presicion M65 MB dead?
  • Joeman
    • Jun 2010
    • 3
    Ok so i have a dell presicion M65.got it for free.ok so the person that had it said it had a bios password no problem for me.but i got it home and plugged it in and nothing no lights no LEDs dead.so i opened it up down to just the motherboard.plugged the AC adapter in and still nothing.but i noticed that the board is getting some power 2 chips get really hot one of these chips is a maxim 8731e it gets so hot that it'll burn ur fingure.heats up instanly 1-2 secs.and if left powered up u can smell it cooking. also the other chip is located below the wwlan card slot cant fully read it but it has "tps" on it.it gets hot aswell but not burning hot and it seems to get hot cool off the repeat over and over.something to point out is the maxim chip doesnt get hot at all when just the battery is powering the system(still dead no lights at all)the battery has a full charge swaped out of a working M65.when power is applied to the system AC\battery or both nothing no fan no sounds just the hot chips on the board.i have the time to fix it just not real sure where to start.any ideas would help. even radical ones ill try after all it was a complety free laptop.the guy i got it from said that last time he messed w\ it that it did power up to the bios password screen.he might have been mistaken tho.i have the stinking password for this machine just no life at all in the machine?if i remove the TPS chip (the one that gets warm not cooking)in theroy would the laptop still work w\ out this chip? cpu,mem,adapter,battery is good swapped it w\ a working M65. PLZ help
  • chevelle_nut
    • Dec 2008
    • 62
    Re: presicion M65 MB dead?
    [QUOTE=2 chips get really hot one of these chips is a maxim 8731e it gets so hot that it'll burn ur fingure.heats up instanly 1-2 secs.and if left powered up u can smell it cooking. maxim chip doesnt get hot at all when just the battery is powering the system(still dead no lights at all)the battery has a full charge [/QUOTE]
    Welcome to the forums Joeman, The Maxim chip is the battery charging controller so it makes perfect sense it does not heat up without a/c. It is also used as a power o.k. check to perform power up and boot. The tps chip is most likely a blown mosfet , Shorted internally. will not lie to you swapping the MAX8731 is a pain in the @#%$ without the proper rework station. The tps chip you will definitely need the number (either from the chip or schematic) to check it out tho.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      tps is a ti prefix for their dc-dc converter chips.
      • chevelle_nut
        • Dec 2008
        • 62
        DOH! I thought he wrote fds, I really need better glasses...
        If I remember correctly those are found in the 5v sections (amongst others) for USB power. I had one that was having trouble booting, chip was heating up. It ended up being a broken off piece of a thumb drive stuck in usb port.
        • Joeman
          • Jun 2010
          • 3
          Sorry to say i gave up on the M65 and am using it as a trash board(transplanting other chips ect.. from it)just got tired of it after 2 week steady 5+ hours a day messing w\ it.Have moved onto other more promising things.like a V2000 that will not charge the battery when its running but will charge while its off?ill make a new post reguarding that one thanks.
          Thanks for the offer on the d820 sche. chevelle_nut!!!!i had already trashed by time i saw ur email .
          • double_DD
            How can I be sure that my EC chip is dead?
            by double_DD
            As the title suggests, how can I be sure that my EC chip is really dead?
            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
            03-12-2025, 07:47 AM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • bigbadbios
            Laptop dead after replacing BIOS Chip
            by bigbadbios
            I have an ASUS ROG Strix G533z 12th gen i9 laptop that had no video.
            I suspected BIOS corruption, so I took the main BIOS chip off and replaced it with another one that had a clean BIN I bought online.
            After doing so, the device is stone dead. Even with the original chip fitted back.
            I sent it to Northridge Fix (I am based in US) and he said no activity on thermal cam and no power issue is not directly firmware related.
            Can anyone help? I'd love to save this fairly new and powerful laptop.
            Thank you!​
            03-21-2024, 05:17 PM
          • nubie
            ASUS A320M-K dead with hot ite 8655e chip.
            by nubie
            I tried soldering a new one (hot air), same symptoms, no response from power button and
            ITE 8655e GXS chip is getting hot.
            What can make that chip get hot? Thanks...
            10-21-2024, 01:14 PM
