HP 15-la c701p turn on but no post
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello friends
    Model: HP 15-la c701p turn on but no post at internal and external .
    All voltages are present on its coils, consumption is :
    with ram = 0.342 amp
    without ram = 0.331 amp
    I have these measurements:
    RTC section :
    JCMOS1 = PCH_RTCRST# =3.018v
    JME1 = PCH_SRTCRST# =3.019v
    KB9022QD
    LID_SW# 3.07v (EC pin 115)
    PCH_RSMRST# 3.02 (EC pin 100)
    PCH_PWROK 3.3v (EC pin 32)
    PLT_RST# 3.3v (EC pin 13)
    Ram Measurements :
    +1.35V_VDDQ = 1.362v
    +0.6V_0.675VS = 0.681v
    +V_VDDR_REFA_DQ = .683v
    PCH_SMBDATA = 3.3v
    PCH_SMBDATA = 3.3v
    DDR3_DRAMRST 0v....must be 1.35v
    Trace DDR3_DRAMRST until RC308 ( pull up resistor ) : got 1.35v from only one side ; 0v from the other side...the ohm value is correct .
    Try 2 official bios same issue ; other ram too.
    What to check else ...thank you
  • mon2
    • 14666
    Re: HP 15-la c701p turn on but no post
    +1.35V_VDDQ = 3.3v
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Originally posted by mon2
      Hello friend...it was a mistake ...1.365v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        UC10 measurements??QD1 Checked??
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Thank you mcplslg123
          UC10 :
          pin 2 = 1.363v
          pin 5 = 1.3.63v
          pin 4 = 4.95v
          QD1 :
          Drain and source = 1.363v
          Gate = 4.95v
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Both these measurements are fine. Since you have already flashed bios from hp site, Cpu part of the SOC is very likely to be faulty.
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Yes , i agree with your conclusion .
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                Strange , got another same motherboard with same behaviour : no post.
                But in this case DDR3_DRAMRST is present = 1.35v ..the 21 power sequence steps are all presents.
                Try clean me and repairing bios still same , consumption is =
                With ram = 0.740 amp
                Without ram = 0.600 amp
                Notice when on the fan spin high without stoping.
                step of communication between CPU and bios called POST is faulty !! any other idea to be sure!
                • pajdek
                  Lenovo Y700-17ISK turn on and off
                  by pajdek
                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                  09-20-2023, 02:49 AM
                • RdeveLabs
                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                  by RdeveLabs
                  To all the members here...
                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                  05-05-2025, 04:59 AM
                • robante15
                  Acer Aspire 4520 won't turn on after reboot
                  by robante15
                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                  If I remove the...
                  04-06-2024, 06:50 PM
                • masoksian
                  Dell latitude e7470 not turn on .power buton on off and Run Power problem
                  by masoksian
                  I am dealing with the problem of turning on and off my Dell e7470 notebook.
                  The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                  The system does not turn on, there is no post.
                  I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                  The problem continues in the same way.
                  I tried to turn on the Fn key, nothing came to the screen....
                  02-15-2025, 12:08 PM
                • dqtech
                  lenovo x240 nm-a091 wont turn on
                  by dqtech
                  i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                  board number VIUX1 NM-A091 REV:1.0...
                  02-07-2024, 01:57 AM
