Macbook Air 820-00165 A 14 V on PP3V42_G3H
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have this board Macbook 2016 model on PP3V42_G3H line. Is the board dead or what ? Earlier it was around 1.8 and now it is 14 V instead of 3.4 volt on L7095 . Please advise.
  • mon2
    • 14662
    Re: Macbook Air 820-00165 A 14 V on PP3V42_G3H
    OMG. Probably toasted with such a high voltage but are you confident the reading is correct ?
    Remove all power and check the voltage divider resistors @ R7095 & R7096. They must be the same value as shown in the circuits otherwise the downstream rail will get damaged.
    These resistors define the 3v42 configuration.
    • piernov
      • Jan 2016
      • 4439
      • France
      Measure on the output of the inductor not the input.
      • IamPritesh
        • Aug 2017
        • 356
        • India
        The inductor was damaged when I tried to use the heat gun . There is no connectivity between both the ends.
        • mon2
          • 14662
          Can you confirm how you measured this rail ? The inductor has been recently damaged - after the measurement of 14v ??
          The inductor (L7095) is not a critical component and can be replaced with any 2520 sized 10uh device. Often ferrite beads will work here but check their rated current before using. The rail itself is only 300mA but good idea to use 1A rated inductor or higher.
          Perhaps you have a donor board or can borrow for testing ?
          Then confirm the voltage rail @ L7095, pin # 2 as noted by @piernov.
          In your repair, use lots of flux and watch how long the heat is applied onto the component if the heat setting is high. We use 550C on our clone Quick station (BEST Tools) but are cautious to not keep the heat on for too long on the component.
          • piernov
            • Jan 2016
            • 4439
            • France
            The inductor is a critical part of the buck converter, it cannot be replaced by a ferrite bead.
            • mon2
              • 14662
              Meaning the style that is attached. A wire wound inductor is not required to be used for such low currents. SMD ferrite bead inductor can be applied.
              • piernov
                • Jan 2016
                • 4439
                • France
                The original inductor uses this kind of package. It is not the same thing as a ferrite bead used to filter high frequency noise though.
                • envym
                  by envym
                  Hi everyone!
                  06-27-2025, 08:54 AM
                • Flasman90
                  Macbook Pro DFU Restore Issues
                  by Flasman90
                  I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                  - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                  - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                  08-30-2025, 10:27 AM
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
                • obelix24
                  A2941 Macbook air 15” - 5V 0a
                  by obelix24
                  I’m working on one macbook air 15” m2 that was water damaged.
                  keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                  i’ve put macbook in shelf and order new screen so i can fully repair it.
                  Now i got the screen and macbook stays at 5v 0a.
                  i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                  i don’t have schematics so i don’t know where to start can someone help me?...
                  03-27-2025, 01:19 PM
                • Orux
                  Macbook Pro M1 A2338 13"
                  by Orux
                  I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
                  I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
                  One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
                  09-22-2025, 12:54 PM
