A1706 820-00923 CPU gets warm, no post
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    This MacBook is fallen on is back, says the previous owner, after this nothing.
    Every tension on the CPU is present. With board disconnected, board takes first 820 mAmps, falls down to 720, falls down till 666mAmps and stays.
    No backlight enable signal, no post signal and CPU gets warm. After a while the fans starts spinning because of the hot heatsinks.
    Long press on the TouchID button switches the laptop off and 2nd press back on. Battery charges and on battery the same behavior.
    CPU reballed, no improvement.
    Dead CPU, or other clues?
    Might this be a dead BIOS rom chip?
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    Re: A1706 820-00923 CPU gets warm, no post
    update: ALL_SYS_PWR_GOOD is high, which proves the well functioning of all power lines.
    I mesured with oscilloscope SPI_MLB_IO1_MISO and SPI_MLB_IO0_MOSI and there's communication visible till the current drops to 666mAmps.
    Removed BIOS chip and current stays on 500mAmps. CPU seems to read from BIOS.
    Anyone who could tell something more with this update?
    • Danielreinaa
      HELP need password bios Macbook A1706
      by Danielreinaa
      Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
      Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
      Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
      gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
      Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
      09-07-2024, 03:47 PM
    • moderator
      A1706 - emc 3107 bios
      by moderator
      a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
      Serial number is C02STA7EHF1P
      its A1706 - emc 3107...
      05-17-2024, 07:00 AM
    • proxneo
      iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
      by proxneo
      Dear reader
      TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
      I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
      12-01-2023, 04:14 AM
    • capon5153
      Macbook A1706 works perfectly but no data on USB C
      by capon5153
      hello,
      so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
      i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
      06-22-2025, 09:42 AM
    • madjid911
      A1706 No power
      by madjid911
      Hello, I have a macbook a1706 (820-00923-A) that does not turn on, the 20v ubc triggers but no power consumption, no short and no liquid damage, PPBUS_G3H: 0V15 (16mohms no short), U7000 is well powered by the 20V, I looked at everything around the ISL9239 chip the resistors are good, so I replaced the chip twice but the result is the same, my skills stop there can you help me please?
      02-17-2025, 12:32 PM
