amp sequence looks ok but doesnt boot. trackpad enabled, keyboard shift key light not present, when I insert a usb stick its light turns on for a sec. but then no activity. with display disconnected and connected to external monitor same problem. I reflashed the bios with a clean me bin that I downloaded from this forum no difference.
      L7211, L7221, L7231 on boot: 1.112 then 0.700 A
      PCH and other chips get hot but not really hot (please...
      01-09-2023, 09:28 AM
    • jesi
      MacBook Pro 820-00281-A A1707 macbook
      by jesi
      hi all techs
      require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
      adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
      update:
      when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
      08-23-2025, 02:35 PM
