THINKPAD T450S - NM-A301 no power
  • Stunt
    • Oct 2019
    • 203
    • South Africa
    Hi i've THINKPAD T450S - NM-A301 with no power when i diagnosed it i'm only getting 20v on the main power nothing else on U41 chip that generate 5v and 3v i only get 20v on VIN pin and 0v on EN, EN1 and EN2 pins when i check the schematic EN, EN1 and EN2 signals comes from SIO chip and there's no 3,3v around SIO chip there's only 20v on pin 65 that's. Is the SIO chip dead? please help
  • Udemzy
    • May 2017
    • 164
    • Guatemala
    Re: THINKPAD T450S - NM-A301 no power
    What do you have on pin 22,29,2?
    You need the ic to generate vreg3 and vreg5 before talking about en1 and en2
    • Stunt
      • Oct 2019
      • 203
      • South Africa
      Hi on U41 Chip on Pin 2 = 0v. Pin 22 = 3.3v. Pin 29 = 0v
      • Stunt
        • Oct 2019
        • 203
        • South Africa
        • Techtiger
          • Oct 2014
          • 1602
          • france
          What is the impedance on L4 /L3 coil ? Is the U41 getting hot when you touch ? Note down voltage on all pins of tps51220
          • Stunt
            • Oct 2019
            • 203
            • South Africa
            The impedance on L4 = 3.1 k ohms on L3 its not stable it keeps on jumping between Mili ohms and K ohms. The U41 is not getting hot. The Voltages on tps51220 pins there are all 0v except pin 22 which is 3.3v and pin 23 which is 20v
            • mon2
              • Dec 2019
              • 14664
              Remove all power. Meter in resistance mode (2k scale).
              Measure the resistance to ground of VREG5 (pin 29) of U41.
              Post the readings.
              VREG5 will only enable if EN (U41, pin 12) is a logic HIGH.
              EN (pin 12) of U41 receives this signal from the TQFP128 (Toshiba) part TB62D516FG (TQFP128 14X14) @ U101 (pin 96) = KBC ??
              • Stunt
                • Oct 2019
                • 203
                • South Africa
                Post the readings.
                VREG5 Pin 29 = 0.451 resistance to ground
                • mon2
                  • Dec 2019
                  • 14664
                  This should not be the diode mode setting. Suggest the 2k ohm scale (or closest on your meter).
                  Can you confirm the resistance scale used for this measurement ?
                  • Stunt
                    • Oct 2019
                    • 203
                    • South Africa
                    OK the resistance starts from 567.8 k omhs and keeps on droping rapidly until it reaches 457.6 k ohms that's when it becomes steady i don't understand it
                    • mon2
                      • Dec 2019
                      • 14664
                      The rather high resistance is ok and confirms there is no excessive load (ie. short circuit or a bad cap) on this rail. So this rail has no reason to turn OFF.
                      Now for this rail to enable, the EN pin of U41 needs to be a logic high as per the shared datasheet for this component.
                      This logic level for the EN pin comes upstream from the Toshiba component (pin 96).
                      Is the Toshiba component warm / hot to the touch ? Review if the power rails are present on this component.
                      • Stunt
                        • Oct 2019
                        • 203
                        • South Africa
                        On pin 96 = 0v and resistance is 32k ohms. I get 20v on pins 99 and 65 only the rest of the pin are 0v. The toshiba component is not getting hot and there are no burnt signs on the chip
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
                        • DynaxSC
                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                          by DynaxSC
                          Hi
                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                          08-04-2025, 12:20 PM
                        • Paffo
                          Thinkpad Tablet 2 (2679) No Power
                          by Paffo
                          I recently got my hands on a batch of Thinkpad Tablet 2 that a local business was throwing away. They all have the same issue, no Power.
                          I do have a working one that i also took and the first thing i did was trying to power it without the battery being inserted.
                          It seems that these tablets do not work unless the battery is in (my PSU is 5V5A so i doubt it's a current thing, probably design).
                          I thought i'd be lucky so i took the battery from the working one and i tried it in 2-3 of the broken ones, but no luck, still no power.
                          The current draw is 18mA...
                          07-05-2024, 03:30 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
