PC specialist NL5E-N18EG
  • lucian6464
    • Feb 2021
    • 9
    Hi, i have the same problem, no more power and same coil is broken, how do you check if a mosfet is in short, and if you remember where was your broken on as my be the same on my one
  • mon2
    • Dec 2019
    • 14198
    Re: PC specialist NL5E-N18EG motherboard
    This question is best posted in the laptop repair side of the forum.
    Remove all power -> meter in resistance mode (start with the lowest scale).
    Then measure across the mosfet pins as follows:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    If the meter shows '1' -> switch to the next higher meter scale.
    Post each measure & the meter scale used for the measurement.
    You are checking for a low resistance reading which often means a defective mosfet.
    • lucian6464
      • Feb 2021
      • 9
      Thank you, will do tomorrow
      • lucian6464
        • Feb 2021
        • 9
        All sorted, mosfet under the burned coil was burned also, replaced that and the laptop works again
        Thank you for your support
        • jorpec
          Changing the scale of an analog meter
          by jorpec
          Hi
          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
          I wonder how i can accomplish this so the meter would be precise at any temperature ?
          Thnaks
          01-23-2023, 10:37 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • chth96
          Is it possible to test small ceramic disc capacitor with analogue meter?
          by chth96
          I read EBOOK of Testing Electronic Component and found that
          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
          Is it really possible to test small ceramic disc capacitor with analogue...
          03-09-2024, 10:03 PM
          MEDION ERAZER Specialist P10 Notebook Specification for Upgrade or Repair
          This specification for the MEDION ERAZER Specialist P10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Specialist P10 boardview and Specialist P10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          09-07-2024, 06:11 AM
