Sony SVF1531GSA DA0HKDMB6D0 Screen question
  • pingaroon
    • Nov 2019
    • 121
    • uk
    Hi, does anybody have this model? I need to know which model screen it takes (edp) and if it's a "Sony special" (ie different pin config to most other edp 30-pin screens). I know Sony often do things differently to everyone else.
    I have a board which outputs ok to hdmi and need to verify it's good to a laptop screen.
    Cheers
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Adam Russ
    Black screen on Sony 65x90ch (65x900h from Costco)
    by Adam Russ
    Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
    09-15-2024, 05:46 PM
  • Ihandyrepair
    sony 55X850D black screen no front white or red led light.
    by Ihandyrepair
    Hi guys
    strange one
    I have a dead Sony 55X850D
    when plug in, black screen, no front white or red LED, no back light no screen
    Voltages I get
    3.3v LD/power and main board
    reg 12V
    reg 19V
    3.3v on power on pin
    no Tcon on
    no tcon 12v
    no BL_on
    I do get BL_ERR 2.0v
    I tried to bypass it by ground it but still get same symptom
    I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
    or is possible the chip next to...
    08-07-2024, 04:58 AM
