hp 15-p202ne no data but light screen
  • salmanzeiad
    • May 2016
    • 68
    • world
    hp 15-p202ne power ok but light screen no data
    flashed bios but same issue!
    • 21936
    Re: hp 15-p202ne no data ghut light screen
    https://www.badcaps.net/forum/showthread.php?t=88758
    Here we will give just a few pointers to what kind of troubleshooting has to be done if you suspect a board issue.
    Powers on but no display
    • Check if it's no backlight, no image or both
      • If no image:
        • Check if external display works, try with internal LCD disconnected as well.
        • Measure voltage on LCD power rail(s)
      • If no backlight but image is present
        • Try to locate the fuse (or resistor or inductor) to backlight rail and check if it's blown
        • Measure voltage on backlight rail, backlight enable signal, brightness adjustment signal
    • Check if laptop is POSTing: pressing caps lock key triggers caps lock LED, activity of USB drive blinks when turning on, audio plays, HDD is being read, etc… If it's not POSTing:
      • Check RAM compatibility
      • Reseat RAM and clean RAM slots
      • Measure exact voltage on CPU VCore
      • Check CPU Reset signal
      • Follow power sequence if it exists in the schematics
      • Follow list of power rails if it exists in the schematics
    No power
    • Check Laptop battery charging circuit
    • Check if DC-in jack LED lights up
    • Check voltage on all the large inductors
    Note: don't forget to trigger power button when measuring for the rails that only come up when machine is turned on.
    When requesting help, please attach a picture of the board with voltage and resistance to ground measurements on all the large inductors after triggering power button.
    Powers on, display ok but something is wrong afterwards
    • Exclude software issue by booting from another drive with Windows 10/Linux/macOS
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: hp 15-p202ne no data but light screen
      USB keyboard Numlock glows?? Screen.display cable replaced or tested with working ones??
      • mansoorppv
        • May 2014
        • india
        iasus k55vd same problam kb light responding. ext vga port working fine . no picture in internal display screen changed cable changed . only backlight working what to check?
          • 21936
          Off topic, start a new thread.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • Rav_tangle
            MacBook Pro 2011 turns on with keyboard light , screen dead
            by Rav_tangle
            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
            is this...
            05-31-2024, 04:09 PM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Ihandyrepair
            sony 55X850D black screen no front white or red led light.
            by Ihandyrepair
            Hi guys
            strange one
            I have a dead Sony 55X850D
            when plug in, black screen, no front white or red LED, no back light no screen
            Voltages I get
            3.3v LD/power and main board
            reg 12V
            reg 19V
            3.3v on power on pin
            no Tcon on
            no tcon 12v
            no BL_on
            I do get BL_ERR 2.0v
            I tried to bypass it by ground it but still get same symptom
            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
            or is possible the chip next to...
            08-07-2024, 04:58 AM
