a1990 820-01041
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    a1990 820-01041
    a1990 820-01041 stuck on 5v
    i have no PP3V3_G3H_RTC_X
    it also in diode mode i read 0.025
    i readed its generated from u6960 and also i have no voltage in vin at c6961
  • mon2
    • Dec 2019
    • 14662
    Re: a1990 820-01041
    What is the voltage of PPBUS_G3H @ F7000, pin # 2 ?
    When 5 volt (default) from the external adapter is the power source, U7000 will enter BOOST mode for the PPBUS_G3H rail.
    Remove the battery and use only the external USB C power adapter and measure this voltage.
    Do check also F7000, pin # 1.
    If you see a low voltage on this rail, then remove all power -> remove F7000 and then power up again with the external adapter.
    Then check again the voltage of PPBUS_G3H
    @ F7000, pin # 1 - what is the reading without a load (no fuse) ?
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      Re: a1990 820-01041
      F7000 pin 1 no voltage
      f7000 pin 2 no voltage
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        Re: a1990 820-01041
        i used another usb-c (right side ) and i have 12v on f7000/f7001 pin 1 without fuse
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          Re: a1990 820-01041
          putting back fuse i have pulsing voltage around7v/8v both side of fuse
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            Re: a1990 820-01041
            this port is using u 3200 , and i have also PP3V3_G3H_RTC_X but no 20v ... ...
            • lordgeny
              • Apr 2016
              • 223
              • Italia
              Re: a1990 820-01041
              ok i found that ub400 was heating , so i removed and now ppbus its back at 12v , i need new ic
              • alfredodinolfo
                MacBook Pro 2019 (A1990)
                by alfredodinolfo
                mb code:820-01827-A;
                sn:C02Z349ALVDR;
                i9 32GB Ram 1TB
                Hi, I found short on one of 6 black nand (total 1TB).
                i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                macbook with A2141 configuration run on recovery but don't complete it.​
                anyone can help me?
                05-26-2025, 09:27 AM
              • Strolch
                MacBook A1990 26 Pin Connector
                by Strolch
                Hello, can anyone tell me where I can get this 26-pin FPC connector? What is the connector for?So that one's also for the Touch Bar. I thought only the FPC at the top was for the Touch Bar. But where can I get it? I can't find the connector online. I only found the 22nd pin. Thank you....
                09-03-2025, 01:11 AM
              • master_haze86
                A1990 820-01814-A dead not charging - need help with diagnostics.
                by master_haze86
                Good day everyone,
                Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
                The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
                09-13-2025, 06:01 PM
              • falcontech
                Macbook Pro a1990 activation locked
                by falcontech
                I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks.
                09-29-2025, 06:57 AM
              • ktmmotocross
                Two Apple A1990 EMC3215 start to 5W and power off, T2 ic is heating
                by ktmmotocross
                Hello.
                Have this two Apple A1990 EMC3215 that starting to 5W and power off. Byt Thermocam i see that T2 ic is heating little too much right when consumption start to raise.
                I dont find any short in coils for it and it looks like there are voltages
                Any hint or bad T2 is common on this boards?
                09-17-2025, 07:51 AM
