Lenovo Y530 power button only works with battery
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    So my Lenovo Y530 power button (and power LED) only works with battery. If I only plug in the AC, the power doesn't flash and nothing happens if press it.
    20V present on the main power rail with the AC plugged in.
    Also worth mentioning:
    If I inject 19V/1A on the + pin of the AC IN, nothing happens current draw is 0.016A V is 19V. But If Inject the same power trough a CAP after the first MOSFETS the board starts up (power LED flashing) and the current draw is 480mA.
  • mon2
    • Dec 2019
    • 14097
    Re: Lenovo Y530 power button only works with battery
    Remove all power. Meter in resistance mode.
    Check the resistance of the first 2 mosfets to see if they are defective.
    Meter in resistance mode (2k scale is ok).
    Check each mosfet with meter probes across:
    Source (1-2-3) & Drain (5-6-7-8)
    Source (1-2-3) & gate (4)
    Gate (4) & drain (5-6-7-8)
    Post each measurement. Repeat for the 2nd mosfet. Checking for a low resistance = defective mosfet.
    Also post the markings of each mosfet so we can find their datasheets (or a valid replacement).
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      Meter in 2k resistance mode.
      MOSFET1 AON6366E_DFN8-5:
      Every combination is OL.
      MOSFET2 AON6414AL_DFN8-5:
      Same values.
      Also, If I inject the power on the drain side of MOSFET 2 the power led flashes, the system wants to start up. 20V/480mA load.
      • mon2
        • Dec 2019
        • 14097
        Review the voltages on the mosfet.
        What are the mosfet markings?
        Can you post or link the schematic for your logic board so we are referencing the same?
        Which charger IC is onboard?
        • unimatrix93
          • Oct 2021
          • 343
          • Magyarország
          With AC in:
          PQ201 6366E GA0F14
          20.7V on D
          20.7V on S
          26.5V on G
          PQ202 6414A GA3Y58
          20.7V on S
          26.5 on G
          20.7 on D
          Schematic:
          https://1drv.ms/b/s!Ar4hHP2toEdogtU4...bmXWA?e=n0OToz
          • mon2
            • Dec 2019
            • 14097
            Mosfet voltage looks ok.
            Are you using the original laptop power supply for testing ?
            There is an ADAPTER_ID that must be present for this to work properly.
            • unimatrix93
              • Oct 2021
              • 343
              • Magyarország
              Yes I do.
              ADAPTER_ID is not present (0v) as far as I see.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Try with known good Lenovo power supply.
                Measure resistance to ground (the adapter must be disconnected from the mains and the laptop itself) between the Id pin and the ground (at the jack) of your current power brick.
                Become a Badcaps supporter
                Thanks to all supporters.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3582
                  • slovakia
                  replace first mosfet
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Agree, it is also a logical reason for the behavior of the machine as described, although the data from their measured voltages and resistances seem to be OK.
                    • unimatrix93
                      • Oct 2021
                      • 343
                      • Magyarország
                      I measure 0.996 kOhm resistance to ground between the ID pin and ground.
                      DMM is set to 2k.
                      • unimatrix93
                        • Oct 2021
                        • 343
                        • Magyarország
                        When I first tried to diagnose the laptop, I suspected the SuperIO chip because of the unresponsive power button.
                        But when I tried with the battery the button worked, also the laptop does try to start up when I inject power at the second mosfets drain or on one of the caps of the main power rail.
                        • mon2
                          • Dec 2019
                          • 14097
                          With no power, check the resistance across the battery mosfet pins.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            DMM is set to 2k.
                            Seem ok, it's a 135W power brick right?
                            Replace the mosfet as ktmmotocross suggested.
                            • unimatrix93
                              • Oct 2021
                              • 343
                              • Magyarország
                              Measurements across PQ203 mosfet:
                              • unimatrix93
                                • Oct 2021
                                • 343
                                • Magyarország
                                So I replaced the first MOSFET now 20V is not passing trough it.
                                I have 0V on both gate and source if I apply power on the ACIN pin.
                                Its the original 135W power brick and its supplies 20V, I checked it.
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  With what exactly? What are the markings of the new mosfet?
                                  Are you sure you've soldered it properly (not upside down for example)?
                                  Are you playing there with the bench power supply? If yes, be very very careful , because if you accidentally touch the ADAPTER_ID line with the positive (+20v) probe, you can say goodbye to SIO chip, you have been warned.
                                  Try with the original adapter. (because ADAPTER_ID must be present)
                                  Yes I do.
                                  ADAPTER_ID is not a (positive) voltage line! It's a signal line, SIO chip receive this signal as a value of the resistance to the ground in it.
                                  That's why I asked above to measure this value at the jack of your current power brick.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    Be more specific - do you measure resistance in Ohms between S/D/G to ground, or between the S/D/G pins of the battfet itself in diode mode???
                                    • unimatrix93
                                      • Oct 2021
                                      • 343
                                      • Magyarország
                                      I'm pretty sure I soldered it properly, also here are the markings on the mosfets:
                                      MOSFET1: 6366E, GA0F14
                                      NOSFET2: 6414A, GA8U2K
                                      Sure, I pay attention to it.
                                      0.996 kOhm at the jack of the power brick and 0.005 kOhm on the ADAPTER_ID pin on the board to ground.
                                      Sorry, I meant it in resistance mode between S/D/G to ground and between S/D/G. In diode mode:
                                      S to D: 0.542
                                      D to S: 2.431
                                      G to S: 1.814
                                      G to D: 2.476
                                      Also, I found a short to ground on the 3VALW line. If I apply 2V/4A on it the PCH chip is getting slightly warm, but nothing else.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        S to D: 0.542
                                        D to S: 2.431
                                        G to S: 1.814
                                        G to D: 2.476
                                        0.005 kOhm is 5 Ohm - this is almost short, along with the shorted PCH means that this machine is now beyond economical repair.
                                        Playing with a bench power supply on the motherboard without the theoretical and/or practical skills and understanding on a subject does not lead to anything good as a result.
                                        • rabsonnjala
                                          LENOVO IDEAPAD 100 works only on bench power supply
                                          by rabsonnjala
                                          Hie I have a Lenovo laptop
                                          Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                          it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                          below are my readings
                                          with the original charger only
                                          JBATT1
                                          PIN1 0.22V
                                          PIN2 0.22V
                                          PIN3 0.45V
                                          PIN4 0.45V
                                          PIN5 O.43V
                                          PIN6 0V
                                          PIN7 GND
                                          PIN8...
                                          11-20-2021, 08:32 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Mita99
                                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                          by Mita99
                                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                          04-27-2025, 07:20 PM
