Macbook A1708 EMC3164 battery not detected laptop on when power cable in
  • salim5566
    • Jul 2022
    • 19
    • New Zealand
    HI everyone i have strange problem i have macbook A1708 battery not detected
    i have change new battery still same, when i plug charger in to laptop it can turn on soon as i take out cable macbook turn off. anyone knows how do i solve this problem?
    thanks
  • mon2
    • Dec 2019
    • 14659
    Re: Macbook A1708 EMC3164 battery not detected laptop on when power cable in
    Measure the voltage on each pin of the battery connector and post the measurements.
    • salim5566
      • Jul 2022
      • 19
      • New Zealand
      Hi thanks for quick reply i just want to know battery flex cud be the problem?
      or measure the just other battery pin?
      • mon2
        • Dec 2019
        • 14659
        We are checking the voltage to confirm if the I2C / SMBUS interface lines are ok or if they are strapped. This can halt battery detection / charging.
        • salim5566
          • Jul 2022
          • 19
          • New Zealand
          Thanks mate for all your help really appreciated
          • mon2
            • Dec 2019
            • 14659
            You are quite welcome.
            To future readers, the fault was the dual ESD diode on the battery pack, D6950.
            One diode inside the package was fine with a ~3volt reading.
            The other diode was at 0volts. Removal of this defective diode restored the SMBUS communication (2 lines) with the battery pack.
            Moving forward, the part should be replaced to protect the same lines in the future.
            Source the part from a donor board or AliExpress.
            • mon2
              • Dec 2019
              • 14659
              Datasheet for the part @ D6950 is attached.
              You can purchase these from any distributor of SEMTECH branded parts.
              They are available here:
              (suggest to buy more than you need as these are very very small devices and can easily be lost in the application or rework of the component onto the circuit board)
              https://lcsc.com/product-detail/ESD-...T_C512374.html
              https://www.digikey.com/en/products/...2T-TNT/5118675
              https://www.findchips.com/search/RCL...8aAlBVEALw_wcB
              • tommy97
                Macbook A1708 battery not detected
                by tommy97
                Hi guys, i have weird problem with A1708, laptop does not detect battery, currently I'm using tested new battery, laptop works on it but does not show any details such as percentage, cycle counts etc. and works on it only for like 1-2 minutes with battery cross icon.
                I've tried new battery flex, no change.
                PPBUS_G3H 10.9v on battery
                D6950 - tested fine (replaced also just in case, no change)
                R5381 - 3.3V (2kOhm)
                R5380 - 3.3V (2kOhm)
                R6950 - 10kOhm - 0.08v or 0 (Checked path and fine with connector)
                On battery data connector...
                07-14-2023, 03:32 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • platinumsteel
                Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
                by platinumsteel
                Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
                03-03-2023, 10:17 AM
              • mrkmpn
                Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                by mrkmpn
                Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                03-13-2024, 01:54 PM
              • gboone
                820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                by gboone
                Hi, I was given this laptop by my uncle who said:
                • It would occasionally shutdown if not plugged in
                • battery had been replaced
                • touchbar would "strobe"
                I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                BUT
                When powered off, it would at some point have a...
                01-27-2025, 09:12 AM
