Lenovo a285 no power can't charge power button no response
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Hi guys
    I don't know how to solve this
    Plugging USB c gave reading 19v in but battery not charging. Using other laptop battery charges just fine
    With no battery and USB c adapter plugged in Vsys is around 9v. With battery only Vsys is equal to battery voltage. With battery and adapter plugged in Vsys is around 12v. So unlikely that bq 25700 is damaged nor the MOSFETs it controls
    tps51285b supplies 3 and 5v. 3.3v present. 5v present if only enabled.
    Closest schematic I could find is one for x270. In x270 3v enable and 5v enable are tight together, but in a285 they are not. So currently only 3.3v present (en around 2.7v), no 5v (en 0v)
    Also in a285 the voltage controller for CPU is isl62771
    No activity on bios cs pin, but 1.8v VCC present
    I believe this is caused by amd integrated PCH in APU not getting v supply maybe ? Since the voltage controller isl62771 isn't getting 5v vcc which supplied by TPS ic mentioned above
    3.3v on power button, pressing it pulls down the voltage
    1.8v and 3.3v present on caps around thinkengine ic.
    So that's it..... If anyone know where to check next
    Thanks in advance
  • mon2
    • Dec 2019
    • 14003
    Re: Lenovo a285 no power can't charge power button no response
    Hi. So BQ25700 is the charger IC ?
    With the adapter & battery connected, measure the voltage on
    pin # 19 (SRN)
    pin # 20 (SRP)
    BATDRV# pin # 21
    SCL (pin #13)
    SDA (pin #12)
    CELL_BATPRESZ (pin # 18)
    Post each reading.
    • ss45
      • Jun 2019
      • 119
      • Brazil
      pin # 19 (SRN)
      pin # 20 (SRP)
      BATDRV# pin # 21
      SCL (pin #13)
      SDA (pin #12)
      Post each reading.
      Hi. Here is the measurements
      SCL sda 3.3v
      Cell batpresz 3.459v
      Sen srp 12.85v
      Batdrv 13v
      Vdda REGN 6V
      Vbus 20
      CHG ok 3.3
      Upon plugging battery without ac adapter No activity on SCL SDA pin confirmed with oscilloscope
      There is 1.8v and 3.3v at thinkengine ic tho
      • mon2
        • Dec 2019
        • 14003
        Review figure 40 of the above charger IC datasheet.
        With no power, compare if you have a similar resistor based voltage divider on your logic board for the CELL_BATPRESZ pin.
        With no power, check the resistance across the high side and low side resistors for this pin.
        The posted voltage, from the datasheet, does not look correct.
        What voltage do you see for CELL_BATPRESZ on the other laptop that is working?
        If you charge this battery in the other laptop, does this battery work to power this logic that is not charging?
        • ss45
          • Jun 2019
          • 119
          • Brazil
          Well battery confirmed working. Sadly Currently no other laptop of similar model, previously there was, but already fixed and returned, different problem
          Anyway the resistor 58.5 kohm to vdda 75.5 kohm to gnd
          So the math checks out, ~3.4 is around 55% of 6v which according to the datasheet will configure the chip to charge 3s battery. The battery nominal voltage is 11.5 which also strengthen it is indeed 3s bat.
          Hope is running thin, maybe dead mec (Lenovo superior) m
          • tomodachi
            • Apr 2012
            • 600
            • Turkey
            What is the current draw on ampermeter ?
            by the way A285 appears to be same design with Thinkpad X280, hope it helps you
            • ss45
              • Jun 2019
              • 119
              • Brazil
              0.02 virtually 0 amp?
              Yeah thanks for pointing that out.
              • mon2
                • Dec 2019
                • 14003
                Excellent and many thanks !! Have the schematic in my database for this one.
                See attached for the first DUAL MOSFET in a single package datasheet.
                Remove all power. Meter in resistance mode.
                Check the resistance between the following:
                source & drain (review the datasheet on which pin is which on this package)
                source & gate
                gate & drain
                post the readings for the 1st and then the 2nd mosfet inside this package.
                • ss45
                  • Jun 2019
                  • 119
                  • Brazil
                  All MOSFETs are fine, ie q1-q4, batfet all no short. Checked waveform on all gates, they are also fine and each conducts when proper signal is fed,
                  Acn aCP vbus around 19.9v
                  CHG ok around 3v if adapter is plugged in, 0v otherwise
                  The only suspicious thing is Output from nvdc system is around 9v without bat
                  Usually with nvdc it tries to match nominal cell voltage, right ?
                  Edit
                  Not necessarily, I have X1 carbon equipped with same ic, output without battery is around 10v, so....
                  That's it guys thanks for helping. I give up
                  • ipatch
                    troubleshooting microsoft surface pro 4 no power no led charge light
                    by ipatch
                    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                    10-05-2023, 11:59 AM
                    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                    Narrow VDC applications where the system power source is
                    either the battery pack or the regulated output of the charger.
                    This makes the max voltage to the system equal to the max
                    battery voltage instead of the max adapter voltage. Operating
                    at lower system voltage can improve...
                    11-05-2024, 04:43 PM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
                  • Klevjetack
                    Charge a L19D3PDA battery externally from the laptop
                    by Klevjetack
                    Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                    03-05-2024, 07:26 AM
                  • razenxd
                    How can I charge that battery pack?
                    by razenxd
                    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                    Now, I have noticed a few things.
                    The "dead" battery, while connected to charger and NOT Charging will...
                    12-05-2024, 06:11 AM
