LENOVO 100-15ibd NM-A681 Doesn't detect battery
  • misha97123
    • Feb 2021
    • 36
    • Qazaqstan
    Hello everyone I ask for your help with this laptop already honestly don't know what to do...
    The problem is that the battery didn't charge, or rather, it wasn't even visible, I had the same 100-15ibd, I took the battery from there and connected it, but the problem remained, I already put its battery in a working 100-15ibd and immediately started charging, then I changed the 8682L pu911 charger chip and that didn't help, after I flashed the BIOS from the site and firmware for the EC 128kb from there, but it didn't work ...
    then I changed ite8586e, the problem remained that the battery is not detected and is not charging ...
    But there is such a trick if you just connect a charged battery but the board does not start, but if you connect the power supply, the board turns on and if you immediately turn off the power supply, then the board continues to work from the battery ... but it also does not charge, but it works from it if only at first the board is turned on from the power supply and disconnect it, it continues to work from the battery... I decided to change the charging mosfets pq311 and pq309 but also nothing works, please help me solve this problem ... thanks.
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: LENOVO 100-15ibd NM-A681 Doesn't detect battery
    Post the schematic that you are working with.
    Post the voltage of the charging IC.
    Post the voltages of the 2 first mosfets
    • piernov
      • Jan 2016
      • 4439
      • France
      https://www.badcaps.net/forum/showthread.php?t=90356
      2.2.2. Battery not detected
      Issue on charging circuit SMBUS.
      Check voltage and diode mode to ground on charging circuit SMBUS SDA and SCL lines
      • misha97123
        • Feb 2021
        • 36
        • Qazaqstan
        EC_SMB_CK1=2.398v-2.598v, EC_SMB_DA1= 3.3v with only adapter power.
        EC_SMB_CK1=0.026v, EC_SMB_DA1= 3.3v with only battery.
        • mon2
          • Dec 2019
          • 14668
          Remove all power. Meter in resistance mode.
          Check the resistance across the mosfet pins on the known good logic board.
          Compare the measurements of the same mosfet on the defective logic board.
          Review for the dc in mosfets. Most likely there is a fault in this area.
          • piernov
            • Jan 2016
            • 4439
            • France
            • misha97123
              • Feb 2021
              • 36
              • Qazaqstan
              PQ301 PQ302 Good I tested them on gates 4.80v as well on a good board... The problem is not the DC input mosfets.The problem is that EC_SMB_CK1=2.398v-2.598v should be 3.3v but it is low than needed.
              • misha97123
                • Feb 2021
                • 36
                • Qazaqstan
                Originally posted by piernov
                Charger chip 8682L pin10SCL=EC_SMB_CK1=2.398v-2.598v, pin11SDA=EC_SMB_DA1= 3.3v
                with only adapter
                • mon2
                  • Dec 2019
                  • 14668
                  Your last post are voltage checks - they are not in DIODE mode.
                  Place meter in DIODE mode.
                  Red lead (yes RED) to GROUND.
                  Black lead to the pin to test. Confirm the DIODE mode readings of the SMBUS (I2C) interface lines (SDA & SCL).
                  Post your measurements.
                  • misha97123
                    • Feb 2021
                    • 36
                    • Qazaqstan
                    Diode mode on photo
                    about pin 10 scl with adapter jumps every 2-3sec 0.300-0.500 diode mode and voltage jumps 2.4v-2.6v
                    • mon2
                      • Dec 2019
                      • 14668
                      DIODE mode = measured always without power.
                      RESISTANCE mode = measured always without power.
                      • misha97123
                        • Feb 2021
                        • 36
                        • Qazaqstan
                        The photo shows measurements without power.
                        I changed another Ite8586e but the problem remained, the laptop works if you connect the battery and the adapter the laptop turns on and immediately disconnect the adapter, then the laptop continues on the battery but does not see and does not charge.
                        • misha97123
                          • Feb 2021
                          • 36
                          • Qazaqstan
                          This
                          • mon2
                            • Dec 2019
                            • 14668
                            Still need to review the DC-in mosfets.
                            Check the resistance across the mosfet pins to check if it is defective.
                            Source (1-2-3) & Drain (5-6-7-8)
                            Source (1-2-3) & Gate (4)
                            Gate (4) & Drain (5-6-7-8)
                            Post the above readings (and the meter scale) for PQ301 and then again for the next mosfet PQ302 that follows. A low reading = defective mosfet.
                            reference:
                            http://electronicsbeliever.com/how-t...0good%20MOSFET.
                            See the resistance table on this webpage.
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • mkdj
                              ASUS X571 no power : battery issue?
                              by mkdj
                              Mark and model: ASUS X571
                              Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                              Tests already made:
                              - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                              - I have removed...
                              07-14-2025, 09:16 AM
                            • techfreak9356
                              Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                              by techfreak9356
                              I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                              09-14-2023, 11:10 PM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
                            • ferah831208
                              Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                              by ferah831208
                              Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                              03-18-2025, 01:18 AM
