MacBook Air A1466 webcam not detecting
  • mferna14
    • Jun 2018
    • 1018
    I am working on a MacBook Air A1466 (Board # 820-00165-A). The initial problem was liquid spill near the ROM chip & after cleaning & re-programmed (ME Region cleaned) all worked fine without any problems. It boots up fine, & the only problem now it is not detecting the Webcam. 1st I tested with a know good camera, same issue. I was reading forums & they say about this resistance R2042 (0 Ohms) & U1900. There was corrosion on R2042, I replaced the resistor & even U1900 on the safe side. No Luck. L4007 & L4009 are perfect too. Then I had one Known good U3900, replaced it, no luck at all. I get 5V on the webcam connector & it seems to be fine too. What could be the problem???? Thanks
  • mon2
    • Dec 2019
    • 14106
    Re: MacBook Air A1466 webcam not detecting
    Confirm the voltage readings of I2C_CAM_SDA & I2C_CAM_SCK.
    The camera is a MIPI device and needs I2C to be working for the register configuration and detection.
    What is the voltage of CAM_SENSOR_WAKE_L_CONN ?
    • piernov
      • Jan 2016
      • 4435
      • France
      https://logi.wiki/index.php/BCM15700_Camera
      • mferna14
        • Jun 2018
        • 1018
        Thank you very much mon2 & piernov, you guys are really very helpful. I will check these volts today & let you guys know, where the webcam is acting upon.
        • mferna14
          • Jun 2018
          • 1018
          I2C_CAM_SDA 1.79V & I2C_CAM_SCK 1.79V & CAM_SENSOR_WAKE_L_CONN 0 Volts even when the camera cable is attached to the logic board connector. So this CAM_SENSOR_WAKE_L_CONN should also be 1.79v because I am getting 1.79v on R4005 (Both sides 1.79 & 1.77V) but it's NOT reaching R4031. BUt I see in all the board R4030 in not present???? Why?? There might be a circuit break somewhere, I have to check this. Just Mon2 please confirm the voltages, am I right??? Thanks
          • piernov
            • Jan 2016
            • 4435
            • France
            BOM option CAM_WAKE:YES not populated, CAM_WAKE:NO populated instead.
            • mferna14
              • Jun 2018
              • 1018
              piernov, seriously I did not understand "BOM option CAM_WAKE:YES not populated, CAM_WAKE:NO populated instead" can you please explain in detail please.. Thanks
              • piernov
                • Jan 2016
                • 4435
                • France
                • mferna14
                  • Jun 2018
                  • 1018
                  Thank you so much for the Explaination "Piernov"., really very help, so I think in the logic board which I am working the resistor R4030 should not be populated???
                  • kevingill
                    • Jun 2013
                    • 152
                    • England
                    I've seen MacBooks where a bad battery stops the webcam working.
                    Might be worth a quick check or unplug battery.
                    • mferna14
                      • Jun 2018
                      • 1018
                      Good idea, I will try this too. Always tested it with the battery connected, maybe this might help removing the battery first. Thanks anyways
                      • mferna14
                        • Jun 2018
                        • 1018
                        Battery disconnected, but still the same camera not detected... Tomorrow will check in detail. Thanks for the tip.
                        • mferna14
                          • Jun 2018
                          • 1018
                          OK., I am still on this "webcam not detecting", have not given up. I replaced component with know good ones. Replaced the U3900, U1900, U4000 & SMC U5000. The only problem was there was liquid spill near U1900, & then I replaced the CAPs & the resistors too around U1900. But still no luck. I measured all the voltages on these points & all are present. (PP1V35_CAM 1.35V, PP1V8_CAM 1.8V, PP3V3_S3RS0_CAMERA 3.3V, PP1V2_CAM 1.2V, PP0V675_CAM_VREF .67V) All these voltages were taken near U3900 & all present.. Where am I going wrong??? I reset the SMC, & re-programmed BIOS & on the safe side replaced with another known good webcam, NO LUCK AT ALL. Still gives No Camera Detected. Any Help or Tip will be a great help. Thanks
