a1990 820-01041
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    a1990 820-01041
    a1990 820-01041 stuck on 5v
    i have no PP3V3_G3H_RTC_X
    it also in diode mode i read 0.025
    i readed its generated from u6960 and also i have no voltage in vin at c6961
  • mon2
    • 14086
    Re: a1990 820-01041
    What is the voltage of PPBUS_G3H @ F7000, pin # 2 ?
    When 5 volt (default) from the external adapter is the power source, U7000 will enter BOOST mode for the PPBUS_G3H rail.
    Remove the battery and use only the external USB C power adapter and measure this voltage.
    Do check also F7000, pin # 1.
    If you see a low voltage on this rail, then remove all power -> remove F7000 and then power up again with the external adapter.
    Then check again the voltage of PPBUS_G3H
    @ F7000, pin # 1 - what is the reading without a load (no fuse) ?
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      Re: a1990 820-01041
      F7000 pin 1 no voltage
      f7000 pin 2 no voltage
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        Re: a1990 820-01041
        i used another usb-c (right side ) and i have 12v on f7000/f7001 pin 1 without fuse
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          Re: a1990 820-01041
          putting back fuse i have pulsing voltage around7v/8v both side of fuse
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            Re: a1990 820-01041
            this port is using u 3200 , and i have also PP3V3_G3H_RTC_X but no 20v ... ...
            • lordgeny
              • Apr 2016
              • 223
              • Italia
              Re: a1990 820-01041
              ok i found that ub400 was heating , so i removed and now ppbus its back at 12v , i need new ic
              • alfredodinolfo
                MacBook Pro 2019 (A1990)
                by alfredodinolfo
                mb code:820-01827-A;
                sn:C02Z349ALVDR;
                i9 32GB Ram 1TB
                Hi, I found short on one of 6 black nand (total 1TB).
                i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                macbook with A2141 configuration run on recovery but don't complete it.​
                anyone can help me?
                05-26-2025, 09:27 AM
              • ahoonid
                MacBook A1990 vertical stripes on external screen
                by ahoonid
                Hey everyone,
                I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                The board is neat. Not opened before for sure. Just a little dust, nothing more.
                Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                06-20-2025, 08:54 AM
              • ahoonid
                A1990 820-01326 stuck at 5v and 0.19A
                by ahoonid
                Hi everyone.
                I have a MacBook Pro 15" A1990 touchbar with (I believe) a dedicated Vaga GPU. The exact Boardview and schematics doesn't seem to exist but I've been using the one for 820-01814 so far.
                The MacBook doesn't turn on, stuck at 5v and drawing only 0.19A.
                All 4 USB Cs ports behave exactly the same.
                There's no PPBUS G3H available.
                The resistance to ground from PPBUS G3H is 0.4 ohm. I have found the same resistance to PPBUS G3H from two coils near cpu/gpu area.
                Since the boardview I have is different exactly in this...
                05-20-2025, 04:31 AM
              • mavaro
                MacBook A1990 — No Display With Battery Connected
                by mavaro
                Hi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
                Battery replaced with another unit → same problem.
                ISL9239 replaced → no change.
                SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
                Any ideas or advice would be a huge help!
                Thanks in advance for your time.​
                04-18-2025, 08:07 AM
              • arashmoayyedizadeh
                A1990 2019 touchbar weird behaviour
                by arashmoayyedizadeh
                Hello to all of you engineers
                i have a macbook pro a1990 in no power condition
                another shop had done some works on it with no success (pm ic was reflowed, a little bit of flux around one of the type c rom ic, changing the charging ic)
                initial state: 5v 0amps on all 4 type c sockets
                after some inspections i realized the charging ic that another shop installed is isl9239
                I changed it with right one (isl9240) and the machine turned on and booted into macos
                weird behaviour:
                Lcd works ok until it boots to os and as soon as you see login page it goes black...
                03-26-2025, 12:02 PM
