A1932 - Black screen, no startup sounds
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    Apple MacBook Air 13" A1932 2018. It's on. Touchpad clicks and board gets warm. There is no start-up sound and the display stays black. The audio board was defective after liquid damage. Nothing is visible on the logic board. bild comes with another logic board. So display and cable are intact! I have both logic boards here and can also measure on both.
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    Re: A1932 - Black screen, no startup sounds
    From C8469-C8473 I have 43 volts on the board where the display works. On the board where the display remains black, I have 0.0200 volts from C8469-C8473!
    • mon2
      • Dec 2019
      • 14030
      Remove all power. Meter in resistance mode.
      Check the resistance to ground on C8469-C8473 for the non-working board.
      Compare the resistance to ground of the working board.
      • Strolch
        • Nov 2017
        • 237
        • Deutschland
        All right around 168K ohms after a few seconds.
        • Strolch
          • Nov 2017
          • 237
          • Deutschland
          possibly U8400
          • mon2
            • Dec 2019
            • 14030
            What is the 820-xxxx marking on your logic board ?
            • Strolch
              • Nov 2017
              • 237
              • Deutschland
              820-1521-a
              • mon2
                • Dec 2019
                • 14030
                With the adapter & known good LCD connected, what are the voltage readings for:
                1) F8400, pin # 1
                2) F8400, pin # 2
                3) R8442, pin # 1 (EDP_BKLT_EN)
                4) R8442, pin # 2 (BKLT_EN_R)
                5) I2C_BKLT_SCL
                6) I2C_BKLT_SDA
                7) I2C_BKLT_SCL_R
                8) I2C_BKLT_SDA_R
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  Then do I have to remove the display to measure? Or just remove the 6 screws from the display board and fold the display board over?
                  • mon2
                    • Dec 2019
                    • 14030
                    Compare notes with the working unit.
                    For the logic board with the working backlight, do you have the display connected ? Pretty sure that you will need to mate the display to allow for the logic board to turn on the backlight.
                    Respectively, need to check under the same conditions as the working board, if the backlight IC is being ENABLED on the non-working board ?
                    Is the DC input to the backlight fuse OK ?
                    The I2C pins are not stuck on the backlight IC ?
                    Proceed with patience and care to prevent damage.
                    • Strolch
                      • Nov 2017
                      • 237
                      • Deutschland
                      I had slipped while measuring near F8400 and wanted to test the board and installed it. Then there was some smoke and the U8400 burned out ;-( from the intact board!
                      • Strolch
                        • Nov 2017
                        • 237
                        • Deutschland
                        Then I'll probably swap the U8400 from the board first and see if it works again.
                        • mon2
                          • Dec 2019
                          • 14030
                          Ouch! They are commonly available on Aliexpress.
                          Being in this position, consider to flux and carefully remove the same IC off the non-working board and transplant onto this board and see if the backlight works.
                          Lots of flux & patience.
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            I bought 10 pieces from Ali. I'm not sure if it fits this board. The the IC both the same? The numbers are not the same.
                            • mon2
                              • Dec 2019
                              • 14030
                              Perhaps a different housemark.
                              Did the vendor state the part to be the same as the original backlight IC ?
                              Worth testing with 1 device.
                              Post the bottom side pic of the new part. The defective one needs to be replaced of course but do make a note of the pin #1 orientation for this surgery.
                              • Strolch
                                • Nov 2017
                                • 237
                                • Deutschland
                                I also installed the IC in the A1707 15 inch MacBook Pro! On the schematics the IC on both boards Air and Pro are the same LP8548B1SQ_-04 and LP8548B1SQ_-03 and the same contacts
                                • mon2
                                  • Dec 2019
                                  • 14030
                                  It should be fine to use.
                                  • Strolch
                                    • Nov 2017
                                    • 237
                                    • Deutschland
                                    Das sind die IC die ich gekauft habe
                                    • mon2
                                      • Dec 2019
                                      • 14030
                                      That is a good store - have used them many times for parts. No issues.
                                      • Strolch
                                        • Nov 2017
                                        • 237
                                        • Deutschland
                                        I unsoldered U8400. 3pins don't look good one pin is gone. Pin 8 is not connected. I will rebuild the 3 pins and solder in U8400. I hope the display will work again. Then I measure the other board.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
