MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
  • mon2
    • Dec 2019
    • 13857
    Re: MacBook Pro Mid 2012 turns on, fans spin for five seconds and turns off, repeats
    Measure the resistance from the arrow heads 1-1.
    Then 2-2.
    What are the resistance readings for each ?
    • Gigabit2
      • Apr 2022
      • 264
      • United Kingdom
      #62
      Sadly I lost first resistor so I will need to replace - it blew away
      For second on the right: 00.5
      • Gigabit2
        • Apr 2022
        • 264
        • United Kingdom
        #63
        For first on left: 00.5 [resistor missing]
        • Gigabit2
          • Apr 2022
          • 264
          • United Kingdom
          #64
          Whilst looking around board, I did find broken trace but elsewhere.
          Could this be causing any issue?
          • Gigabit2
            • Apr 2022
            • 264
            • United Kingdom
            #65
            ^ Around U9950 - I am not sure what this does.
            It looks like trace broken between highlighted red points, there is point there looks like it goes to other side of board? I could not scrape anything away and could not find any continuity from it to either points. I tried to scrape off some trace on right and also no continuity to there.
            • mon2
              • Dec 2019
              • 13857
              See attached.
              • Gigabit2
                • Apr 2022
                • 264
                • United Kingdom
                #67
                Originally posted by mon2
                see attached.
                u9950
                • mon2
                  • Dec 2019
                  • 13857
                  See attached.
                  I believe this is the trace flow - from pin # 7 of U9950.
                  Respectively, it does not matter how the traces flow on the PCB itself as long as you can rebuild the same connection.
                  You have enough meat from Pin # 7 trace that is broken to solder a thin wire and connect it directly to the target point = pin # 5.
                  Update - you have meat (actual test pad you can solder to) on pin # 5 trace.
                  You have meat on pin # 7 trace.
                  Just solder a small wire onto the pad on pin # 5 trace and mate it to pin # 7 - done.
                  • Gigabit2
                    • Apr 2022
                    • 264
                    • United Kingdom
                    #69
                    Hi mon2,
                    Yes I will fix this, is this likely to be causing the problem?
                    Can we do more testing in the meantime whilst waiting for the resistor replacement for the other component?
                    • mon2
                      • Dec 2019
                      • 13857
                      This could have been THE show stopper. Of course you still need to replace and stuff the 10 ohm resistors - suggest 1% tolerance if available. The engineers expect this resistor value to be present in series to the current sense resistor. Based on this value, they have knowledge of how much current draw is too much to shut down the unit.
                      You are facing a shut down event so it is quite possible that U7000 is shutting off PPBUS_G3H (a critical rail) due to the missing current sense loop.
                      At this time, can only wait for the parts to replace and see. The area you shared appears to be toasted - any other damaged traces ? If not obvious, just wait for the replacements to move forward.
                      • Gigabit2
                        • Apr 2022
                        • 264
                        • United Kingdom
                        #71
                        Hard to say as do not have any other unit to compare to.
                        R2113 is missing.
                        R1848 is missing.
                        R2913 is missing.
                        R1922 looks a bit dodgy?
                        R2067 is missing.
                        R1843 is missing.
                        R2155 is missing and one of the pads looks gone?
                        Are any of these vital?
                        Rest of board looks clear, please let me know if you can see any other issues here.
                        • mon2
                          • Dec 2019
                          • 13857
                          R2113 is missing - for JTAG TCK parking of the line when not in use.
                          Ok to skip it.
                          R1848 is missing - not sure but is GPU related.
                          R2913 is missing - unable to locate this one in the schematic.
                          R2067 - is a pull-up; if this signal is open-drain then it is required but skip for now.
                          rest - for now - just try to run with the above repairs. Keep the thread posted with your updates.
                          Need to run and find a dress shirt for my son's bday party...he wants to dress up for some viral video thingy.
                          • costivl
                            Y50-70 turns on, no video, fans dont spin
                            by costivl
                            My Lenovo Y50-70 turns on but i have no video, fans dont spin, keyboard lights turns on, no ssd activity.
                            I removed battery, hdd, rams, bios battery, then pressed power button for 30 sec to drain out all energy, still same thing, i did check both mosfets on power module of the board, pq301 and pq302, i get 20,5V on all pins except one pin that have 8.7V
                            Connected external keyboard, tried on all 3 usb ports, no leds on the keyboard, neither numlock, checked voltage on usb pins, i only have 5.1V on 1 pin, rest 0V
                            I have 1.4v on PL502 with...
                            07-01-2024, 11:38 PM
                          • costivl
                            by costivl
                            Any ideas what to check more?
                            Thank You
                            06-13-2024, 11:25 AM
                          • emil_t
                            RTX3090 working fine but fans not spinning
                            by emil_t
                            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                            04-12-2024, 06:54 AM
                          • huzo
                            CLEVO N970TF turns fans to the full and goes of
                            by huzo
                            The laptop is CLEVO N970TF with i5-9400, RTX2070, i haven't disassembled it yet to know what is the board number, i will update that later, but the issue is laptop turns on normally and works for about 2 minutes,then both fans turn on to the max and in 30 seconds laptop shuts down! Nothing is warm or even close to overheating...
                            i manage to get linux up and running and monitor the temperatures from all sensors, and the peak one is 51 celsius from a cpu cores...
                            So something is acting up and thinks the laptop is overheating? How to foul the board into thinking everything...
                            03-06-2024, 05:28 AM
                          • Stephen
                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                            by Stephen
                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                            03-15-2024, 09:37 AM
