Dell g3 p89f002 burnt component identification
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Hi folks
    Can anybody tell me what component is this and what does it do ?
    It is near lcd connector
    Is there any hope fixing it ?
    Looks to me it is welded to board firmly
    • 21917
    Re: Dell g3 p89f002 burnt component identification
    Originally posted by ss45
    Hi folks
    What is the motherboard part number ,search for a schematic and boardview to help ID what it is .
    https://www.badcaps.net/forum/showthread.php?t=88758
    1.1.3 Motherboard model number
    • ss45
      • Jun 2019
      • 119
      • Brazil
      I believe this is the board number
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Dell G3 3590 Wistron Selek CFL-H 18225-1- this schematic is there on forum. might help
        • ss45
          • Jun 2019
          • 119
          • Brazil
          Thank you for your reply..
          Ughh this looks ugly... It supplies Vccio which is part of CPU.. so my bet is this PC is as good as ornament..
          Rant: dell why don't you put fuse at the Vin of this chip.... Cries..... End rant
          Case closed
          • piernov
            • Jan 2016
            • 4439
            • France
            Sadly fuse won't help. Razer boards have fuses, high failure rate of CPU VRM ICs and CPU often dies as a result even when the fuse has blown.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes, whenever an IC is blown in VCCIO/VCORE/GFXCORE on newer motherboards, SOC dies(On rare occassion it survives)
              • ss45
                • Jun 2019
                • 119
                • Brazil
                Sad violin noise 🎻
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • nobbnobb1
                  Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                  by nobbnobb1
                  I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                  - 1x 3.14 A @ 250V main circuit fuse
                  - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                  - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                  11-16-2024, 09:56 PM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
