MacBook Apro 16" A2141 Just 5,181Volt
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    Hi, I have a MacBook Pro 16" it has liquid damage. With the power supply I only get 5.181 volts only on one USB-C plug! Left and right. See pictures.
  • mon2
    • Dec 2019
    • 14169
    Re: MacBook Apro 16" A2141 Just 5,181Volt
    Remove all power. Meter in lowest resistance mode.
    Confirm the resistance across each of the 4 fuses on this logic board for the Type C connectors.
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      all 4 fuses 0.37 ohm from pin1 to pin2
      • mon2
        • Dec 2019
        • 14169
        Good.
        Check the voltage @ F7000 / F7001 = PPBUS_G3H with the adapter mated with a working port.
        • Strolch
          • Nov 2017
          • 237
          • Deutschland
          0,0004v
          • mon2
            • Dec 2019
            • 14169
            So PPBUS_G3H is not working. Meter in resistance mode. Remove all power.
            Check the resistance to ground on both sides of the fuse @ F7000.
            • mon2
              • Dec 2019
              • 14169
              I should have clarified...do you see the same voltage on either side of fuse F7000 ?
              • Strolch
                • Nov 2017
                • 237
                • Deutschland
                yes
                and F7000/ F7001 is 0,35 ohms both sides to ground
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  the new MacBooks always only have 5 volts after liquid or the display doesn't work! Apple built it that way on purpose!?
                  • mon2
                    • Dec 2019
                    • 14169
                    LOL.
                    Remove both F7000 and F7001 fuses off the logic board.
                    No power to the logic board.
                    Measure the resistance to ground again using the fuse pads. We wish to know, is the short to ground on the power rail producer side or consumer side.
                    Post the measurements.
                    • Strolch
                      • Nov 2017
                      • 237
                      • Deutschland
                      Hi mon2, we have 11,5m ohms at pin1 and 0,35ohms at pin2
                      • Strolch
                        • Nov 2017
                        • 237
                        • Deutschland
                        I absolutely have to get books to teach SMD Technink.
                        • mon2
                          • Dec 2019
                          • 14169
                          So the producer side = U7000 is ok with the very high resistance.
                          The fault is on the consumer side of this power rail due to the very low resistance on SMD pad # 2.
                          Confirm there are no shorts from this fuse removal and apply power again.
                          Meter in voltage mode -> check the voltage @ SMD pad # 1.
                          What voltage do you read with the meter ?
                          If this does not equal to PPBUS_G3H then most likely, U7000 is defective but need to do other checks.
                          Then, need to review where is the possible part that is shorted on this logic board. Voltage injection may be a good choice @ 0v8 with a power supply but wait till we confirm U7000 first.
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            We have at Pin1= 12.227 volts
                            Pin2=0Volt
                            • Strolch
                              • Nov 2017
                              • 237
                              • Deutschland
                              Pin2=0Volt
                              Pictures
                              • mon2
                                • Dec 2019
                                • 14169
                                Very good. Your U7000 appears to be alive but gets shutdown due to the excessive current draw from the low resistance = 0.35 ohms.
                                Short is downstream. Would you have a current limited power supply ?
                                Dial up 0v8 = 0.8 volts and try @ 2A and inject this onto pad # 2. This is because something downstream that is shorted. It could be a capacitor or perhaps a chip.
                                Using alcohol / thermal camera - review which part gets hot. Leave the voltage low (on purpose) so to not kill a low voltage device that may be shorted to this rail.
                                Suggest to apply the voltage and then remove and check for any warming of a component on the board. If required, increase the current but go slowly.
                                • Strolch
                                  • Nov 2017
                                  • 237
                                  • Deutschland
                                  Unfortunately, I don't have a current-limited power supply. what does it look like? Then I'll buy it ;-). But I hope we can do it without now.
                                  • mon2
                                    • Dec 2019
                                    • 14169
                                    Do you have a variable power supply ? Need to keep the voltage low - just in case there is a short downstream to a sensitive component.
                                    Suspecting a shorted tantalum capacitor but we do not know at this time.
                                    If yes to the adjustable power supply - select at 0.8 volt (we want to keep it under 1 volt) for now. Then check for any part that is getting warm / hot to the touch or can mist alcohol. It is safe to pour alcohol over the parts you suspect and check for a quick dry of the liquid.
                                    Red power supply lead on fuse pad # 2 (the one with the low resistance) + black power supply lead to ground.
                                    • Strolch
                                      • Nov 2017
                                      • 237
                                      • Deutschland
                                      No I have not current limited power supply and thermal camera. But I will buy it today!
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 667
                                        Power Supplies are very cheap and very effective in finding a short. I would totally invest in one!
                                        sigpic
                                        MEOWING IN THE IMPOSSIBLE UNIVERSE!
