Macbook Air 820-3437B missing PP3V3_S5
  • vinifera
    Vinifera
    • Aug 2018
    • 28
    • Belgium
    Re: Macbook Air 820-3437B missing PP3V3_S5
    PP3V3S5_EN_R is high = 3,425V
    Resistance between Pin16 and Pin2 from L7560 = 19,57k
    R7563 10 ohm must be 10 ohm
    R7561 9,25K must be 10K
    R7560 18,11K must be 23,2K
    Pin2 L7576 in ohm to ground = 3K
    All those measures are taking with L7560 on the board
    Kr
    • Adogabriel100
      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
      by Adogabriel100
      Hey! This is a A1278 macbook 2011.
      Problem: Not turning on / No green light
      Im using by3200s charger.
      Voltajes:
      PPBUS_G3H = 12.26v
      SMC_RESET_L = 3.3v
      PP3V42_G3H = 3.42v
      U7000 =
      Pin 1 CHGR_AGATE = 0v
      Pin 2 CHRG_DCIN = 19v
      Pin 3 CHRG_ACIN = 4.6v
      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
      Pin 12 PP3V42_G3H = 3.42v
      Pin 13 CHRG_RST_L = 3.3V
      Pin 14 SMC_BC_ACOK = 0.8V
      Pin 19 PP5V1_CHRG_VDD = 5.05V
      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
      04-01-2024, 01:02 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • salopian
      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
      by salopian
      Hello. I would need some advice please.
      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
      I have already replaced the logic board with another...
      02-27-2021, 07:30 AM
    • mferna14
      Apple MacBook A1398 820-00138-A missing 5V
      by mferna14
      HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
      01-16-2023, 01:35 PM
    • fajfelek
      Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
      by fajfelek
      Hello, First of all thanks you for reading this topic.
      I need your help with identify missing parts on trackpad logic board (661-18430).
      The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
      Please help me with identity parts from blue and red area .
      06-15-2024, 01:41 PM
